MIL Style 2RV7
PRECISION
Precision Series KK - 2 Watt multiple element 1/4" shaft diameter
Precision series KK/2RV7 potentiometers are suitable for
both military and commercial applications requiring
multiple elements. They can easily be customized to
meet special requirements.
FEATURES:
hot molded carbon element
gold-plated terminals
stainless-steel shaft and housing
quality meeting or exceeding MIL-R-94 - QPL listed
OPTIONS:
custom shafts and bushings
special tapers
fourth (center) terminal
concentric shafts
attached switches
ELECTRICAL SPECIFICATIONS:
MECHANICAL SPECIFICATIONS:
Resistance range, linear taper: 50 Ω to 5 Meg Ω
Mechanical rotation: 314°
Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω
Operating torque: 1 oz/in to 12 oz/in
Resistance tolerance: ±10% or ±20%
Rotational life: 25,000 cycles
Resistance taper: linear, logarithmic, reverse logarithmic;
other tapers by special order
Power rating: 2 watts at 70°C derated to 0 watts at 120°C
Insulation resistance:
dry: 10K Meg Ω
wet: 100K Meg Ω
Dielectric strength: 900 V RMS at sea level
Operating voltage: 500 V, subject to power rating
ENVIRONMENTAL SPECIFICATIONS:
Operating temperature: − 65°C to +125°C
Resistance to soldering heat: 350°C for 5 seconds
Humidity range: per MIL-R-94
Vibration range: per MIL-R-94
Shock resistance: per MIL-R-94
Load life: 1000 hours at 70°C
PRECISION
DRAWING:
MIL Style 2RV7
MIL Style 2RV7
PRECISION
ORDERING INFORMATION:
Ordering Information - Commercial Part Numbers
Series
KK = series KK dual element
Bushing
Blank =
standard
Switch
Blank =
without
switch
Taper
U = linear
KKK = series KKK triple element
L = locking
S = SPST
switch
A=
logarithmic
B = reverse
logarithmic
W = panel &
shaft steel
Tolerance Shaft Style
Resistance Value
Total resistance value in 1 = 10% of R = round S
Ω: first 2 digits significant, nominal
= slotted F =
third digit =
flatted
number of zeroes
2 = 20% of
nominal
Shaft
Length
16 = 1/2" 20
= 5/8" 24 =
3/4"
28 = 7/8" 32
= 1"
40 = 1 1/4"
48 = 1 1/2"
64 = 2"
80 = 2 1/2"
96 = 3"
Example: KKU1041S28
note: not all part number combinations are valid
Ordering Information - Military Part Numbers
Style
2RV7 = MIL style
2RV7
Bushing
N = standard
L = locking
Temperature & Moisture
Characteristics
Y = as per MIL-R-94
S = panel & shaft steel
Shaft Style
Shaft
Length
Resistance Value
Taper & Tolerance
S = slotted
B = 1/2"
A = linear 10%
F = flatted
A = 5/8"
in Ω: first 2 digits
B = linear 20%
D = 7/8"
G = 1 1/4"
significant, third digit =
C = logarithmic 10%
number of zeroes
D = logarithmic 20%
J = 2"
E = reverse logarithmic
K = 2 1/2"
10%
F = reverse logarithmic
20%
Example: RV4NAYSB000A
很抱歉,暂时无法提供与“KKU5021S28”相匹配的价格&库存,您可以联系我们找货
