RJ-13
SINGLE TURN CERMET TRIMMERS
RJ-13 構造図
RoHS compliant
INTERNAL STRUCTURE
②
①
⑩
⑨
③
④
⑧
⑤
⑥
Part name
■ FEATURES
● RoHS compliant
● Wide resistance range from10 Ω to 5MΩ
● Precious metal alloy wiper
● Resin material is UL Recognized 94V-0
⑦
Material
①
Rotor
Polybutyleneterephthalate
②
Cover
Stainless steel
③
Electrode
Ag-Pd cermet
④
Resistive element
RuO2 cermet
⑤
Base element
⑥
Terminal pin
⑦
Adhesive
Epoxy
⑧
“O” ring
Silicone rubber
⑨
Wiper
Multi metal alloy
⑩
Rubber cushion
Silicone rubber
Ceramic
Nickel, Gold-plated
■ PART NUMBER DESIGNATION
R J - 1 3 P 2 0 kΩ ( 2 0 3 )
Resistance code
Series name
Resistance value
Product shape
P :Top adjustment
B :Panel mount
S :Side adjustment
PR :Top adjustment with knob
SR :Side adjustment with knob
※ Please refer to the LIST OF PART NUMBERS when placing orders.
RJ-13
CERMET TRIMMERS
■ LIST OF PART NUMBERS
Adjustment Shape of terminal
position
(Top view)
Top adjustment
②
①
③
〈Nominal resistance values〉
Form of packaging
Pieces in
package
Plastic bag
RJ-13P
50 pcs./pack
③
③
①
10 kΩ
1 MΩ
2 MΩ
→ 5 MΩ
Fig. 1
The products indicated by
of order basis.
25 pcs./pack
③
RJ-13S
③
RJ-13SR
mark are manufactured upon receipt
②
①
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
10 Ω ~ 5 MΩ
Resistance tolerance
± 10 %
■ MECHANICAL CHARACTERISTICS
Mechanical angle
270 ° (1 turn)
Operating torque
3 ~ 35 mN·m {30.6~357 gf·cm}
Stop strength
Power ratings
100 mN·m {1.02 kgf·cm}
0.75 W (70 °C) 0 W (120 °C)
Rotational life
Resistance law
Linear law
Maximum input voltage DC300 V or power rating, whichever is smaller
Terminal to strength
200 cycles
10 Ω ~ 200 Ω [ΔR/R ≦ ± (0.5 Ω +3 %)]
500 Ω ~ 5 MΩ [ΔR/R ≦ ± (0.5 Ω +2 %)]
20 N {2.04 kgf} minimum
(Tensile strength)
10 N {1.02 kgf} minimum
Thrust to rotor
Maximum wiper current 100 mA or power rating, whichever is smaller
Effective electrical angle
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
Operating temp. range
Temp. coefficient
Insulation resistance
Dielectric strength
Solderability
245 ± 3 °C, 2 ~ 3 s
{ }:Reference only
230 ° (1 turn)
End resistance
Net weight
5 kΩ
RJ-13PR
②
Side
adjustment
(↑Adjustment
direction)
100 kΩ 200 kΩ → 250 kΩ 500 kΩ
2 kΩ
RJ-13B
②
①
20 kΩ → 25 kΩ 50 kΩ
1 kΩ
※ The above part numbers are all available with the respective
combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
②
①
→ 10 Ω → 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω
−55 ~ 120 °C
10 Ω , 20 Ω , 5 MΩ : ± 250 10-6/°C maximum
50 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
1000 MΩ minimum (DC500 V)
AC900 V, 60 s
Approx.
Approx.
Approx.
Approx.
Approx.
