3102
3102
    ADAFRUIT
    电位器(操纵杆) 10KΩ ±10%
3102 数据手册
Mini Analog Joystick - 10K Potentiometers PRODUCT ID: 3102 Description Sometimes a simple analog control device can be the perfect tactile solution for your project, but they can be surprisingly hard to come by. Luckily we've found a low cost, quality Mini Analog Joystick to fill you directional analog input needs! Unlike most arcade-style joysticks which come with four clicking switches, this product has two 10KΩ potentiometers and a spring-back system. You can get a full 50 degrees in both X and Y directions. Connect one side of each potentiometer to ground, and the other side to a higher voltage and read the analog voltage off the middle. Great for robotics and other control interfaces. This joystick is durable and has a great feel to it. You could replace the springs if you want a stronger or weaker spring-back force. Technical Details Resistance Value: 10 Kohm Resistance Tolerance: ±10% Independent Linearity: ±1% Temperature Coefficient Resistance: ±400ppm/°C Output Smoothness: 0.5% max X and Y Axis range: ±25° Mechanical Lifecycle: 500,000 cycle Operating Temperature Range: -10~80°C Product Dimensions: 67.4mm x 52.7mm x 52.7mm / 2.7" x 2.1" x 2.1" Product Weight: 55.9g / 2.0oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3102”相匹配的价格&库存,您可以联系我们找货
