CT6EN104
CT6EN104
    COPAL(日电产 科宝电子)
    精密微调电阻 100KΩ ±10% 1/2W ±100ppm/℃
CT6EN104 数据手册
    SINGLE TURN CERMET TRIMMERS CT-6 $5ߏ଄ਤ RoHS compliant INTERNAL STRUCTURE 1 2 3 4 5 !0 6 9 8 Part name ■ FEATURES ● ● ● ● RoHS compliant Various configurations to choose from Wide variety (14 types) “O” ring sealed and washable 7 Material 1 Housing 2 Rotor 3 Wiper Multi metal alloy 4 Rubber cushion Silicone rubber 5 “O” ring Silicone rubber 6 Resistive element 7 Terminal pin 8 Adhesive 9 Base element !0 Electrode Flammability Polybutyleneterephthalate UL94V-0 — UL94HB RuO2 cermet Copper, Tin-plated — Epoxy UL94V-0 Ceramic — Ag-Pd cermet ■ PART NUMBER DESIGNATION C T - 6 E T V 5 kΩ ( 5 0 2 ) Series name Resistance code Terminal pin Resistance value E:Sn (Lead-free) Product shape Form of packaging T:Taping (Ammo pack type) M:Magazine (stick) Blank:Bulk in plastic bag P:Top adjustment W:Top adjustment R:Top adjustment V:Top adjustment F:Rear adjustment ※ Please refer to the LIST OF PART NUMBERS when placing orders. S:Side adjustment X:Side adjustment H:Side adjustment N:Side adjustment CT-6 CERMET TRIMMERS ■ LIST OF PART NUMBERS Adjustment position Shape of terminal (Top view) ① ① ① ① ① ① ① ① ① Top adjustment ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ③ ③ ③ ③ ③ ③ ③ ③ ③ Side adjustment (↑Adjustment direction) ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① ① Rear adjustment ① ① ① ① ① ① ① ① ① ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② ② Pieces in package ③ ③ ③ ③ ③ ③ ③ ③ ③ Form of packaging Remarks Taping Magazine (stick) Plastic bag CT-6ETP Ammo pack type CT-6EMP CT-6EP The pin length of CT-6ETP & CT-6EMP is different from CT-6EP. CT-6EW — A CT-6ER — CT-6EV — CT-6ES The pin length of CT-6EMS is different from CT-6ES. CT-6EX — ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ ③ CT-6ETV Ammo pack type ③ ③ ③ ③ ③ ③ ③ ③ ③ CT-6EMS ① ① ① ① ① ① ① ① ① ③ ③ ③ ③ ③ ③ ③ ③ ③ CT-6ETH Ammo pack type CT-6EH ③ ③ ③ ③ ③ ③ ③ ③ ③ CT-6EN — A CT-6EF — 50 pcs./pack — ③ ③ ③ ③ ③ ③ ③ ③ ③ 1000 pcs./taping 75 pcs./stick  :Not manufactured The products indicated by → mark are manufactured upon receipt of order basis. The pin length of CT-6ETH is different from CT-6EH. 〈Nominal resistance values〉 Fig. 1 → 10 Ω →  20 Ω 50 Ω 100 Ω 200 Ω 500 Ω 1 kΩ 100 kΩ 2 kΩ 5 kΩ 10 kΩ 20 kΩ 200 kΩ 500 kΩ 1 MΩ 2 MΩ 50 kΩ ※ The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. ※ Taping and magazine specifications are not sold separately and must be purchased in taping or stick units. CT-6 CERMET TRIMMERS ■ ELECTRICAL CHARACTERISTICS 10 Ω ~ 2 MΩ Nominal resistance range Resistance tolerance ± 10 % Power ratings 0.5 W (70 °C) 0 W (120 °C) Resistance law Linear law Maximum input voltage