2765
2765
    ADAFRUIT
    电位器(操纵杆) 10KΩ -
2765 数据手册
SENSORS / TOUCH / MINI 2-AXIS ANALOG THUMBSTICK PRODUCT ID: 2765 Description Sometimes a simple analog control device can be the perfect tactile solution for your project, but they can be surprisingly hard to come by. Luckily we've got a low cost, quality Mini 2-Axis Analog Thumbstick to fulfill your directional analog input needs! This is a small joystick with a black rocker cap, similar to the PSP joysticks. The joystick is a 'self-centering' analog-type. It is comprised of two 10KΩ potentiometers, one for up / down and another for left / right. You can solder the potentiometer pins onto a custom breakout board if you so choose. We also offer our own Analog Mini Thumbstick PCB which will pair great with this little guy. When fully assembled and functioning, the voltage will follow the motion of the thumbstick as it is moved around. When you release the thumbstick it will center itself. Great for robotics and other control interfaces! Note: Breakout PCB is not included. • Technical Details For a tutorial on how to read analog joysticks, check out this Arduino tutorial - it can easily be extended to any microcontroller! Product Dimensions: 17.5mm x 17.4mm x 12.0mm / 0.7" x 0.7" x 0.5 Product Weight: 2.1g / 0.1oz
很抱歉,暂时无法提供与“2765”相匹配的价格&库存,您可以联系我们找货
