18 TURNS CERMET TRIMMERS
CT-9 構造図
RoHS compliant
CT-9
INTERNAL STRUCTURE
③
⑩
② ①
⑨
④
⑤
⑥
⑦
Part name
⑧
Material
■ FEATURES
①
Housing
● RoHS compliant
● General use type
● Fine setting is possible with 18 turns configuration
● Resin material is UL Recognized 94V-0
②
Base element
③
Wiper
④
Resistive element
RuO2 cermet
⑤
Electrode
Ag-Pd cermet
⑥
Adhesive
Epoxy
⑦
Terminal pin
⑧
Rotor gear
⑨
Rubber cushion
⑩
Shaft
Polybutyleneterephthalate
Ceramic
Multi metal alloy
Copper, Tin-plated
Polyamide
Silicone rubber
Brass, Nickel-plated
■ PART NUMBER DESIGNATION
C T - 9 E W 1 MΩ ( 1 0 5 )
Series name
Terminal pin
E:Sn (Lead-free)
Product shape
W :Top adjustment
X :Side adjustment
P :Side adjustment
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Resistance code
Resistance value
CT-9
表
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
〈Nominal resistance values〉
Form of packaging
Shape of terminal
(Top view)
Plastic pack
Pieces in
package
②
②
③
③
③
①
①
②
①
②① ③
③
①
②
②
①
①
②
①
②
③
①
①
②
①
②
③
Side adjustment
(↑Adjustment
direction)
①
③
③
③
20 kΩ
1 kΩ
2 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
5 kΩ
Fig.1
Top adjustment
③
→ 10 Ω → 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω
10 kΩ
※ The above part numbers are all available with the respective
combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
CT-9EW
50 pcs./
CT-9EX
The products indicated by → mark are manufactured upon
receipt of order basis.
pack
③
②
CT-9EP
②
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
Resistance tolerance
■ MECHANICAL CHARACTERISTICS
Mechanical turn
18 turns
10 Ω ~ 2 MΩ
Operating torque
35 mN·m {357 gf·cm} maximum
± 10 %
Mechanical stop
Clutch action
Power ratings
0.5 W (70 °C) 0 W (120 °C)
Resistance law
Linear law
Maximum input voltage DC300 V or power rating, whichever is smaller
200 cycles [ΔR/R ≦ ± (2 Ω + 3 %)]
Rotational life
Terminal strength
10 N {1.02 kgf} minimum
(Tensile strength)
Thrust to shaft
Solderability
245 ± 3 °C, 2 ~ 3 s
Maximum wiper current 100 mA or power rating, whichever is smaller
Effective electrical turn
15 turns
End resistance
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
Dielectric strength
Net weight
−55 ~ 120 °C
10 Ω , 20 Ω : ± 250 10 /°C maximum
50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Specifications
Thermal shock
−65 ~ 125 °C (0.5 h),
5 cycles
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
−10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
[ΔR/R ≦ 2 %]
Humidity
-6
1000 MΩ minimum (DC500 V)
AC900 V, 60 s
Approx. 0.94 g (CT-9EP)
Approx. 0.95 g (CT-9EX, EW)
Shock
981 m/s , 6 ms
6 directions for 3 times each
2
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.5 W, 1000 h
Low temp. operation
−55 °C, 2 h
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
Flow
260 ± 3 °C, 5 ~ 6 s, two times
Soldering heat maximum
Manual soldering
380 ± 10 °C, 3 ~ 4 s
[ΔR/R ≦ 1 %]
ΔR/R:Change in total resistance
S.S. :Setting stability
CT-9
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance values ( Ω )
Resistance code
10
100
200
500
Maximum input voltage (V)
Maximum wiper current (mA)
100 1.00 100
200 2.00 100
500 5.00 100
101
7.07
70.7
201
10.0
50.0
501
15.8
31.6
1 k
102
22.4
22.4
2 k
202
31.6
15.8
5 k
502
50.0
10.0
10 k
103
70.7
7.07
20 k
203
100
5.00
50 k 503 158 3.16
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
224
300
300
300
300
2.24
1.50
0.60
0.30
0.15
The products indi-cated by → mark are manufactured upon receipt of order basis.
CT-9W 外形図
■ OUTLINE DIMENSIONS
φ 2.3, Slot 0.6 W × 0.8 D
①
3 – φ 0.5±0.05
2
9.6
2.5 2.5
3
1.4
CT-9X 外形図
1.1
1.5
9.6
②
5 min.
Resistance code, Production date code and
Lead-free Identification mark
–0.1
5.5+0.4
2.7
1
● CT-9EX
Side adjustment
1.4
q 2.3, Slot 0.6 W × 0.8 D
3 – Φ 0.5±0.05
2
3
9.6
2.5 2.5
1.1
1.5
5.5+0.4
–0.1
9.6
5 min.
2.7
1
4.8
Resistance code &
③
CW rotation
4.8
● CT-9EW
Top adjustment
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
-9P 外形図
CT-9
CERMET TRIMMERS
①
3 – Φ 0.5±0.05
2
3
1.4
9.6
2.5
1.5
9.6
5.5 +0.4
–0.1
72
1.1
Resistance code, Production date code and Lead-free Identification mark
■PACKAGING SPECIFICATIONS
● Unit of bulk in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 100 pcs. per box.
4.8
1
③
CW rotation
②
2.5 2.5
Φ 2.3, Slot 0.6 W × 0.8 D
4.8
● CT-9EP
Side ajustment
很抱歉,暂时无法提供与“CT9EP105”相匹配的价格&库存,您可以联系我们找货
