S10C011P
S10C011P
    APEM(埃斐)
    SW2_49.78X49.78MM
    电位器(操纵杆) POTENTIONMETER_49.78X49.78MM 5KΩ ±20%
S10C011P 数据手册
03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page9 S and SR series Washable rocker and paddle switches Distinctive features and specifications UG1410A ❑ Sealed • Secure assembly of the two case parts • Internally sealed bushing • Epoxy sealed terminals ❑ Process compatible (S series) • Wave solderable • Washable ❑ Optional ESD protection ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - silver contacts (A or 1) : 4A 30VDC - brass, gold plated contacts (CD or 0) : 0,4VA 20VAC or DC - silver, gold plated contacts (AD or 2) : 4A 30VDC (300mA 30VDC for gold plating) • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. • Dielectric strength : 1.000 Vrms 50 Hz min. • Electrical life with nominal load : Contacts A or 1 CD or 0 AD or 2 • Case and cover : UL94-V0, polyamide, glass filled or PES • Actuator : polyamide • Contacts CD or 0 : brass, gold plated A or 1 : silver AD or 2 : silver, gold plated • Terminal seal : epoxy Number of cycles 2 positions 3 positions 40.000 100.000 40.000 40.000 50.000 40.000 GENERAL SPECIFICATIONS AGENCY APPROVALS • Mechanical strength : Terminals are strengthened by a bracket or a ground plate ensuring the rigidity of the switch on the board. Actuator strength is 10N max. • Operating temperature : -20°C to +85°C • Storage temperature : -40°C to +85°C • Moisture : The insulating materials employed and the complete seal permit the switches to withstand a 56 days moisture test (IEC 68-2-3). • Soldering - thermal shock (S series only) : The switches are especially designed for flow soldering at 260°C during 5 seconds owing to high temperature polymer parts. • Iron soldering (SR series) : 300°C 5 sec. max. • Solderability : The switches are tested at 235°C according to IEC 68-2-20 after accelerated aging. 2A 250VAC 4A 125VAC Availability : consult factory for details of approved models. Marking : to order switches marked UL, complete appropriate box of ordering format. The company reserves the right to change specifications without notice. APEM www.apem.com D-9 D 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page10 S series Washable rocker and paddle switches Overview S Terminals SERIES W WW Y D Right angle, horizontal mounting Right angle, vertical mounting Bracket mounting CD Silver Silver, gold plated Brass, gold plated 2 0 Terminal spacing 4,7 (.185) or 3,81 (.150) Terminal spacing 5,08 (.200) (SW switches) Special options / insulated models Lever Contact materials A AD Bushing and terminals -6 For rocker and paddle. Blank No special requirement X653 Vertical right angle with stand-off plate X1159 Insulated models Number of poles 3 4 Single pole Double pole Approvals UL Availability : Consult factory for details of approved models. Electrical functions 6 9 7 8 2 4TH ON ON MOM ON ON ON OFF OFF OFF ON ON ON MOM MOM MOM ON Actuators Rockers U620 U730 Large Small Paddles U610 U700 Narrow Broad See