DC200 V or power rating, whichever is smaller ■ MECHANICAL CHARACTERISTICS Mechanical angle 260 ° (1 turn) Operating torque 2 ~ 20 mN·m {20 ~ 204 gf·cm} Stop strength 50 mN·m {510 gf·cm} minimum Rotational life 200 cycles [ΔR/R ≦ ± (2 Ω +3 %)] Teminal strength 10 N {1.02 kgf} minimum (Tensile strength) Thrust to rotor 10 N {1.02 kgf} minimum Solderability 245 ± 3°C, 2 ~ 3 s { }:Reference only Maximum wiper current 100 mA or power rating, whichever is smaller Effective electrical angle 220 ° (1 turn) End resistance 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater Operating temp. range Temp. coefficient 10 Ω ~ 20 Ω : ± 250 10-6/°C maximum 50 Ω ~ 2 MΩ: ± 100 10-6/°C maximum 1000 MΩ minimum (DC500 V) Dielectric strength AC900 V, 60 s Approx. 0.51 g (CT-6EP, EW, ER, EV) Approx. 0.65 g (CT-6ES, EX, EH, EN) Approx. 0.92 g (CT-6EF) Net weight Test item Test conditions Specifications Thermal shock − 65 ~ 125 °C (0.5 h), 5 cycles [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] Humidity −55 ~ 120 °C Insulation resistance ■ ENVIRONMENTAL CHARACTERISTICS Shock −10 ~ 65 °C (80 ~ 98 %), 10 cycles, 240 h 981 m/s2, 6 ms 6 directions for 3 times each Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each Load life 70 °C, 0.5 W, 1000 h Low temp. operation −55 °C, 2 h High temp. exposure 120 °C, 250 h Immersion seal 85 °C, 60 s [ΔR/R ≦ 2 %] [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] [ΔR/R ≦ 3 %] [S.S. ≦ 1 %] [ΔR/R ≦ 2 %] [S.S. ≦ 2 %] [ΔR/R ≦ 3 %] [S.S. ≦ 2 %] No leaks (No continuous bubbles) Flow:260 ± 3 °C、5 ~ 6 s, Soldering heat two times maximum Manual soldering:380 ± 10 °C, 3 ~ 4 s [ΔR/R ≦ 1 %] Δ R/R:Change in total resistance S.S. :Setting stability ■ MAXIMUM INPUT RATINGS Nominal resistance values ( Ω ) Resistance code → 10 → 20 50 100 200 500 Maximum input voltage (V) Maximum wiper current (mA) 100 1.00 100 200 2.00 100 500 5.00 100 101 7.07 70.7 201 10.0 50.0 501 15.8 31.6 1 k 102 22.4 22.4 2 k 202 31.6 15.8 5 k 502 50.0 10.0 10 k 103 70.7 7.07 20 k 203 100 5.00 50 k 503 158 3.16 100 k 200 k 500 k 1 M 2 M 104 204 504 105 205 200 200 200 200 200 2.00 1.00 0.40 0.20 0.10 The produc t s indicated by → mark are manufactured upon receipt of order basis. CT-6 CT-6P 外形図 CERMET TRIMMERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CT-6EP Top adjustment CT-6W 外形図 ③ CW rotation 3 –φ0.45 0.6 W ×2.6 L×1.6 D 260°Nom. ② 2 7 2.5 Lead-free Identification mark ① 1 3 7 5.8 Resistance code & Production date code 7±2 2.5 2.5 ● CT-6EW Top adjustment CT-6V 外形図 3 –φ0.45 2 0.6 7 1.3 Lead-free Identification mark 0.6 W×2.6 L×1.6 D 260°Nom. 3 7 5.8 Resistance code & Production date code 7±2 ★ Pin pitch in W type is different from P type. ● CT-6EV Top