RJ5EX205
RJ5EX205
    COPAL(日电产 科宝电子)
    精密微调电阻 2MΩ ±10% 1/4W ±100ppm/℃
RJ5EX205 数据手册
14 TURNS CERMET TRIMMERS RJ-5 RJ-5 構造図 RoHS compliant INTERNAL STRUCTURE ① ⑩ ② ③ ④ ⑤ ⑥ ⑦ Part name ⑧ ⑨ Material ■ FEATURES ① Housing ● ● ● ● ② Base element ③ Electrode Ag-Pd cermet ④ Resistive element RuO2 cermet ⑤ Adhesive ⑥ Wiper ⑦ Terminal pin ⑧ Rubber cushion ⑨ Rotor gear ⑩ Shaft RoHS compliant Fine setting is possible Sealed construction (Washable: Refer to 698) Resin material is UL Recognized 94V-0 Polybutyleneterephthalate Ceramic Epoxy Multi metal alloy Copper, Tin-plated Silicone rubber Polyamide Brass, Nickel-plated ■ PART NUMBER DESIGNATION R J - 5 E W 1 0 0 kΩ ( 1 0 4 ) Series name  Resistance code Terminal pin E:Sn (Lead-free) Product shape W :Top adjustment X :Side adjustment P :Side adjustment ※ Please refer to the LIST OF PART NUMBERS when placing orders.  Resistance value RJ-5 CERMET TRIMMERS ■ LIST OF PART NUMBERS Adjustment Shape of terminal position (Top view) ③ ① Form of packaging Plastic bag Pieces in package Side adjustment (↑Adjustment direction) 1 kΩ 2 kΩ 50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ 2 MΩ 5 kΩ Fig. 1 RJ-5EW The products indicated by → mark are manufactured upon receipt of order basis. ① 50 pcs./pack RJ-5EX ② ① 20 kΩ ※ The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. ② ③ →10 Ω →20 Ω 50 Ω 100 Ω 200 Ω 500 Ω 10 kΩ ③ ② RJ-5EP ■ ELECTRICAL CHARACTERISTICS Nominal resistance range Resistance tolerance 10 Ω ~ 2 MΩ ± 10 % Power ratings 0.25 W (85 °C) 0 W (120 °C) Resistance law Linear law Maximum input voltage DC200 V or power rating, whichever is smaller Maximum wiper current 100 mA or power rating, whichever is smaller Effective electrical turn 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater Temp. coefficient Insulation resistance Mechanical turn 14 turns Operating torque 20 mN·m {204 gf·cm} maximum Mechanical stop Clutch action Rotational life Terminal strength Thrust to shaft 200 cycles 10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)] 500 Ω ~ 2 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)] 10 N {1.02 kgf} minimum (Tensile strength) 5 N {0.51 kgf} minimum Solderability 245 ± 3 °C, 2 ~ 3 s { }:Reference only 11 turns End resistance Operating temp. range ■ MECHANICAL CHARACTERISTICS −55 ~ 120 °C 10 Ω ~ 50 Ω : ± 250 10 /°C maximum 100 Ω ~ 2 MΩ : ± 100 10-6/°C maximum -6 1000 MΩ minimum (DC500 V) Dielectric strength AC600 V, 60 s Net weight Approx. 