following pages. Bezels For SK models U1200 U1210 For LED ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as above Specifications are on previous page. For SW, SWW and SY models U4602 Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Packaging unit : 25 pieces to 50 pieces depending on models. D-10 www.apem.com APEM 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page11 S series Washable rocker and paddle switches 1 2 4.15 (.163) • Straight PC or right angle terminals • Models with snap-in mounting (SK) • Terminal spacing 4,7 (.185) or 5,08 (.200) on SW switches • 1 and 2 pole configurations 3 1.10 (.043) MODEL STRUCTURE Shown with rocker U620 12.70 (.500) EPOXY 8.40 (.330) 5.10 (.200) 0.50 (.019) 3 2 1 0.80 (.031) 3.90 (.153) 11.65 (.458) 4.70 (.185) 12.70 (.500) 5.08 (.200) Ø1.60 (.062 DIA) 4.70 (.185) 12.70 (.500) (.125) 3.20 Ø1.60 (.062 DIA) 3.81 (.150) ON OFF ON OFF MOM OFF MOM - MOM ON ON 5.08 (.200) 9.30 (.366) 12.70 (.500) ON ON MOM ON ON ON III 3.81 (.150) SW246-6 SW249-6 SW247-6 SW248-6 SW242-6 SW244TH-6* II 24˚ 4.50 8.75 (.177) (.344) SW236-6 SW239-6 SW237-6 SW238-6 SW232-6 12.70 (.500) Double pole I I 1.10 (.043) Single pole II 0.40 (.015) III 2.40 (.094) 6.00 (.236) Right angle terminals - horizontal - spacing 4,7 (.185) Single pole with stand-off plate, double pole without. 6.60 (.259) EPOXY 2 3 6.65 (.261) 3.10 (.122) 4.75 (.187) 13.00 (.511) Ø1.60 (.062 DIA) 11.35 (.446) ** Functions 2 and 8 : reversed connection available. Consult factory. III Double pole SY236-6 SY239-6 SY237-6 SY238-6 SY232-6 SY246-6 SY249-6 SY247-6 SY248-6 SY242-6 SY244TH-6* ON ON MOM ON ON ON I ON OFF ON OFF MOM OFF MOM - MOM ON ON 8.20 (.322) EPOXY 0.80 0.90 (.031) (.035) * Function 4 : SP in DP case - TH connection, see end of catalogue. APEM www.apem.com 4.70 (.185) 1 2 3 0.50 (.019) 15.75 (.620) 0.40 (.015) 12.70 (.500) 3.18 (.125) I 15.75 (.620) Single pole II 4.40 (.173) III II 24˚ 11.70 4.30 8.75 (.460) (.169) (.344) 9.30 (.366) 6.00 (.236) Bracket mounting 4.75 (.187) 3.81 (.150) 5.08 (.200) 12.70 (.500) 6.00 (.236) 1 3.81 (.150) 1.10 (.043) Ø1.60 (.062 DIA) Ø1.60 (.062 DIA) 3.18 (.125) 11.35 (.446) 4.70 (.185) ON OFF ON OFF MOM OFF MOM - MOM ON ON 24˚ 3.18 (.125) 4.70 (.185) ON ON MOM ON ON ON 5.08 (.200) I 15.75 (.620) SWW246-6 SWW249-6 SWW247-6 SWW248-6** SWW242-6** SWW244TH-6* 0.40 (.177) SWW236-6 SWW239-6 SWW237-6 SWW238-6 SWW232-6 0.50 (.019) Double pole I II 80 ) 0. 31 (.0 Single pole II 9.30 (.366) 12.70 4.50 8.75 (.500) (.177) (.344) III III 3.81 (.150) Right angle terminals - vertical 4.75 (.187) D-11 D 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page12 S series Washable rocker and paddle switches 8.40 (.330) 3.20 (.125) 3 0.60 (.023) 2 1 0.60 (.023) 3.90 (.153) 5.08 (.200) 11.65 (.458) 5.08 (.200) Single pole with stand-off plate, double pole without. ON OFF ON OFF MOM OFF MOM - MOM ON ON 1.10 (.043) 0.80 (.031) 4.70 (.185) 12.70 (.500) 2.00 (.078) 11.30 (.444) 1 2 3 0.50 (.019) 2.50 Maxi (.098 MAX) ON ON MOM ON ON ON I EPOXY 4.75 (.187) Ø1.60 (.063 DIA) SK246-6 SK249-6 SK247-6 SK248-6 SK242-6 SK244TH-6* III II 24˚ Shown with rocker U730 and bezel U1200 16.60 (.653) SK236-6 SK239-6 SK237-6 SK238-6 SK232-6 4.15 (.163) Double pole 15.70 (.618) I Ø1.60 (.063 DIA) D Single pole II 4.70 (.185) III 19.50 (.767) 6.50 (.255) Straight PC terminals - snap-in mounting Ø1.10 (.043 DIA) 3.81 (.150) EPOXY 5.10 (.200) 5.08 (.200) 12.70 (.500) 12.70 (.500) 12.70 (.500) ON OFF ON OFF MOM OFF MOM - MOM ON ON 0.60 (.023) ON ON MOM ON ON ON Ø1.10 (.043 DIA) 4.70 (.185) SW046-6 SW049-6 SW047-6 SW048-6 SW042-6 SW044TH-6* 5.08 (.200) 9.30 (.366) 12.70 (.500) SW036-6 SW039-6 SW037-6 SW038-6 SW032-6 III 3.81 (.150) Double pole II 24˚ I 0.40 (.015) Single pole II I 4.50 8.75 (.177) (.344) III 2.40 (.094) 6.00 (.236) Right angle terminals - horizontal - spacing 5,08 (.200) * Function 4 : SP in DP case - TH connection, see end of catalogue. PANEL CUT-OUT 17.00 With rocker U730 or paddle U700 D-12 For SK only 17.00 (.669) 10.00 (.393) 15.00 (.590) 15.00 (.590) 12.50 (.492) 12.00 11.70 (.460) 12.00 (.472) With rocker U620 or paddle U610 www.apem.com APEM 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page13 S series Washable rocker and paddle switches CONTACT MATERIALS -6 A AD CD Silver Silver, gold plated Brass, gold plated SPECIAL OPTIONS / INSULATED MODELS -6 X653 Vertical right angle with stand-off plate Shown with rocker U620 I 1.10 (.043) 6.60 (.259) 1 EPOXY 2 3 3.30 (.129) 5.08 (.200) 9.15 (.360) 15.50 (.610) 4.75 (.187) Ø1.60 (.062 DIA) 11.35 (.446) 4.75 (.187) 12.70 (.500) Ø1.60 (.062 DIA) 3.81 (.150) 1.27 (.050) ON OFF ON OFF MOM OFF MOM - MOM ON ON 24˚ 5.08 (.200) I 80 ) 0. 31 (.0 ON ON MOM ON ON ON 0.50 (.019) Double pole SWW246-6 X653 SWW249-6 X653 SWW247-6 X653 SWW248-6 X653** SWW242-6 X653** SWW244TH-6 X653* II 6.15 8.75 (.242) (.344) 12.70 (.500) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 3.81 (.150) SWW236-6 X653 SWW239-6 X653 SWW237-6 X653 SWW238-6 X653 SWW232-6 X653 III 9.30 (.366) 12.70 (.500) Single pole 3.81 (.150) II 6.00 (.236) III * Function 4 : SP in DP case - TH connection, see end of catalogue. ** Functions 2 and 8 : reversed connection available. Consult factory. X601 APEM Silver plated brass contacts Current/voltage rating for an electrical life of 20.000 cycles : 0,5A 30VDC Minimum quantity : 5.000 per type and shipment. www.apem.com D-13 D 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page14 S series Washable rocker and paddle switches SPECIAL OPTIONS / INSULATED MODELS (continued) -6 Insulated model protected against E.S.D. up to 12 KV - Horizontal right angle ø1.60 (.062 DIA) 3 2 1 0.80 (.031) 0.50 (.019) 8.40 (.330) 3.90 (.153) 4.70 (.185) 11.65 (.458) ø1.60 (.062 DIA) 4.70 (.185) 3.81 (.150) EPOXY 5.10 (.200) 5.08 (.200) 12.70 (.500) 12.70 (.500) 3.20 (.125) 5.08 (.200) 9.30 (.366) 4.80 8.70 (.189) (.343) 0.40 (.015) ON OFF ON OFF MOM OFF MOM - MOM ON ON III 24° 3.81 (.150) ON ON MOM ON ON ON II 12.70 (.500) I 12.70 (.500) 3.00 (.118) 6.00 (.236) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM Insulated model protected against E.S.D. up to 12 KV - Vertical right angle Shown with rocker U620 6.60 (.259) ø1.60 (.062 DIA) 5.08 (.200) 12.70 (.500) 24° 1 3 6.65 (.261) 3.10 (.122) ø1.60 (.062 DIA) 4.75 (.187) 12.70 (.500) EPOXY 2 1.10 (.043) 5.08 (.200) I 11.35 (.446) 13.00 (.511) 4.75 (.187) 3.81 (.150) ON OFF ON OFF MOM OFF MOM - MOM ON ON II 6.00 (.236) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM ON ON MOM ON ON ON III 9.30 (.366) 3.81 (.150) I 0.40 (.016) II 80 ) 0. 31 (.0 Double pole SWW246-6 X1159 SWW249-6 X1159 SWW247-6 X1159 SWW248-6 X1159** SWW242-6 X1159** SWW244TH-6 X1159* III 0.50 (.019) Single pole SWW236-6 X1159 SWW239-6 X1159 SWW237-6 X1159 SWW238-6 X1159 SWW232-6 X1159 12.70 4.80 8.70 (.500) (.189) (.343) D Insulated model protected against E.S.D. up to 12 KV - Straight PC terminals - bracket mounting ON OFF ON OFF MOM OFF MOM - MOM ON ON EPOXY 0.80 0.90 (.031) (.035) 8.20 (.322) II I 24° 3.18 (.125) 9.30 (.366) ø1.60 (.062 DIA) 1 2 3 0.50 (.019) 4.70 (.185) 15.75 (.620) 0.40 (.015) 4.70 (.185) III 3.18 (.125) 3.18 (.125) 11.35 (.446) 4.70 (.185) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM ON ON MOM ON ON ON Shown with rocker U620 I 15.75 (.620) II 15.75 (.620) Double pole SY246-6 X1159 SY249-6 X1159 SY247-6 X1159 SY248-6 X1159** SY242-6 X1159** SY244TH-6 X1159* III 6.00 (.236) Single pole SY236-6 X1159 SY239-6 X1159 SY237-6 X1159 SY238-6 X1159 SY232-6 X1159 11.70 4.60 8.70 (.460) (.181) (.343) X1159 Shown with rocker U620 I 3.81 (.150) X1159 II 12.70 (.500) Double pole SW246-6 X1159 SW249-6 X1159 SW247-6 X1159 SW248-6 X1159 SW242-6 X1159 SW244TH-6 X1159* III 1.10 (.043) Single pole SW236-6 X1159 SW239-6 X1159 SW237-6 X1159 SW238-6 X1159 SW232-6 X1159 4.40 (.173) X1159 4.75 (.187) * Function 4 : SP in DP case - TH connection, see end of catalogue. ** Functions 2 and 8 : reversed connection available. Consult factory. Above models available with all actuators shown on next page. D-14 www.apem.com APEM 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page15 S series Washable rocker and paddle switches AGENCY APPROVAL -6 UL Availability : consult factory for details of approved models. Marking : to order switches marked with the UL symbol, complete above box with "UL". Blank : no agency approval required. ACTUATORS + U... -6 7.60 (.299) Broad paddle Small rocker U610 and U620 not available on SK models 13.20 (.519) 12.10 (.476) 5.00 (.196) 2.00 (.078) Ø7.10 (.279 DIA) 12.10 (.476) 12.10 (.476) Bezel for SW - SWW and SY models 15.70 (.618) 12.10 (.476) 15.70 (.618) 19.50 (.767) 2.00 (.078) Bezels for SK model (snap-in) Add bezel part number to actuator part number. Ø5.00 (.196 DIA) 28.00 (1.102) U1200 U1210 Bezel Bezel for LED Ø 5 (.196) - not supplied APEM 12.40 (.488) www.apem.com 20.10 (.791) U4602 1.27 (.050) U730 11.70 (.460) 17.00 (.669) 15.60 (.614) U700 9.05 (.356) 2.00 (.079) 5 R:5.7 R.) (.226 9.00 (.354) 16.50 (.649) 18.40 (.724) 5.37 (.211) 11.30 (.444) 2.50 (.098) 7.90 (.311) 11.20 (.440) D blue dark blue black green grey yellow red ivory white orange 10.00 (.394) U620 Large rocker 1 1/4 2 3 4 5 6 7 7/1 9 4.80 (.189) U610 Narrow paddle Replace last "0" by number 16.80 (.661) 7.10 (.279) .43 R:8 1 R.) 3 (.3 Actuator colours 13.50 (.531) 9.30 (.366) 9.50 (.374) 20.70 (.814) 3.96 (.155) 2.13 (.083) 7.87 ) (.309 18.80 (.740) 9.50 (.374) 25.00 (.984) Black bezel - for rocker U620 only D-15 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page16 SR series Washable rocker and paddle switches Overview SR Number of poles SERIES 3 4 Electrical functions Single pole Double pole 6 9 7 8 2 4 ON ON MOM ON ON ON OFF OFF OFF ON Terminals ON ON MOM MOM MOM ON S0 Solder lug D Mounting plate Contact materials 0 1 2 5 Brass, gold plated Silver Silver, gold plated Special contact : lower rating, minimum quantity : consult factory 00 01 Standard plate Standard plate + accessories Model 00 Standard Actuators 10 20 Rocker Paddle ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as above Specifications are at the beginning of this section (S and SR series). Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Packaging unit : 20 pieces. D-16 www.apem.com APEM 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page17 SR series Washable rocker and paddle switches Solder lug terminals 1 2 1.90 (.070) 3 1.10 (.043) 1.90 (.074) 2.45 (.096) • 1 and 2 pole configurations • Iron soldering 300°C max. 5 seconds max. MODEL STRUCTURE Shown with standard mounting plate (code 00) Solder lug terminals I III ON ON MOM ON ON ON ON OFF ON OFF MOM OFF MOM - MOM ON ON 6.60 (.259) 1.80 (.070) EPOXY 12.70 (.500) 0.80 (.031) 15.00 (.590) I 10.70 (.421) SR46S0 SR49S0 SR47S0 SR48S0 SR42S0 SR44S0* 0.40 (.015) SR36S0 SR39S0 SR37S0 SR38S0 SR32S0 II 24˚ 15.10 (.594) Single pole Double pole 35.00 (1.377) 26.60 (1.047 ) 1 2 3 0.50 (.019) 4.70 (.185) 10.80 (.425) II 2.45 (.096) III 11.35 (.446) 4.75 (.187) * Function 4 : SP in DP case - TH connection, see end of catalogue. PANEL CUT-OUT 27.50 (1.082) 15.50 (.610) Ø2.70 (.106 DIA) 35.00 (1.377) APEM www.apem.com D-17 D 03-Serie S-SR-A-R1_03-Série S-SR-A 05/11/14 14:57 Page18 SR series Washable rocker and paddle switches CONTACT MATERIALS Brass, gold plated Silver Silver, gold plated Special contact, lower rating, minimum quantity : consult factory. 0 1 2 5 01 Standard mounting plate + mounting accessories (spacers, screws and nuts) M2.5x0.45 (.098 DIA x0.45 IS) 6.00 (.236) Standard mounting plate ACTUATORS Actuator colours 00 10 20 Rocker Paddle D-18 29.80 (1.173) 9.30 ) (.366 26.60 (1.047) 31.80 (1.251) 14.00 (.551) 15.00 (.590) www.apem.com 2.50 (.098) 23.00 (.905) 22.55 (.887) 10.00 (.393) 15.00 (.590) 12.10 (.476) D 00 12.00 (.472) MOUNTING PLATE 5.00 (.196) Replace "0" by number 1 1/4 2 3 4 5 6 7 7/1 9 blue dark blue black green grey yellow red ivory white orange APEM Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: SR47S00000014 S30L081P S30L081P50 S10C011P
S10C011P 价格&库存
很抱歉,暂时无法提供与“S10C011P”相匹配的价格&库存,您可以联系我们找货
