MIL Style RV8
PRECISION
Precision Series SPR - 1/2 Watt 1/8" shaft diameter
Precision series SPR/RV8 potentiometers are for PCB
applications requiring a rugged potentiometer.
FEATURES:
hot molded carbon element
board washable
stainless steel shaft
compact size
quality meeting or exceeding MIL-R-94 - QPL listed
OPTIONS:
custom shafts and bushings
special tapers
customer specified marking
location tab position
ELECTRICAL SPECIFICATIONS:
MECHANICAL SPECIFICATIONS:
Resistance range, linear taper: 100 Ω to 5 Meg Ω
Mechanical rotation: 295°
Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω
Operating torque: 0.5 oz/in to 6 oz/in
Resistance tolerance: ±10% or ±20%
Rotational life: 25,000 cycles
Resistance taper: linear, logarithmic, reverse logarithmic;
other tapers by special order
Power rating: 0.5 watts at 70°C derated to 0 watts at 120°C
Insulation resistance:
dry: 10K Meg Ω
wet: 100K Meg Ω
Dielectric strength: 750 V RMS at sea level
Operating voltage: 350 V, subject to power rating
ENVIRONMENTAL SPECIFICATIONS:
Operating temperature: − 65°C to +125°C
Resistance to soldering heat: 350°C for 5 seconds
Humidity range: per MIL-R-94
Vibration range: per MIL-R-94
Shock resistance: per MIL-R-94
Load life: 1000 hours at 70°C
PRECISION
DRAWING:
MIL Style RV8
MIL Style RV8
PRECISION
ORDERING INFORMATION:
Ordering Information - Commercial Part Numbers
Series
SPR = series SPR
Bushing
Bushing
Length
Blank =
Blank = 1/4"
standard
6 = 3/8"
L = locking
W = panel &
shaft seal
Taper
U = linear
A=
logarithmic
B = reverse
logarithmic
Resistance Value
Total resistance value in
Ω: first 2 digits significant,
third digit = number of
zeroes
Tolerance Shaft Style
1 = 10% of R = round
nominal
S = slotted
2 = 20% of F = flatted
nominal
Shaft
Length
16 = 1/2"
20 = 5/8"
24 = 3/4"
28 = 7/8"
32 = 1"
Example: SPRU2521R20
note: not all part number combinations are valid
Ordering Information - Military Part Numbers
Style
Bushing
N = standard
RV8 = MIL style RV8
Switch
A = without
L = locking
Temperature & Moisture
Characteristics
Y = as per MIL-R-94
switch
S = panel &
shaft seal
Shaft Style
Shaft
Length
Resistance Value
Taper & Tolerance
S = slotted
L = 3/8"
A = linear 10%
F = flatted
B = 1/2"
in Ω: first 2 digits
B = linear 20%
A = 5/8"
D = 7/8"
significant, third digit =
C = logarithmic 10%
number of zeroes
D = logarithmic 20%
E = reverse logarithmic
10%
F = reverse logarithmic
20%
Example: RV8NAYSD252A
Series SPR Cross Reference
Precision
Military
Clarostat
Allen Bradley
SPR
RV8NAY
392
W or G
SPRL
RV8LAY
392
很抱歉,暂时无法提供与“SPRU1031S28”相匹配的价格&库存,您可以联系我们找货
