JT30-120-C00
JT30-120-C00
    COPAL(日电产 科宝电子)
    电位器(操纵杆) - - -
JT30-120-C00 数据手册
OPTICAL CONTACTLESS TYPE JT30 Basic construction RoHS compliant Case Light source Position Sensitive Detector (Photo-sensor) Slit P.C. board Preload spring Bearing ■ FEATURES Shaft ● Contactless configuration offers much longer life ● Low torque 0.245 mN·m {2.5 gf·cm} maximum ● Superior temperature characteristic due to temperature Optical contactless single turn type compensation circut incorporated ● RoHS compliant ■ PART NUMBER DESIGNATION JT30 - 120 - 500 Series name Output 0:0.5 ~ 4.5 V (Standard) Effective electrical angle 120:120° 340:340° Input voltage 5:DC5 V C:DC12 V ■ LIST OF PART NUMBERS Effective electrical angle 120° 340° Input voltage Part number DC5 V JT30-120-500 DC12 V JT30-120-C00 DC5 V JT30-340-500 DC12 V JT30-340-C00 ※ Verify the above part numbers when placing orders. JT30 POTENTIOMETERS ■ STANDARD SPECIFICATIONS ● Electrical characteristics Input voltage ● Mechanical characteristics DC5 V ± 0.25 V Dissipation 120° 340° +0.5 ~ +4.5 V Output voltage JT30 出力回路 Insulation resistance 100 MΩ (at DC500 V) minimum AC500 V (1 min) ( 2 × 108 revolution 294.2 m/s2 {30 G} 30 ~ 200 Hz, 30 h 294.2 m/s2 {30 G} minimum Operating temp. range −30 ~ 80 °C Storage temp. range −40 ~ 100 °C Relative humidity 95 % maximum Humidity ※1 At normal temp. ■ OUTPUT Rotational life ● Environmental characteristics ± 40 mV (± 30 mV/0 ~ 50 °C) Dielectric strength 360° continuous Shock ± 2.0 %FS (± 1.0 %FS/0 ~ 50 °C) Temperature medium drift Mechanical angle Vibration Absolute linearity ※ 1 ± 1.5 %FS ± 2.0 %FS ± 1.5 %FS ± 2.0 %FS Temperature sensitivity 1500 min-1 Maximum rotational speed 40 mA maximum Effective electrical angle 120° 340° 0.245 mN·m {2.5 gf·cm} maximum (at normal temp.) Starting torque DC12 V ± 0.6 V Approx. 40 g Net weight CW IP40 Protection grade ) ■ OUTPUT CIRCUITRY + 4.5 V DC5 V, 12 V + 2.5 V + 0.5 V I0 50 % 50 % Output 2.2 kΩ 0V Effective electrical angle I0 is 20 mA max. ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) AWG28 Shield cable 3-M3 D = 3 min. 2.5 ñ0.006 q 6 ñ0.014 0 Red Power ⊕ Blue Power 0 (V) White Output Green Case ground Cable shield NC 0$ 12 12 0$ q 27 q 15 ñ0.05 q 30 20 q ■ ELECTRICAL WIRING 10 Cable length = 600 ± 20 minimum 1.57 1.5 2 15 20
JT30-120-C00 价格&库存
很抱歉,暂时无法提供与“JT30-120-C00”相匹配的价格&库存,您可以联系我们找货
