KKU1021S28
KKU1021S28
    PRECISIONELECTRONICSCORPORATION
    可调电阻/电位器 1KΩ ±10% 2W
KKU1021S28 数据手册
MIL Style 2RV7 PRECISION Precision Series KK - 2 Watt multiple element 1/4" shaft diameter Precision series KK/2RV7 potentiometers are suitable for both military and commercial applications requiring multiple elements. They can easily be customized to meet special requirements. FEATURES: • • • • hot molded carbon element gold-plated terminals stainless-steel shaft and housing quality meeting or exceeding MIL-R-94 - QPL listed OPTIONS: • • • • • custom shafts and bushings special tapers fourth (center) terminal concentric shafts attached switches ELECTRICAL SPECIFICATIONS: MECHANICAL SPECIFICATIONS: Resistance range, linear taper: 50 Ω to 5 Meg Ω Mechanical rotation: 314° Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω Operating torque: 1 oz/in to 12 oz/in Resistance tolerance: ±10% or ±20% Rotational life: 25,000 cycles Resistance taper: linear, logarithmic, reverse logarithmic; other tapers by special order Power rating: 2 watts at 70°C derated to 0 watts at 120°C Insulation resistance: dry: 10K Meg Ω wet: 100K Meg Ω Dielectric strength: 900 V RMS at sea level Operating voltage: 500 V, subject to power rating ENVIRONMENTAL SPECIFICATIONS: Operating temperature: − 65°C to +125°C Resistance to soldering heat: 350°C for 5 seconds Humidity range: per MIL-R-94 Vibration range: per MIL-R-94 Shock resistance: per MIL-R-94 Load life: 1000 hours at 70°C PRECISION DRAWING: MIL Style 2RV7 MIL Style 2RV7 PRECISION ORDERING INFORMATION: Ordering Information - Commercial Part Numbers Series KK = series KK dual element Bushing Blank = standard Switch Blank = without switch Taper U = linear KKK = series KKK triple element L = locking S = SPST switch A= logarithmic B = reverse logarithmic W = panel & shaft steel Tolerance Shaft Style Resistance Value Total resistance value in 1 = 10% of R = round S Ω: first 2 digits significant, nominal = slotted F = third digit = flatted number of zeroes 2 = 20% of nominal Shaft Length 16 = 1/2" 20 = 5/8" 24 = 3/4" 28 = 7/8" 32 = 1" 40 = 1 1/4" 48 = 1 1/2" 64 = 2" 80 = 2 1/2" 96 = 3" Example: KKU1041S28 note: not all part number combinations are valid Ordering Information - Military Part Numbers Style 2RV7 = MIL style 2RV7 Bushing N = standard L = locking Temperature & Moisture Characteristics Y = as per MIL-R-94 S = panel & shaft steel Shaft Style Shaft Length Resistance Value Taper & Tolerance S = slotted B = 1/2" Total resistance value A = linear 10% F = flatted A = 5/8" in Ω: first 2 digits B = linear 20% D = 7/8" G = 1 1/4" significant, third digit = C = logarithmic 10% number of zeroes D = logarithmic 20% J = 2" E = reverse logarithmic K = 2 1/2" 10% F = reverse logarithmic 20% Example: RV4NAYSB000A note: not all part number combinations are valid
KKU1021S28 价格&库存
很抱歉,暂时无法提供与“KKU1021S28”相匹配的价格&库存,您可以联系我们找货
KKU1021S28
  • 1+812.883031+105.54882
  • 10+673.6092710+87.46482
  • 25+624.7468425+81.12027
  • 50+590.0706350+76.61774
  • 100+557.27810100+72.35979
库存:106
