DSK-3R3H703T414-HRL
DSK-3R3H703T414-HRL
    ELNAAMERICA
    超级电容器 - 70mF -20~+80% 3.3V
DSK-3R3H703T414-HRL 数据手册
DSK-414 DSK-414 ELECTRIC DOUBLE LAYERLAYER ELECTRIC DOUBLE CAPACITORS “DYNACAP” CAPACITORS “DYNACAP” Coin Cell Capacitors ● ● ● ● GREEN CAP ® ® 70℃ Reflow soldering method available. Unlike batteries, the number of charging / Low profile discharging cycles unlimited and rapid charging / discharging is possible. DSK (414) Unlike batteries, exceilent charge and discharge characteristics with no chemical reactions. φ4.8×1.71Lmm Max height type made lineup in the DSK series. DSK (614) Specifications Item Performance Series name series DSK Max. operating voltage (V) 3.3 Category temperature range (℃) ー10 to +70 Tolerance at rated capacitance (%) ー20 to +80 Rated capacitance (F) 0.07 Internal resistance (Ω Max.) 100 at 1 kHz Characteristics at high and low temperature Percentage of capacitance change Endurance (70℃) Percentage of capacitance change Within ±50% of the value at 20℃ Internal resistance Less than ten times of the initial specified value. Test time 500 hours Within ±30% of the initial measured value Internal resistance 5kΩ or less Shelf life (70℃) Test time : 500 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009(IEC 62391-1 2006) Outline Drawing Unit : mm Terminal shaped : HR 7.4 Max. 1.1±0.5 1.6±0.2 7.4 Max. 1.1±0.5 1.1±0.5 1.6±0.2 1.0±0.2 0.7±0.2 +0.1 L ー0.2 3.5ー00.5 0.1±0.03 2.0 +0 ー0.1 1.66±0.05 Polarity changesto terminal form. Sn plated Sn plated *Please 2.5ー00.5 0.1±0.03 2.8±0.1 0.1±0.03 3.0 +0, ー0.1 φD +0 ー0.2 3.0 +0, ー0.1 1.66±0.05 1.0±0.2 0.7±0.2 L 0.1±0.03 +0.1 ー0.2 φD+0 ー0.2 1.1±0.5 2.0+0 ー0.1 2.8±0.1 Unit : mm 1.5±0.1 4.6±0.1 1.5±0.1 Terminal shaped : HL Recommended land pattern size consult with us about other terminal form Part numbering system (3.3V0.07F, terminal shaped : HL) DSK Series code ̶ 3R3 Max.operating voltage symbol H 703 T414 ̶ Rated capacitance symbol Additional symbol HL L Terminal shaped Taping symbol Part number is refer to following table. Standard Ratings EDLC Max. operating voltage (V) 3.3 *Soldering Rated capacitance (F) 0.07 ELNA Parts No. DSK-3R3H703T414-HLL DSK-3R3H703T414-HRL φD×L (mm) 4.8×1.4 conditions are described on page 191. CAT.No.2015/2016E 210 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use.
DSK-3R3H703T414-HRL 价格&库存
很抱歉,暂时无法提供与“DSK-3R3H703T414-HRL”相匹配的价格&库存,您可以联系我们找货
