PART NUMBER
4
2
3
REVISION HISTORY
SEE SHEET-2 TABLE
D
.656
MAX
[ 16.66 ]
.484 .016
[ 12.29 0.41 ]
2
CENTER
(C)
.062 .005
[ 1.57 0.13 ]
C
D
REV
DOCUMENT
DESCRIPTION
CHG'D BY
DATE
APPROVED
A
0112190
RELEASED
B.M.
2014-08-05
M. MIKE
SHOWN WITH SHAFT
AT 50% ROTATION
[ # 0.79]
D
2
[ # 0.41]
.025
MAX
[ 0.64 ]
(3X .088
[ 2.24 ]
TYP
1
A
.515 .016
[ 13.08 0.41 ]
+.010
-.000
[+0.25]
[-0.00]
B
( .080
2 [ 2.03 ]
[ # 0.13]
SLOTTED
TYP
.125 .001
[ 3.18 0.02 ]
.200 .005
[ 5.08 0.13 ]
3
RIGHT
(R)
45 $
1
LEFT
(L)
.200 .005
[ 5.08 0.13 ]
C
1/4-32 NEF-2A
1
.234
MAX
MARKING
SURFACE
DATE CODE
YY IS LAST 2 DIGITS
OF YEAR
WW IS WEEK NUMBER
1
B
2
LOCATING
PIN #1
X .012
[0.3]
( 90 $
MOUNTING SURFACE
R .040 .002
2
[ 1.02 0.05 ]
(FROM n .515) 2 PLS
LOCATING
PIN #2
2X .031 .016
[ 0.79 0.41 ]
OUTSIDE OF LOCATING
PINS MAY BE FLAT
GENERAL SPECIFICATIONS AND NOTES:
SERIES: 392
CONDUCTIVE PLASTIC ELEMENT
SUPPLIED WITH MOUNTING NUT, LOCKING WASHER AND JAM NUT.
NUTS AND WASHER PACKAGED ASSEMBLED OR UNASSEMBLED BASED ON LISTING
(REFER TO TABLE ON SHEET2).
MARKING INFORMATION SHOWN ON SIDE OF HOUSING.
REFER TO TABLE FOR SPECIFIC LISTING MARKING INFORMATION.
WEIGHT OF SINGLE CONTROL: .25 OUNCE [6.8 GRAMS] APPROX.
VALUES ARE SHOWN IN STANDARD AND METRIC UNITS. METRIC UNITS ARE IN [ ].
IF CONVERSION DIFFERENCE EXISTS, THE STANDARD UNIT PREVAILS.
CONTROLS HAVE AN INTERNAL O-RING SHAFT SEAL.
UNITS ARE SEALED FOR WAVE SOLDER AND WASH PROCESSING.
BUILT IN ACCORDANCE WITH MIL-R-94.
DIMENSIONS FOR BODY DIAMETER AND LOCATING PINS DEVIATE FROM MIL-R-94
45 $ 1/2 $
JAM
NUT
MOUNTING
NUT
3
LOCKING
WASHER
EPOXY
SEALANT
SPECIFICATIONS.
A
TAPER: LINEAR
TAPER TOLERANCE # 20% OF NOMINAL RESISTANCE AT 50% # 3% MECHANICAL
ROTATION.
LINEARITY (INDEPENDENT): # 5%
MAX WORKING VOLTAGE: 350 VDC APPLIED ACROSS L
& R TERMINALS. POWER NOT TO EXCEED RATING.
DIELECTRIC STRENGTH: 750 VAC FOR 60s
@ ATM [1 MPa]
350 VAC FOR 60s
@ 3.4 IN Hg ([1.5 KPa]
POWER RATING: 0.5W
@ 158 $ F [70 $ C], DE-RATED LINEARLY TO 0@ 264 $ F [129 $ C]
CRV FOR RESISTANCE GREATER THAN 500 ^ AND LESS THAN 50K ^ IS 1.5% OF
TOTAL
RESISTANCE. CRV FOR ALL OTHER RESISTANCE VALUES IS 3.1% OF TOTAL
RESISTANCE.
END RESISTANCE: 4 ^ MAX AT EACH END OF ROTATION
RESISTANCE AND TOLERANCE: (REFER TO TABLE)
ELECTRICAL ROTATION: 295 $ # 5 $
EFFECTIVE ELECTRICAL ROTATION: 265 $ TYPICAL
MATERIALS
SHAFT
NICKEL PLATED BRASS
HOUSING
THERMOPLASTIC
BUSHING
NICKEL PLATED BRASS
BASE
THERMOSET
TERMINALS
C
BRASS, SOLDER (TIN-LEAD) DIP FINISH
SEALANT
EPOXY
LOCK WASHER
NICKEL PLATED PHOS BRONZE
MOUNTING NUT
NICKEL PLATED BRASS
JAM NUT
CW
NICKEL PLATED BRASS
UNLESS OTHERWISE SPECIFIED THIRD ANGLE PROJECTION
OPERATIONAL SPECIFICATIONS:
DIMENSIONS ARE IN INCHES
ROTATIONAL LIFE: 50,000 CYCLES
STORAGE TEMPERATURE: -67 $ F [-55 $ C] TO 248 $ F [120 $ C]
OPERATING TEMPERATURE: -40 $ F [-40 $ C] TO 248 $ F [120 $ C]
ROTATIONAL TORQUE: 0.5 TO 2.0 OZ-IN [3.5 TO 14 mN
m]
WITH JAM NUT TIGHTENED TO 8 LB-IN [0.9 Nm] SHAFT WILL NOT ROTATE
UNTIL 20 LB-IN [2.3 Nm] IS APPLIED.
