ST-7 構造図
SURFACE MOUNT CERMET TRIMMERS (3 TURNS)
RoHS compliant
ST-7
INTERNAL STRUCTURE
①
⑨
⑬
⑫
⑧
⑪
③
④
⑦ ⑥ ⑤ ②
Part name
■ FEATURES
RoHS compliant
Fine adjustment is possible
Automatic mounting is possible (Taping)
Flow/reflow soldering is possible
Sealed construction (Washable: Refer to page 698.)
Resin material is UL Recognized 94V-0
⑩
Material
①
Rotor gear
②
Base element
③
Terminal pin
④
Resistive element
RuO2 cermet
⑤
Electrode
Ag-Pd cermet
⑥
Housing base
⑦
Wiper
⑧
Shaft
⑨
Housing
⑩
Shaft “O” ring
⑪
Base “O” ring
⑫
Clutch spring
⑬
Cover
Polyphenylenesulphide
Ceramic
Copper alloy, Sn-Cu-plated
Multi metal alloy
Silicone rubber
Stainless steel
■ PART NUMBER DESIGNATION
S T - 7 E T A 1 kΩ ( 1 0 2 )
Series name
Resistance code
Terminal pin
Resistance value
E:Sn-Cu (Lead-free)
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Product shape (Shape of terminal)
A:J-hook(Top adjustment)
B:Gull wingg(Top adjustment)
ST-7
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
Shape of terminal
Form of packaging
Taping (reel)
Plastic bag
ST-7ETA
ST-7EA
B ( Gull wing ) ST-7ETB
ST-7EB
A (J-hook)
Top adjustment
Pieces in package
500 pcs./reel
50 Ω
100 Ω
200 Ω
500 Ω
10 kΩ
20 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
1 kΩ
2 kΩ
5 kΩ
Fig. 1
※ The above part numbers are all available with the respective combination of
(Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping specification is not sold separately and must be purchased in reel units.
50 pcs./pack
■ ELECTRICAL CHARACTERISTICS
■ MECHANICAL CHARACTERISTICS
Nominal resistance range
50 Ω ~ 1 MΩ
Mechanical turn
3 turns
Resistance tolerance
± 20 %
Operating torque
5 mN·m {51 gf·cm} maximum
Mechanical stop
Clutch action
Power ratings
0.25 W (70 °C) 0 W (125 °C)
Resistance law
Linear law
Rotational life
100 cycles [ Δ R/R ≦ ± (2 Ω +3 %)]
Thrust to shaft
5 N {0.51 kgf} minimum
Maximum input voltage DC200 V or power rating, whichever is smaller
Solderability
245 ± 3 °C, 2 ~ 3 s
Maximum wiper current 100 mA or power rating, whichever is smaller
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Effective electrical turn
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
2.5 turns
End resistance
1 % or 2 Ω, whichever is greater
C.R.V.
1 % or 3 Ω, whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
− 55 ~ 125 °C
50 Ω : ± 250 10-6/°C maximum
100 Ω ~ 1 MΩ : ± 100 10-6/°C maximum
1000 MΩ minimum (DC500 V)
Pull-off strength
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Thermal shock
Dielectric strength
AC600 V, 60 s
Humidity
Net weight
Approx. 0.25 g
Shock
Vibration
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
Peak : 250 0 ℃
5 N {0.51 kgf} 10 s
Load life
Test conditions
Specifications
− 65 ~ 125 °C (0.5 h), 5 cycles
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
70 °C, 0.25 W, 1000 h
180 ℃
150 ℃
Pre Heating Zone
Heating time
Soldering Zone
[ Δ R/R ≦ 3 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
− 55 °C, 2 h
High temp. exposure
125 °C, 250 h
Immersion seal
85 °C, 60 s
No leaks (No continuous bubbles)
Soldering heat
Flow : 260 ± 3 °C as the temperature in a
pot of molten solder, immersion from head of
terminal to backside of board, 5 ~ 6 s, two
times maximum
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
Manual soldering:350 ± 10 °C, 3 ~ 4 s
[ Δ R/R ≦ 1 %]
90±30 s
30±10 s
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
Low temp. operation
+5
Over 230 ℃
[ Δ R/R ≦ 2 %]
Reflow : two times maximum
Δ R/R:Change in total resistance
S.S. :Setting stability
ST-7
■ MAXIMUM INPUT RATINGS
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
Nominal resistance
values ( Ω )
● ST-7EA
2
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
15.8
22.4
35.4
50.0
70.7
112
15.8
11.2
7.07
5.00
3.54
2.24
100 k
200 k
500 k
1 M
104
204
504
105
158
200
200
200
1.58
1.00
0.40
0.20
2
70.7
50.0
35.4
22.4
2
3.53
5.00
7.07
11.2
(Unit: mm)
2
500
101
201
501
3.5
50
100
200
500
● ST-7EB
2
Maximum input Maximum wiper
voltage (V)
current (mA)
2
Resistance
code
1.6
1.6
1.6
2.35
1.6
2.35
Note) The zero point is the center of mounting.
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● ST-7EA
Top adjustment
①
0.5 W × 1.8 L × 0.5 D
6.8 –0.5
1.5
6.1
t = 0.15
1
1.2
3.4
1.5
2
2 – 0.8
0.02 min.
3
②
4.3
6.4
Lead-free Identification mark
③
CW rotation
2.3
Resistance code & Production date code
6.4
2
3.4
1.5
1.2
t = 0.15
3
0.02 min.
0.35 min.
1
7.8
6.1
1.5
0.35 min.
● ST-7EB
Top adjustment
2 – 0.8
2.3
※The ST-7 series has a different terminal arrange-ment from the ST-32 and ST-4 series.
Pay attention to the location of terminals number 1 and 3. (Resistance decreases when the shaft is
turned CCW.)
ST-7
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the dia- grams below.
● EMBOSSED TAPE DIMENSIONS
ST-7TB
Taping
Empty
Filled
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
(Unit: mm)
Empty
End
21±0.8
Head
40 mm min.
50 min.
17.4±1
2±0.5
20 pitches min.
Leader
13±0.2
400 mm min.
Direction of feed
254±2
● ST-7ETB
4±0.1
2±0.1
0.4±0.1
1.75±0.1
12±0.1
7.5±0.1
Installation example
(ST-7EA)
16
7.5±0.1
1.75±0.1
0.4±0.1
+0.1
2±0.1
5
4±0.1
Φ1.
+0.1
Φ1
12±0.1
5
Direction of feed
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
(ST-7EB)
16
● ST-7ETA
21.4±1
5
Direction of feed
很抱歉,暂时无法提供与“ST7ETA103”相匹配的价格&库存,您可以联系我们找货
