MIL Style RV6
PRECISION
Precision Series S -
1/2" Watt 1/8" shaft diameter
Precision series S/RV6 potentiometers are ideal for
applications requiring high reliability and a compact size.
FEATURES:
hot molded carbon element
one piece housing and bushing
stainless-steel shaft
compact size
quality meeting or exceeding MIL-R-94 - QPL listed
OPTIONS:
• custom shafts and bushings
• special tapers
• customer specified marking
ELECTRICAL SPECIFICATIONS:
MECHANICAL SPECIFICATIONS:
Resistance range, linear taper: 100 Ω to 5 Meg Ω
Mechanical rotation: 295°
Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω
Operating torque: 0.5 oz/in to 6 oz/in
Resistance tolerance: ±10% or ±20%
Rotational life: 25,000 cycles
Resistance taper: linear, logarithmic, reverse logarithmic;
other tapers by special order
Power rating: 0.5 watts at 70°C derated to 0 watts at 120°C
Insulation resistance:
dry: 10K Meg Ω
wet: 100K Meg Ω
Dielectric strength: 750 V RMS at sea level
Operating voltage: 350 V, subject to power rating
ENVIRONMENTAL SPECIFICATIONS:
Operating temperature: − 65°C to +125°C
Resistance to soldering heat: 350°C for 5 seconds
Humidity range: per MIL-R-94
Vibration range: per MIL-R-94
Shock resistance: per MIL-R-94
Load life: 1000 hours at 70°C
PRECISION
DRAWING:
MIL Style RV6
MIL Style RV6
PRECISION
ORDERING INFORMATION:
Ordering Information - Commercial Part Numbers
Series
S = series S
Bushing
Blank =
standard
L = locking
Bushing
Length
Taper
Blank = 1/4" U = linear
6 = 3/8"
W = panel &
shaft steel
A=
logarithmic
B = reverse
logarithmic
Tolerance Shaft Style
Resistance Value
Total resistance value in 1 = 10% of R = round S
Ω: first 2 digits significant, nominal
= slotted F =
third digit =
flatted
number of zeroes
2 = 20% of
nominal
Shaft
Length
16 = 1/2" 20
= 5/8" 24 =
3/4"
28 = 7/8" 32
= 1"
36 = 1 1/8"
Example: SLA1021S20
note: not all part number combinations are valid
Ordering Information - Military Part Numbers
Style
Bushing
N = standard
RV6 = MIL style RV6
Switch
A = without
L = locking
Temperature & Moisture
Characteristics
Y = as per MIL-R-94
switch
S = panel &
shaft seal
Shaft
Length
Shaft Style
Resistance Value
Taper & Tolerance
S = slotted
L = 3/8"
A = linear 10%
F = flatted
B = 1/2"
in Ω: first 2 digits
B = linear 20%
A = 5/8"
D = 7/8"
significant, third digit =
C = logarithmic 10%
number of zeroes
D = logarithmic 20%
E = reverse logarithmic
10%
F = reverse logarithmic
20%
Example: RV6LAYSA102C
Series S Cross Reference
Precision
Military
Clarostat
Allen Bradley
Ohmite
SU S28
RV6NAYSD A
392M / 382C3
WA2G056S UA
ASM
SU S12
RV6NAYSL A
392M / 382C4
WA2G024S UA
N/A
SLU S20
RV6LAYSA A
392M / 382C2
WA2L040S UC
AS
SLU S28
RV6LAYSD A
393M / 382C5
WA2L056S UC
N/A
很抱歉,暂时无法提供与“RV6NAYSD502A”相匹配的价格&库存,您可以联系我们找货
