JP-30-20K
JP-30-20K
    COPAL(日电产 科宝电子)
    电位器(操纵杆) 20KΩ ±2% ±150ppm/℃
JP-30-20K 数据手册
CERMET SINGLE TURN TYPE RoHS compliant JP-30 Basic construction Cermet single turn type ■ FEATURES OCost effective (In house comparison) OHigh resoluiion (Essentially infinite) ORoHS compliant ■ STANDARD SPECIFICATIONS Item Part number % Resistance torelance % Independent linearity Effective electrical angle 360° continuous Power rating (at 40 °C) W 1.5 Dielectric strength Vrms Insulation resistance Mї minimum 1000 (at DC500 V) mN·m {gf·cm} 2.94 {30} maximum Series name JP-30:For sensor ± 0.5 300° ± 1° Mechanical angle JP-30-1k ±2 Essentially infinite Resolution ■ PART NUMBER DESIGNATION JP-30 Rotational torque Peak noise 1000 1 min 2 % or 100 ї, whichever is greater Nominal resistance value(ї) 500, 1 k, 2 k, 5 k, 10 k, 20 k, 50 k, 100 k Temp. coefficient ofresistance 10-6/°C Operating temp. range °C Maximum rotational speed r/min Rotational life Net weight Strength of tighten screw ± 150 − 55 ~ 85 150 3 million revolution g Approx. 26 0.98 N·m {10 kgf·cm} maximum KPerform soldering of the terminals at 380 °C for no more three seconds, and avoid applying excess heat. Also, avoid applying outside force to the terminals. In case of using multiturn potentiometers, when rotating the shaft to the mechanical limit, apply torque below the strength of the stopper. Also, give due consideration to thrust and radial loading. JP-30 POTENTIOMETERS ■ LIST OF PART NUMBERS Application Series name Nominal resistance value Part number JP-30 500 ї 1 kї 2 kї 5 kї 10 kї 20 kї 50 kї 100 kї JP-30 500 JP-30 1 k JP-30 2 k JP-30 5 k JP-30 10 k JP-30 20 k JP-30 50 k JP-30 100 k For sensor ※ Verify the above part numbers when placing orders. ■ 120,1$/5(6,67$1&(9$/8(‡5$7(' ■ RATED POWER DERATING CURVE 92/7$*(‡5$7('&855(17 JP-30 Nominal resistance value Rated voltage Rated current (ї) (mA) 500 27.3 54.7 1k 38.7 38.7 2k 54.7 27.3 5k 86.6 17.3 10k 122 12.2 20 k 173 8.66 50 k 273 5.47 100 k 387 3.87 100 Power rating ratio (%) (V) –55 ■ OUTLINE DIMENSIONS (40.5) 26 1 ax. 1m φ 9 R2 φ 2.9±0.1 φ 30 2 0.3 14.5 max. 9±0.3 8 1 ° 12±0.3 5± 3 φ1 30°±5 0 φ 4 –0.05 5° 30°± +85 Unless otherwise specified, tolerance: ± 0.5 (Unit: mm) OJP-30 For sensor +40 Ambient temperature(℃) M 9 (P = 0.75) φ (Accessories) 2.5±0.3 .9 12 M9 P=0.75 φ 12 9.4 0.5 2 1. Nut (1) 2. Washer
JP-30-20K 价格&库存
很抱歉,暂时无法提供与“JP-30-20K”相匹配的价格&库存,您可以联系我们找货
