KB1021S28
KB1021S28
    PRECISIONELECTRONICSCORPORATION
    可调电阻/电位器 1KΩ ±10% 2W
KB1021S28 数据手册
MIL Style RV4 PRECISION Precision Series K - 2 Watt 1/4" shaft diameter Precision series K/RV4 potentiometers are suitable for both military and commercial applications. They can easily be customized to meet special requirements. FEATURES: • • • • hot molded carbon element gold-plated terminals stainless-steel shaft and housing quality meeting or exceeding MIL-R-94 - QPL listed OPTIONS: • • • • • custom shafts and bushings special tapers fourth (center) terminal high life attached switch ELECTRICAL SPECIFICATIONS: MECHANICAL SPECIFICATIONS: Resistance range, linear taper: 50 Ω to 5 Meg Ω Mechanical rotation: 314° Resistance range, logarithmic taper: 150 Ω to 1 Meg Ω Operating torque: 1 oz/in to 6 oz/in Resistance tolerance: ±10% or ±20% Rotational life: 25,000 cycles Resistance taper: linear, logarithmic, reverse logarithmic; other tapers by special order Power rating: 2 watts at 70°C derated to 0 watts at 120°C Insulation resistance: dry: 10K Meg Ω wet: 100K Meg Ω Dielectric strength: 900 V RMS at sea level Operating voltage: 500 V, subject to power rating ENVIRONMENTAL SPECIFICATIONS: Operating temperature: − 65°C to +125°C Resistance to soldering heat: 350°C for 5 seconds Humidity range: per MIL-R-94 Vibration range: per MIL-R-94 Shock resistance: per MIL-R-94 Load life: 1000 hours at 70°C PRECISION DRAWING: MIL Style RV4 MIL Style RV4 PRECISION ORDERING INFORMATION: Ordering Information - Commercial Part Numbers Series K = series K Bushing Blank = standard Switch Blank = without switch Taper U = linear L = locking S = SPST switch A= logarithmic B = reverse logarithmic W = panel & shaft steel Resistance Value Total resistance value in Ω: first 2 digits significant, third digit = number of zeroes Tolerance Shaft Style 1 = 10% of R = round S nominal = slotted F = flatted 2 = 20% of nominal Shaft Length 16 = 1/2" 20 = 5/8" 24 = 3/4" 28 = 7/8" 32 = 1" 40 = 1 1/4" 48 = 1 1/2" 64 = 2" 80 = 2 1/2" 96 = 3" Example: KSU1031R16 note: not all part number combinations are valid Ordering Information - Military Part Numbers Shaft Temperature & Moisture Bushing Switch Shaft Style Length Characteristics Style RV4 = MIL style RV4 N = standard A = without Y = as per MIL-R-94 S = slotted B = 1/2" switch L = locking F = flatted A = 5/8" S = panel & shaft steel B = SPST switch D = 7/8" G = 1 1/4" Resistance Value Taper & Tolerance Total resistance value A = linear 10% in Ω: first 2 digits B = linear 20% significant, third digit = C = logarithmic 10% number of zeroes D = logarithmic 20% J = 2" E = reverse logarithmic K = 2 1/2" 10% F = reverse logarithmic 20% Example: RV4NAYSB000A note: not all part number combinations are valid Type K Cross Reference Military Precision Clarostat Allen Bradley Ohmite KU S28 RV4NAYSD A 380C3 / 53C3 JA1N056S UA CMU KLU S20 RV4LAYSA A 280C2 / 53C2 JA1L040S UC CLU KU S16 RV4NAYSB A N/A JA1N032S UA N/A KU S64 RV4NAYSJ A N/A JA1N200S UA CU KU R64 N/A 380C1 / 53C1 JA1N200P UA N/A KU S80 RV4NAYSK A N/A JA1N232S UA N/A KA R64 N/A 53C1Z JA1N200P AA N/A KLU S28 RV4LAYSD A N/A JA1L056S UA N/A
KB1021S28
1. 物料型号:Precision Series K/RV4,适用于军事和商业应用,可定制以满足特殊要求。 2. 器件简介:电位器具有热成型碳膜、镀金端子、不锈钢轴和外壳,质量符合或超过MIL-R-94标准。 3. 引脚分配:文档中未明确列出引脚分配,但提供了订购信息,包括开关选项、电阻值、公差、轴样式和长度。 4. 参数特性: - 电阻范围:线性变化为50Ω至5MΩ,对数变化为150Ω至1MΩ。 - 机械旋转:314°。 - 操作扭矩:1盎司/英寸至6盎司/英寸。 - 电阻公差:±10%或±20%。 - 旋转寿命:25,000次。 - 功率等级:70°C时2瓦,120°C时降至0瓦。 - 绝缘电阻:干燥时10KMΩ,湿润时100KMΩ。 - 耐电压:海平面上900V RMS。 - 工作电压:500V,受功率等级限制。 5. 功能详解:电位器可提供线性、对数、反向对数的电阻变化,也可按特殊订单提供其他变化。 6. 应用信息:适用于需要高精度和可靠性的应用场景。 7. 封装信息:提供了详细的机械规格和环境规格,包括工作温度范围、耐焊接热、湿度范围、振动范围、抗冲击性和负载寿命。
KB1021S28 价格&库存
很抱歉,暂时无法提供与“KB1021S28”相匹配的价格&库存,您可以联系我们找货