0.37 g ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Thermal shock −65 ~ 125 °C (0.5 h), 5 cycles −10 ~ 65 °C (80 ~ 98 %), Humidity 10 cycles, 240 h 981 m/s2, 6 ms Shock 6 directions for 3 times each Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each Load life 85 °C, 0.25 W, 1000 h Low temp. operation − 55 °C, 2 h High temp. exposure 120 °C, 250 h Immersion seal 85 °C, 60 s Soldering heat Flow 260 ± 3 °C, 5 ~ 6 s, two times maximum Manual soldering 380 ± 10 °C, 3 ~ 4 s Specifications [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] [ΔR/R ≦ 1 %] [ΔR/R ≦ 1 %] [S.S. ≦ 1 %] [ΔR/R ≦ 2 %] [S.S. ≦ 1 %] [ΔR/R ≦ 2 %] [S.S. ≦ 2 %] No leaks (No continuous bubbles) [ΔR/R ≦ 1 %] ΔR/R:Change in total resistance S.S. :Setting stability RJ-5 CERMET TRIMMERS ■ MAXIMUM INPUT RATINGS Nominal resistance values ( Ω ) Resistance code Maximum input voltage (V) Maximum wiper current (mA) → 10 → 20 50 100 200 500 100 1.00 100 200 2.00 100 500 3.53 70.7 101 5.00 50.0 201 7.07 35.3 501 11.1 22.3 1 k 2 k 5 k 10 k 20 k 50 k 102 202 502 103 203 503 15.8 22.3 35.3 50.0 70.7 111 15.8 11.1 7.07 5.00 3.53 2.23 100 k 200 k 500 k 1 M 2 M 104 204 504 105 205 158 200 200 200 200 1.58 1.00 0.40 0.20 0.10 ■ OUTLINE DIMENSIONS The products indicated by → mark are manufactured upon receipt of order basis. Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● RJ-5EW Top adjustment ① φ1.6, Slot 0.6 W × 0.8 D Resistance code & Production date code ③ CW rotation 3 –φ0.4±0.05 Lead-free Identification mark 1 3 2.5 2 2.5 0.9 6 ② 1 4.3 1 6.75 7±2 2.5 1.2 2.5 1.2 ● RJ-5EX Side adjustment φ1.6, Slot 0.6 W × 0.8 D Resistance code & Production date code 3 –φ0.4±0.05 0.9 2.5 2 6 3 2.5 1 1 Lead-free Identification mark ● RJ-5EP Side adjustment 6.75 Resistance code & Production date code 1 7±2 φ1.6, Slot 0.6 W × 0.8 D 3 –φ0.4±0.05 3 2.5 2.5 0.9 6.4 2 2.5 1 6.75 Lead-free Identification mark 4.5 7±2 1 3.2 1 3.2 4.3 RJ-5 CERMET TRIMMERS ■PACKAGING SPECIFICATIONS ● Unit of bulk in a plastic bag is 50 pcs. per pack. ● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
RJ5EX205
物料型号:RJ-5EW、RJ-5EX、RJ-5EP
器件简介: - 符合RoHS标准 - 材料包括聚丁二酸丁二醇酯、陶瓷、银钯钼氧化物、环氧树脂、铜锡镀层、硅橡胶、聚酰胺、黄铜镀镍
引脚分配:文档中未明确列出引脚分配,但提供了端子形状和包装形式的视图。
参数特性: - 标称电阻范围:10~2MΩ - 电阻公差:±10% - 功率等级:0.25W(85°C),0W(120°C) - 电阻法则:线性法则 - 最大输入电压:DC200V或功率等级中较小者 - 有效电气转数:11转 - 端电阻:1%或2Ω中较大者 - C.R.V.:1%或3Ω中较大者 - 工作温度范围:-55~120°C - 温度系数:10~50Ω:最大250ppm/°C,100Ω~2MΩ:最大100ppm/°C - 绝缘电阻:最小1000MΩ(DC500V) - 耐压:AC600V,60s
功能详解: - 机械转数:14转 - 操作扭矩:最大20mN-m - 机械停止:离合器动作 - 旋转寿命:200次循环 - 端子强度:最小10N - 推力至轴:最小5N - 可焊性:245~250°C,2~3秒
应用信息:文档中未明确列出应用信息,但根据参数特性,这些微调电位器适用于需要精确调整电阻的场合。
封装信息: - RJ-5EW:顶调整,50个/袋 - RJ-5EX:侧调整 - RJ-5EP:侧调整
RJ5EX205 价格&库存
很抱歉,暂时无法提供与“RJ5EX205”相匹配的价格&库存,您可以联系我们找货
