CRV16-00-103
CRV16-00-103
    COPAL(日电产 科宝电子)
    电位器(操纵杆) 10KΩ ±20% ±400ppm/℃
CRV16-00-103 数据手册
CONDUCTIVE PLASTIC SINGLE TURN TYPE CRV16 series Basic construction Conductive plastic single turn type RoHS compliant Cover Stopper Mount Resistor Shaft Collector Rivet Base ■ FEATURES OLong life OCost effective OHigh linearity through precision wire winding ORoHS compliant Terminal Wiper ■ PART NUMBER DESIGNATION CRV16-00-102 Series name Nominal resistance value(Ω) 102 : 1 k 502 : 5 k ■ LIST OF PART NUMBERS Nominal resistance value Part number 1 kΩ CRV16-00-102 2 kΩ CRV16-00-202 5 kΩ CRV16-00-502 10 kΩ CRV16-00-103 202 : 2 k 103 : 10 k CRV16 POTENTIOMETERS ■ STANDARD SPECIFICATIONS OElectrical characteristics OMechanical characteristics Nominal resistance value 1 kї, 2 kї, 5 kї, 10 kї Mechanical angle ± 20 Rotational torque % Resistance tolerance Essentially infinite Resolution % Independent linearity Stop strength ±1 W Power rating (at 40 °C) 0.196 {2} 500 thousand cycles Operating temp. range 500, 1min Net weight Insulation resistance Mї minimum 50 (at DC 500 V) Temp. coefficient of resistance ppm/°C ± 400 °C −10 ~ 80 g Approx.5 Protection grade 0.5 % maximum Output smoothness 3.92 {40} OEnvironmental characteristics 0.25 Dielectric strength mN·m {gf·cm} maximum N·m {kgf·cm} minimum Rotational life (cycles) 220° ± 10° Effective electrical angle 260° ± 5° IP20 ■ RATED POWER DERATING CURVE Power rating ratio(%) 100 +40 –10 +80 Ambient temperature(℃) ■ OUTLINE DIMENSIONS 1 R1 3 – φ 1.2 Terminal width 2.5 (30°) 2 (0.75) 3 M 6 (P=0.75) Effective screw length 3.5 +0.5 0 0 φ 5 –0.04 7.5 2.8 ± 0.2 φ8 0.8 2.7 Mounting face CCW 1 2 5 (15) M 6 (P=0.75) 2 1 6.7 φ 10 1. Nut 2. Washer 9 2 CW 3 1 10 (Accessories) Wiring diagram φ 16.2 (30°) Unless otherwise specified tolerance : ± 0.5 (Unit : mm) φ 6.2 0.5
CRV16-00-103 价格&库存
很抱歉,暂时无法提供与“CRV16-00-103”相匹配的价格&库存,您可以联系我们找货
