54-24451
54-24451
    INTERLINKELECTRONICS
    电位器(操纵杆) - -
54-24451 数据手册
MicroJoystick Data Sheet MicroJoystick Features and Benefits Description • Intuitive control • Durable • Smooth cursor movement • Versatile • Low power usage • Customizable • Compact design The high-precision MicroJoystick is an innovative, intuitive, OEM pointing system that delivers simultaneous 360º control of direction and speed at the touch of a fingertip. It is based on Interlink Electronics’ patented pressure-sensitive Force Sensing Resistor® (FSR®) technology. The dynamic response for FSR® technology enables the lightest of touches to be translated into smooth, intuitive cursor control while simultaneously enabling dynamic speed control by altering the amount of applied pressure. The result is smooth cursor movement in any direction, from a precise crawl to a screen-crossing zip. Call us for more information 805-484-8855 P/N: PDS-10006-B Human-Machine Interface Solutions for a Connected World MicroJoystick Data Sheet MicroJoystick Device Characteristics Weight 2 grams or less Actuation Force Range 0.2N-1.7N, typical Deflection at Maximum Use Force 0.7mm from tip centerline for a 10mm stick Stick Strength Capacity Side load: 20kg, Compressive load: 100kg, Tensile load: 13kg Operating Temperature Performance Functional before, during, and after exposure to the below conditions: Cold Dry Hot Dry Hot Humid Storage Temperature Performance Cold Dry Hot Dry Hot Humid 0ºC
54-24451 价格&库存
很抱歉,暂时无法提供与“54-24451”相匹配的价格&库存,您可以联系我们找货
  • 1+801.735681+104.22305
  • 5+699.373305+90.91627
  • 10+659.3232710+85.70990
  • 25+609.7951325+79.27140
  • 50+574.7358150+74.71380
  • 100+541.62347100+70.40930
库存:114