adjustment CT-6ES 外形図 0.6 W ×2.6 L×1.6 D 260°Nom. 3 –φ0.45 3 1 2 7 Lead-free Identification mark 1 1.8 1.8 13.5±2 7 Resistance code & Production date code 5.8 2.5 2.5 16±2 ● CT-6ES Side adjustment 0.6 W×2.6 L×1.6 D Adjustment 7 +0.4 -0.2 1 3 2.5 2 2.5 2.5 3 –φ0.45 3.5 Resistance code & Production date code 8.2 0 7.5 ± 2 Lead-free Identification mark +0.4 4.6 7 CT-6 T-6X 外形図 CERMET TRIMMERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CT-6EX Side adjustment ① ③ CW rotation Resistance code & Production date code 0.6 W×2.6 L×1.6 D 7 ② Adjustment 2 + 0.4 – 0.2 4.6 CT-6H 外形図 2.5 8.2 3.5 7 + 00.4 3 10 ±2 Lead-free Identification mark 1 2.5 2.5 3 –φ0.45 0.6 W×2.6 L×1.6 D 7 + 00.4 Resistance code & Production date code Adjustment 2 7 +– 0.4 0.2 1 2.5 2.5 9.5 ±2 7 ±2 4.6 8.2 CT-6N 外形図 3 3.5 Lead-free Identification mark 3 –φ0.45 ● CT-6EN Side adjustment 0.6 W×2.6 L×1.6 D 2 7 +– 0.4 0.2 Adjustment 2.5 8.2 3.5 Resistance code & Production date code 4.6 7 7.5 ± 2 Lead-free Identification mark + 0.4 0 1 2.5 2.5 3 3 –φ0.45 ★ Terminals 1 & 3 position in N type is different from X type. CT-6F外形図 CT-6 CERMET TRIMMERS ■ OUTLINE DIMENSIONS ● CT-6EF Rear adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) <受注生産品 Semi-standard products > 0.6 W × 2.6 L × 1.6 D 2 ① ③ CW rotation 3 –φ0.45 ② CT-6R 外形図 φ10.5max. 4.4 Lead-free Identification mark 1 3 4.4 4.4 ● CT-6ER Top adjustment 5.52 0.3 7.6 Resistance code & Production date code < Semi-standard products > 3 – Φ 0.45 0.6 W × 2.6 L × 1.6 D CT-6 梱包仕様 260°Nom. 1 2 3 2.5 7 Lead-free Identification mark 7 Resistance code & Production date code 5.8 7±2 2.5 2.5 ■PACKAGING SPECIFICATIONS ● Taping version is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 1000, 2000, 3000 pcs., etc. ● Taping version (ammo pack type) is boxed with one reel (1000 pcs.). Direction of feed 45 #1 terminal 1 3 Direction of feed 33 0 Ammo pack type Ammo Pack ● Package size: 330 mm × 330 mm × 45 mm ● The leader and end of the tape have an empty part of minimum 300 mm respectively. ● There are two tape outlets on the package for different terminal alignment directions, for which details refer to the sketch above. (e.g.) When the tape is fed from the right outlet marked ③ , #3 terminal comes out first. ● Gross weight of the boxing version ETV : Approx. 840 g ETH : Approx. 930 g ETP : Approx. 