RV6LAYSA252A
RV6LAYSA252A
    PRECISIONELECTRONICSCORPORATION
    可调电阻/电位器 2.5KΩ ±10% 500mW
RV6LAYSA252A 数据手册
PART NUMBER 4 2 3 REVISION HISTORY SEE SHEET-2 TABLE D .656 MAX [ 16.66 ] .484 .016 [ 12.29 0.41 ] 2 CENTER (C) .062 .005 [ 1.57 0.13 ] C D REV DOCUMENT DESCRIPTION CHG'D BY DATE APPROVED A 0112190 RELEASED B.M. 2014-08-05 M. MIKE SHOWN WITH SHAFT AT 50% ROTATION [ # 0.79] D 2 [ # 0.41] .025 MAX [ 0.64 ] (3X .088 ) [ 2.24 ] TYP 1 A .515 .016 [ 13.08 0.41 ] +.010 -.000 [+0.25] [-0.00] B ( .080 2 [ 2.03 ] [ # 0.13] SLOTTED ) TYP .125 .001 [ 3.18 0.02 ] .200 .005 [ 5.08 0.13 ] 3 RIGHT (R) 45 $ 1 LEFT (L) .200 .005 [ 5.08 0.13 ] C 1/4-32 NEF-2A 1 .234 MAX MARKING SURFACE DATE CODE YY IS LAST 2 DIGITS OF YEAR WW IS WEEK NUMBER 1 B 2 LOCATING PIN #1 X .012 [0.3] ( 90 $ ) MOUNTING SURFACE R .040 .002 2 [ 1.02 0.05 ] (FROM n .515) 2 PLS LOCATING PIN #2 2X .031 .016 [ 0.79 0.41 ] OUTSIDE OF LOCATING PINS MAY BE FLAT GENERAL SPECIFICATIONS AND NOTES: SERIES: 392 CONDUCTIVE PLASTIC ELEMENT SUPPLIED WITH MOUNTING NUT, LOCKING WASHER AND JAM NUT. NUTS AND WASHER PACKAGED ASSEMBLED OR UNASSEMBLED BASED ON LISTING (REFER TO TABLE ON SHEET2). MARKING INFORMATION SHOWN ON SIDE OF HOUSING. REFER TO TABLE FOR SPECIFIC LISTING MARKING INFORMATION. WEIGHT OF SINGLE CONTROL: .25 OUNCE [6.8 GRAMS] APPROX. VALUES ARE SHOWN IN STANDARD AND METRIC UNITS. METRIC UNITS ARE IN [ ]. IF CONVERSION DIFFERENCE EXISTS, THE STANDARD UNIT PREVAILS. CONTROLS HAVE AN INTERNAL O-RING SHAFT SEAL. UNITS ARE SEALED FOR WAVE SOLDER AND WASH PROCESSING. BUILT IN ACCORDANCE WITH MIL-R-94. DIMENSIONS FOR BODY DIAMETER AND LOCATING PINS DEVIATE FROM MIL-R-94 45 $ 1/2 $ JAM NUT MOUNTING NUT 3 LOCKING WASHER EPOXY SEALANT SPECIFICATIONS. A TAPER: LINEAR TAPER TOLERANCE # 20% OF NOMINAL RESISTANCE AT 50% # 3% MECHANICAL ROTATION. LINEARITY (INDEPENDENT): # 5% MAX WORKING VOLTAGE: 350 VDC APPLIED ACROSS L & R TERMINALS. POWER NOT TO EXCEED RATING. DIELECTRIC STRENGTH: 750 VAC FOR 60s @ ATM [1 MPa] 350 VAC FOR 60s @ 3.4 IN Hg ([1.5 KPa] POWER RATING: 0.5W @ 158 $ F [70 $ C], DE-RATED LINEARLY TO 0@ 264 $ F [129 $ C] CRV FOR RESISTANCE GREATER THAN 500 ^ AND LESS THAN 50K ^ IS 1.5% OF TOTAL RESISTANCE. CRV FOR ALL OTHER RESISTANCE VALUES IS 3.1% OF TOTAL RESISTANCE. END RESISTANCE: 4 ^ MAX AT EACH END OF ROTATION RESISTANCE AND TOLERANCE: (REFER TO TABLE) ELECTRICAL ROTATION: 295 $ # 5 $ EFFECTIVE ELECTRICAL ROTATION: 265 $ TYPICAL MATERIALS SHAFT NICKEL PLATED BRASS HOUSING THERMOPLASTIC BUSHING NICKEL PLATED BRASS BASE THERMOSET TERMINALS C BRASS, SOLDER (TIN-LEAD) DIP FINISH SEALANT EPOXY LOCK WASHER NICKEL PLATED PHOS BRONZE MOUNTING NUT NICKEL PLATED BRASS JAM NUT CW NICKEL PLATED BRASS UNLESS OTHERWISE SPECIFIED THIRD ANGLE PROJECTION OPERATIONAL SPECIFICATIONS: DIMENSIONS ARE IN INCHES ROTATIONAL LIFE: 50,000 CYCLES STORAGE TEMPERATURE: -67 $ F [-55 $ C] TO 248 $ F [120 $ C] OPERATING TEMPERATURE: -40 $ F [-40 $ C] TO 248 $ F [120 $ C] . ROTATIONAL TORQUE: 0.5 TO 2.0 OZ-IN [3.5 TO 14 mN m] WITH JAM NUT TIGHTENED TO 8 LB-IN [0.9 Nm] SHAFT WILL NOT ROTATE UNTIL 20 LB-IN [2.3 Nm] IS APPLIED. . STOP TORQUE: 3 LB-IN [0.34 N m] MECHANICAL ROTATION: 