RV6NAYSD101A
RV6NAYSD101A
    PRECISIONELECTRONICSCORPORATION
    可调电阻/电位器 100Ω ±10% 500mW
RV6NAYSD101A 数据手册
MIL Style RV6 PRECISION Precision Series S - 1/2" Watt 1/8" shaft diameter Precision series S/RV6 potentiometers are ideal for applications requiring high reliability and a compact size. FEATURES: • • • • • hot molded carbon element one piece housing and bushing stainless-steel shaft compact size quality meeting or exceeding MIL-R-94 - QPL listed OPTIONS: • custom shafts and bushings • special tapers • customer specified marking ELECTRICAL SPECIFICATIONS: MECHANICAL SPECIFICATIONS: Resistance range, linear taper: 100 Ω to 5 Meg Ω Mechanical rotation: 295° Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω Operating torque: 0.5 oz/in to 6 oz/in Resistance tolerance: ±10% or ±20% Rotational life: 25,000 cycles Resistance taper: linear, logarithmic, reverse logarithmic; other tapers by special order Power rating: 0.5 watts at 70°C derated to 0 watts at 120°C Insulation resistance: dry: 10K Meg Ω wet: 100K Meg Ω Dielectric strength: 750 V RMS at sea level Operating voltage: 350 V, subject to power rating ENVIRONMENTAL SPECIFICATIONS: Operating temperature: − 65°C to +125°C Resistance to soldering heat: 350°C for 5 seconds Humidity range: per MIL-R-94 Vibration range: per MIL-R-94 Shock resistance: per MIL-R-94 Load life: 1000 hours at 70°C PRECISION DRAWING: MIL Style RV6 MIL Style RV6 PRECISION ORDERING INFORMATION: Ordering Information - Commercial Part Numbers Series S = series S Bushing Blank = standard L = locking Bushing Length Taper Blank = 1/4" U = linear 6 = 3/8" W = panel & shaft steel A= logarithmic B = reverse logarithmic Tolerance Shaft Style Resistance Value Total resistance value in 1 = 10% of R = round S Ω: first 2 digits significant, nominal = slotted F = third digit = flatted number of zeroes 2 = 20% of nominal Shaft Length 16 = 1/2" 20 = 5/8" 24 = 3/4" 28 = 7/8" 32 = 1" 36 = 1 1/8" Example: SLA1021S20 note: not all part number combinations are valid Ordering Information - Military Part Numbers Style Bushing N = standard RV6 = MIL style RV6 Switch A = without L = locking Temperature & Moisture Characteristics Y = as per MIL-R-94 switch S = panel & shaft seal Shaft Length Shaft Style Resistance Value Taper & Tolerance S = slotted L = 3/8" Total resistance value A = linear 10% F = flatted B = 1/2" in Ω: first 2 digits B = linear 20% A = 5/8" D = 7/8" significant, third digit = C = logarithmic 10% number of zeroes D = logarithmic 20% E = reverse logarithmic 10% F = reverse logarithmic 20% Example: RV6LAYSA102C note: not all part number combinations are valid Series S Cross Reference Precision Military Clarostat Allen Bradley Ohmite SU S28 RV6NAYSD A 392M / 382C3 WA2G056S UA ASM SU S12 RV6NAYSL A 392M / 382C4 WA2G024S UA N/A SLU S20 RV6LAYSA A 392M / 382C2 WA2L040S UC AS SLU S28 RV6LAYSD A 393M / 382C5 WA2L056S UC N/A
RV6NAYSD101A 价格&库存
很抱歉,暂时无法提供与“RV6NAYSD101A”相匹配的价格&库存,您可以联系我们找货
RV6NAYSD101A
  • 1+294.184551+38.06063
  • 10+244.1068010+31.58173
  • 25+226.4801425+29.30125
  • 50+213.9546050+27.68074
  • 200+190.87326200+24.69456
  • 400+180.26282400+23.32181
库存:232