850 g 0 33 #3 terminal CT-6 CERMET TRIMMERS ● CT-6ETV 外形図 CT-6TV Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ① Lead-free Identification mark ③ CW rotation 0.6 W × 2.6 L × 1.6 D 260°Nom. ② Resistance code & Production date code 7 12.7±1 ∆ 2 max. 1 5.8 18±0.5 0.5 max. 9 +– 0.7 0.5 2.5 ∆ 2 max. 6±0.5 3 min. 19±0.75 24.8±1 7 3 2.5 0.9 6.35±0.5 12.7±0.3 Φ4±0.2 0.45±0.02 CT-6TH 外形図 ● CT-6ETH Side adjustment 0.6 W × 2.6 L × 1.6 D 12.7±1 7 + 00.4 ∆ 2 max. 6±0.5 2.5 18±0.5 3.5 9 +– 0.7 0.5 0.5 max. 3 min. 19±0.75 27.2±1 1 3 2.5 6.35±0.5 12.7±0.3 7 +– 0.4 0.1 0.45±0.02 4.6 260°Nom. 8.2 Lead-free Identification mark Resistance code & Production date code Φ 4±0.2 0.9 ∆ 2 max. CT-6 CERMET TRIMMERS ● CT-6ETP Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) Lead-free Identification mark ① 0.6W × 2.6L × 1.6D 260°Nom. ③ CW rotation ② Resistance code & Production date code 7 12.7±1 ∆ 2 max. ∆ 2 max. 2.5 2.5 1 18±0.5 9 +0.7 –0.5 6±0.5 0.5 max. 3 min. 16±1 19±0.75 24.8±1 5.8 7 2.5 0.9 3 Φ 4±0.2 6.35±0.5 12.7±0.3 0.45±0.02 ● Magazine is packaged 75 pcs. per stick. Orders will be accepted for units of 75 pcs. i.e., 150, 225 pcs., etc. ● Magazine is packed 3000 pcs. sticks per box. CT-6MP 2 外形図 CT-6MS 2 外形図 Plastic magazine length = 580 mm (Without rubber cap) 9.1 7.4 9.8 16.6 16.6 9.1 CT-6EMP Plastic magazine type CT-6EMS CT-6 CERMET TRIMMERS CT-6MP 外形図 ● CT-6EMP Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) 3 –Φ 0.45 0.6 W × 2.6 L × 1.6 D ③ 2 260°Nom. CT-6EMS 外形図 CW rotation 2.5 ② 7 Lead-free Identification mark ① 1 3 7 5.8 Resistance code & Production date code 2.5 2.5 3.1 ● CT-6EMS Side adjustment 0.6 W × 2.6 L × 1.6 D Lead-free Identification mark Adjustment 7 +0.4 –0.2 8.2 1 3 3.1 4.6 2.5 2 3.5 7 +0.4 0 3 –Φ 0.45 2.5 2.5 Resistance code & Production date code ● Unit of bulk pack in a plastic bag is 50 pcs. per pack. ● Boxing of bulk in a plastic bag is performed with 200 pcs. (CT-6EF is 100 pcs.) per box. ■ ADJUSTMENT TOOL, MODEL TA-64 Recommended models + bit − bit CT-6 ST-4 FT-63 RJ-4 RJ-6 TM-7 Note : Please do not use the tool for purposes other than adjustment of electronic components. Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) + bit Tip thickness 0.50.05 0 Tip 2.4 –0.1 – bit Tip thickness 0.50.05 Tip 2.0 130 12 12 2 2 2.7 Φ 10 ● Good for both minus and cross slot rotors / shafts. ● Recommended for use with the following copal trimmers. Material : Polyoxymethylene 2.7
CT6EN104
1. 物料型号:CT-6系列精密电位器,包括不同调整方式和封装形式的型号。 2. 器件简介:CT-6是单圈精密电位器,符合RoHS标准,有多种配置可供选择,具有14种类型,采用“O”形环密封且可清洗。 3. 引脚分配:文档中提供了不同型号的电位器的引脚分配图和说明。 4. 参数特性: - 标称电阻范围:10~2MΩ - 电阻公差:±10% - 功率等级:0.5W(70°C)/0W(120°C) - 电阻规律:线性规律 - 最大输入电压:DC200V或功率等级中较小者 - 最大刮刷电流:100mA或功率等级中较小者 - 有效电气角度:220°(1圈) - 末端电阻:1%或2Ω中较大者 - C.R.V.:1%或3Ω中较大者 - 工作温度范围:-55~120°C - 温度系数:10~20Ω:最大±250ppm/°C,50~2MΩ:最大±100ppm/°C - 绝缘电阻:最小1000MΩ(DC500V) - 耐压:AC900V,60秒 5. 功能详解:文档详细描述了电位器的机械特性、环境特性和最大输入额定值。 6. 应用信息:虽然文档中没有直接提到应用信息,但从电位器的特性可以推断,它们适用于需要精密调整的电子设备。 7. 封装信息:提供了不同型号电位器的外形尺寸和封装规格,包括胶带包装、杂志包装和散装包装的详细信息。
CT6EN104 价格&库存
很抱歉,暂时无法提供与“CT6EN104”相匹配的价格&库存,您可以联系我们找货