295 $ # 5 $ 4 B SCALE 2:1 ( ISOMETRIC VIEW - REF ONLY ) ELECTRICAL SPECIFICATIONS: 3 C L SCHEMATIC R MATERIAL MULTI-SHEET DRAWING 3 DECIMAL TOL NO PLACE 1 PLACE 2 PLACE 3 PLACE ANGULAR TOL ----------- # # # # # .400 .030 .010 .005 2 $ [10.16] [0.76] [0.25] [0.13] CHAMFER - TITLE # 5 $ SEE TABLE FINISH APPLICABLE DOCUMENTS: ASME Y14.100-2004 ASME Y14.5-2009 2 COMPUTER GENERATED DRAWING: PRO/ENGINEER SIZE CAGE CODE SCALE 4:1 C - DWG NO 392-MATRIX-IDWG-13 REF WT: SEE NOTE RELEASE DATE 2014-08-05 DRW: B. MOHAPATRA 2014-05-28 RDE: M. MIKE 2014-05-28 QA: A S-TAPER, SLOTTED SHAFT, LCKG BUSHING, SOLDER HOOK TERMS - CHK: S. RAGHU 2014-08-05 1 SHEET TYPE I REV A 1 of 2 HONEYWELL CONFIDENTIAL THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION AND SUCH INFORMATION MAY NOT BE DISCLOSED TO OTHERS FOR ANY PURPOSE, NOR USED FOR MANUFACTURING PURPOSE'S WITHOUT WRITTEN PERMISSION FROM HONEYWELL PART NUMBER 4 2 3 1 SEE SHEET-2 TABLE CHARACTERISTICS D C LISTING ELECTRICAL RES ( ^ ) RES TOL MARKING 1 MECHANICAL A SLOT DEPTH IN [mm] B SLOT WIDTH IN [mm] C SHAFT LENGTH IN [mm] D BUSHNG LENGTH IN [mm] MTG HARDWARE LINE-1 .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA101A .500 [12.70] ASSEMBLED .625 [15.88] .500 [12.70] .625 [15.88] 392C2100 100 ^ .031 [0.79] .031 [0.79] 392C21K 1K ^ .031 [0.79] .031 [0.79] 392550M6875 10K ^ .031 [0.79] .031 [0.79] 392C210K 10K ^ .031 [0.79] .031 [0.79] 392C2100K 100K ^ .031 [0.79] .031 [0.79] 392C21MEG 1MEG ^ .031 [0.79] .031 [0.79] 392C2250 250 ^ .031 [0.79] .031 [0.79] 392C22500 2.5K ^ .031 [0.79] .031 [0.79] 392C225K 25K ^ .031 [0.79] .031 [0.79] 392C2500 500 ^ .031 [0.79] .031 [0.79] 392C25K 5K ^ .031 [0.79] .031 [0.79] 392C250K 50K ^ .031 [0.79] .031 [0.79] 392C2500K 500K ^ .031 [0.79] .031 [0.79] 392550M9297 5MEG ^ .031 [0.79] .031 [0.79] LINE-3 LINE-4 392C2 100 ^ 20 YYWW MEXICO RV6LAYSA102A 392C2 1K ^ 20 YYWW MEXICO ASSEMBLED RV6LAYSA103A 10K ^ 20 YYWW MEXICO .500 [12.70] ASSEMBLED RV6LAYSA103A 392C2 10K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA104A 392CS 100K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA105A 392C2 1MEG ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA251A 392C2 250 ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA252A 392C2 2.5K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA253A 392CS 25K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA501A 392CS 500 ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA502A 392C2 5K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA503A 392C2 50K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] ASSEMBLED RV6LAYSA504A 392CS 500K ^ 20 YYWW MEXICO .625 [15.88] .500 [12.70] UNASSEMBLED RV6LAYSA505B 392C2 5MEG ^ 20 YYWW MEXICO .625 [15.88] LINE-2 D C B B A A TITLE SIZE CAGE CODE DWG NO SCALE NONE REF WT: C 4 3 2 S-TAPER, SLOTTED SHAFT, LCKG BUSHING, SOLDER HOOK TERMS - 392-MATRIX-IDWG-13 SEE NOTE 1 SHEET TYPE I 2 of 2 REV A
RV6LAYSA252A 价格&库存
很抱歉,暂时无法提供与“RV6LAYSA252A”相匹配的价格&库存,您可以联系我们找货
RV6LAYSA252A
  • 1+277.172881+35.84072
  • 10+230.0138910+29.74268
  • 25+213.4121225+27.59593
  • 50+201.6121850+26.07010
  • 200+179.86553200+23.25808
  • 400+169.86742400+21.96525
库存:322