1.90 g (RJ-13P)
4.50 g (RJ-13B)
2.15 g (RJ-13PR)
2.50 g (RJ-13S)
2.78 g (RJ-13SR)
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Thermal shock
Humidity
Shock
Test conditions
Specifications
−65 ~ 125 °C
(0.5 h), 5 cycles
−10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.75 W, 1000 h
Low temp. operation
−55 °C, 2 h
High temp. exposure
120 °C, 250 h
Immersion seal
85 °C, 60 s
Flow
Soldering heat
[ΔR/R ≦ 1 %]
[ΔR/R ≦ 1 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 1 %]
[ΔR/R ≦ 1 %]
[S.S. ≦ 2 %]
[ΔR/R ≦ 2 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
260 ± 3 °C, 5 ~ 6 s, two times maximum
[ΔR/R ≦ 1 %]
Manual soldering
380 ± 10 °C, 3 ~ 4 s
ΔR/R:Change in total resistance
S.S. :Setting stability
RJ-13
CERMET TRIMMERS
■ MAXIMUM INPUT RATINGS
Nominal resistance valus ( Ω )
Resistance code
10
100
200
500
Maximum input voltage (V)
Maximum wiper current (mA)
100 1.00 100
200 2.00 100
500 5.00 100
101
8.66
86.6
201
12.2
61.0
501
19.4
38.8
1 k
102
27.4
27.4
2 k
202
38.7
19.3
5 k
502
61.2
12.2
10 k
103
86.6
8.66
20 k
203
122
6.10
25 k
253
137
5.48
50 k 503 194 3.88
100 k
200 k
250 k
500 k
1 M
2 M
5 M
104
204
254
504
105
205
505
RJ-13P 外形図
274
300
300
300
300
300
300
2.74
1.50
1.20
0.60
0.30
0.15
0.06
■ OUTLINE DIMENSIONS
● RJ-13P
Top adjustment
The products indicated by → mark are
manufactured upon
receipt of order
basis.
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
Resistance code
①
3 –Φ0.7±0.05
270˚ Nom.
③
CW rotation
2
RJ-13B 外形図
● RJ-13B
Panel mount
2.5
Φ 12.4 +– 0.4
0.1
②
1
3
Production date code
6.3
0.7 W × 5 L × 1 D
M5 (P = 0.8 L = 6 min.)
Nut M5, t = 3.2
Washer t = 1
Φ 14 max.
7.5±2
2.5
2.5
Resistance code & Production date code
2
3 –Φ 0.7±0.05
Red paint
2.5
Φ9
Φ3
RJ-13PR 外形図
0.6
3
1
90˚
7
7.5±0.5
7±2
1
2.5
2.5
Mechanical stops
Resistance code
3 – Φ 0.7±0.05
Straight knurl
2
2.5
+0.4
Φ 12.4 –0.1
270˚ Nom.
Φ 4.90.2
● RJ-13PR
Top adjustment
with knob
ストッパ位置
1
3
0.7 W × 3.8 L × 1.1 D
7±0.5
6.3
17±2
2.5
2.5
Shaft details
RJ-13
CERMET TRIMMERS
■ OUTLINE
RJ-13S
外形図 DIMENSIONS
● RJ-13S
Side adjustment
①
③
CW rotation
②
0.7 W × 5 L × 1 D
Resistance code
Adjustment
3
8.8
2
2.5
7.5±2
J-13SR 外形図
1.2
7.3
+0.4
13.6–0.1
2.5
1
+0.4
–0.1
270˚ Nom.
2.5
12.5+0.4
–0.1
3 – Φ 0.7±0.05
● RJ-13SR
Φ 4.9±0.2
270˚ Nom.
Straight knurl
3
1.2
13.6+0.4
–0.1
2.5
1
2
2.5
7.5±2
7.3
7±0.5
Resistance code
8.8+0.4
–0.1
2.5
12.5+0.4
–0.1
3 –Φ 0.7±0.05
■PACKAGING SPECIFICATIONS
● Unit of bulk pack in a plastic bag is 25 pcs. per pack, only that RJ-13P is 50 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with 50 pcs. per box, only that RJ-13P is 100 pcs. per box.
很抱歉,暂时无法提供与“RJ13P204”相匹配的价格&库存,您可以联系我们找货