STOP TORQUE: 3 LB-IN [0.34 N
m]
MECHANICAL ROTATION: 295 $ # 5 $
4
B
SCALE 2:1
( ISOMETRIC VIEW - REF ONLY )
ELECTRICAL SPECIFICATIONS:
3
C
L
SCHEMATIC
R
MATERIAL
MULTI-SHEET
DRAWING
3
DECIMAL TOL
NO PLACE
1 PLACE
2 PLACE
3 PLACE
ANGULAR TOL
.400
.030
.010
.005
2 $
[10.16]
[0.76]
[0.25]
[0.13]
CHAMFER -
TITLE
# 5 $
SEE TABLE
FINISH
APPLICABLE DOCUMENTS: ASME Y14.100-2004
ASME Y14.5-2009
2
COMPUTER GENERATED DRAWING: PRO/ENGINEER
SIZE
CAGE CODE
SCALE
4:1
C
DWG NO
392-MATRIX-IDWG-13
REF WT:
SEE NOTE
RELEASE DATE
2014-08-05
DRW: B. MOHAPATRA
2014-05-28
RDE: M. MIKE
2014-05-28
QA:
A
S-TAPER, SLOTTED SHAFT,
LCKG BUSHING, SOLDER HOOK TERMS
CHK: S. RAGHU
2014-08-05
1
SHEET
TYPE
I
REV
A
1 of 2
HONEYWELL CONFIDENTIAL
THIS DOCUMENT CONTAINS PROPRIETARY
INFORMATION AND SUCH INFORMATION MAY
NOT BE DISCLOSED TO OTHERS FOR ANY
PURPOSE, NOR USED FOR MANUFACTURING
PURPOSE'S WITHOUT WRITTEN PERMISSION
FROM HONEYWELL
PART NUMBER
4
2
3
1
SEE SHEET-2 TABLE
CHARACTERISTICS
D
C
LISTING
ELECTRICAL
RES
RES
TOL
MARKING 1
MECHANICAL
A
SLOT
DEPTH
IN [mm]
B
SLOT
WIDTH
IN [mm]
C
SHAFT
LENGTH
IN [mm]
D
BUSHNG
LENGTH
IN [mm]
MTG
HARDWARE
LINE-1
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA101A
.500
[12.70]
ASSEMBLED
.625
[15.88]
.500
[12.70]
.625
[15.88]
392C2100
100 ^
.031
[0.79]
.031
[0.79]
392C21K
1K ^
.031
[0.79]
.031
[0.79]
392550M6875
10K ^
.031
[0.79]
.031
[0.79]
392C210K
10K ^
.031
[0.79]
.031
[0.79]
392C2100K
100K ^
.031
[0.79]
.031
[0.79]
392C21MEG
1MEG ^
.031
[0.79]
.031
[0.79]
392C2250
250 ^
.031
[0.79]
.031
[0.79]
392C22500
2.5K ^
.031
[0.79]
.031
[0.79]
392C225K
25K ^
.031
[0.79]
.031
[0.79]
392C2500
500 ^
.031
[0.79]
.031
[0.79]
392C25K
5K ^
.031
[0.79]
.031
[0.79]
392C250K
50K ^
.031
[0.79]
.031
[0.79]
392C2500K
500K ^
.031
[0.79]
.031
[0.79]
392550M9297
5MEG ^
.031
[0.79]
.031
[0.79]
LINE-3
LINE-4
392C2 100 ^
20 YYWW
MEXICO
RV6LAYSA102A
392C2 1K ^
20 YYWW
MEXICO
ASSEMBLED
RV6LAYSA103A
10K ^
20 YYWW
MEXICO
.500
[12.70]
ASSEMBLED
RV6LAYSA103A
392C2 10K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA104A
392CS 100K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA105A
392C2 1MEG ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA251A
392C2 250 ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA252A
392C2 2.5K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA253A
392CS 25K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA501A
392CS 500 ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA502A
392C2 5K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA503A
392C2 50K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
ASSEMBLED
RV6LAYSA504A
392CS 500K ^
20 YYWW
MEXICO
.625
[15.88]
.500
[12.70]
UNASSEMBLED
RV6LAYSA505B
392C2 5MEG ^
20 YYWW
MEXICO
.625
[15.88]
LINE-2
D
C
B
B
A
A
TITLE
SIZE
CAGE CODE
DWG NO
SCALE
NONE
REF WT:
C
4
3
2
392-MATRIX-IDWG-13
SEE NOTE
1
SHEET
TYPE
I
2 of 2
REV
A
很抱歉,暂时无法提供与“RV6LAYSA104A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+372.890691+48.24337
- 10+309.3444710+40.02197
- 25+286.9751025+37.12789
- 50+271.0906350+35.07281
- 200+241.82682200+31.28676
