SINGLE TURN CERMET TRIMMERS
RJ-4
RJ-4 構造図
RoHS compliant
INTERNAL STRUCTURE
⑪
①
⑩
②
③
④
⑨
⑤
⑥
Part name
⑦
⑧
Material
■ FEATURES
①
Rotor
②
“O” ring
③
Electrode
④
Base element
⑤
Base
Polyphenylenesulphide
⑥
Terminal pin
Copper alloy, Tin-plated
⑦
Resistive element
⑧
Adhesive
⑨
Wiper
Multi metal alloy
⑩
Rubber cushion
Silicone rubber
⑪
Cover
Stainless steel
RoHS compliant
Compact with power rating of 0.5 W
Precious metal alloy wiper
Resin material is UL Recognized 94V-0
Polybutyleneterephthalate
Silicone rubber
Ag-Pd cermet
Ceramic
RuO2 cermet
Epoxy
■ PART NUMBER DESIGNATION
R J - 4 E W S 2 kΩ( 2 0 2 )
Series name
Terminal pin
E:Sn (Lead-free)
Product shape
W:Top adjustment
WS:Side adjustment
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Resistance code
Resistance value
RJ-4
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
〈Nominal resistance values〉
Form of packaging
Pieces in
package
Plastic bag
Top adjustment
RJ-4EW
Side adjustment
RJ-4EWS
50 pcs./pack
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
Resistance tolerance
→ 10 Ω → 20 Ω
50 Ω
1 kΩ
2 kΩ
10 kΩ
50 kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
20 kΩ
100 Ω
200 Ω
500 Ω
5 kΩ
The products indicated by → mark are manufactured upon
receipt of order basis.
※ The above part numbers are all available with the respective combination
of (Fig. 1).
※ Verify the above part numbers when placing orders.
■ MECHANICAL CHARACTERISTICS
10 Ω ~ 2 MΩ
Mechanical angle
230 ° (1 turn)
± 10 %
Operating torque
15 mN·m {153 gf·cm} maximum
Stop strength
45 mN·m {459 gf·cm} minimum
Rotational life
200 cycles
10 Ω ~ 200 Ω [ Δ R/R ≦ ± (0.5 Ω +3 %)]
500 Ω ~ 2 MΩ [ Δ R/R ≦ ± (0.5 Ω +2 %)]
Power ratings
0.5 W (70 °C) 0 W (120 °C)
Resistance law
Linear law
Maximum input voltage DC200 V or power rating, whichever is smaller
Terminal strength
10 N {1.02 kgf} minimum
(Tensile strength)
Maximum wiper current 100 mA or power rating, whichever is smaller
Thrust to rotor
Effective electrical angle
Solderability
200 ° (1 turn)
End resistance
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
Dielectric strength
Net weight
Fig. 1
{ }:Reference only
■ ENVIRONMENTAL CHARACTERISTICS
− 55 ~ 120 °C
Test item
10 Ω ~ 50 Ω : ± 250 10-6/°C maximum
100 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
Thermal shock
1000 MΩ minimum (DC500 V)
AC500 V, 60 s
Approx. 0.26 g (RJ-4EW)
Approx. 0.35 g (RJ-4EWS)
245 ± 3 °C, 2 ~ 3 s
Humidity
Shock
Test conditions
Specifications
− 65 ~ 125 °C (0.5 h),
5 cycles
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.5 W
1000 h
Low temp. operation
− 55 °C, 2 h
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
Soldering heat
Flow:
260 ± 3℃、5 ~ 6 s, two times
Manual soldering:
380 ± 10 °C, 3 ~ 4 s
[ Δ R/R ≦ 1 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
[ Δ R/R ≦ 1 %]
Δ R/R:Change in total resistance
S.S. :Setting stability
RJ-4
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance values ( Ω )
Resistance code
10
100
200
500
Maximum input voltage (V)
Maximum wiper current (mA)
100 1.00 100
200 2.00 100
500 5.00 100
101
7.07
70.7
201
10.0
50.0
501
15.8
31.6
1 k
102
22.4
22.4
2 k
202
31.6
15.8
5 k
502
50.0
10.0
10 k
103
70.7
7.07
20 k
203
100
5.00
50 k 503 158 3.16
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
200
200
200
200
200
■ OUTLINE DIMENSIONS
0.6 W × 2.5 L × 0.8 D
①
Lead-free Identification mark
(2
.5
6.5±1.5
1
3
3.5
1.8±0.2
Resistance code & Production date code
3 – φ 0.4±0.05
■ PACKAGING SPECIFICATIONS
● Unit of bulk pack in a plastic bag is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 200 pcs. per box.
3.5
5 + 00.4
0.8±0.2
6.6
(2 2
.5
52
3 min.
4.1
1
0.1
5.6 +– 0.4
Adjustment
0.4
● RJ-4EWS
Side adjustment
0.4
4.5
②
2
3 – φ 0.4±0.05
1±0.2
③
CW rotation
φ4.9 + 00.3
230˚Nom.
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
(Exclude clamp)
● RJ-4EW
Top adjustment
are manufactured
upon receipt of
order basis.
2.00
1.00
0.40
0.20
0.10
0.8±0.2
3
很抱歉,暂时无法提供与“RJ4EWS105”相匹配的价格&库存,您可以联系我们找货
