DXJ
DXJ
ELECTRICDOUBLE
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS“DYNACAP”
“DYNACAP”
ELECTRIC
5.5V Miniaturized
z High Temperature Capacitors
High temperature type of Series DX.
5mm tall. Max. thin profile (H-shaped).
Miniaturized but can encase up to 0.33F in 11.5×5mm case,
and 1.0F in φ19.0×20.5Lmm case.
GREEN
CAP
85℃
High temperature
DXJ
DX
Marking color : White print on a black sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー10 to +85
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
0.047
0.1
0.22
0.33
1
Internal resistance (Ω Max.)
200
150
150
150
75
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (85℃)
Within ±30% of the value at 20℃
Internal resistance
Less than four times of the initial specified value.
1000 hours
Test time
Within ±30% of the initial measured value
Internal resistance
Shelf life (85℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
Terminal shaped : H
(4.5)
φD±0.3
φD±0.3
(0.8)
(0.15)
(0.15)
5.0±0.3
4.0±0.3
Sleeve
Sn plated
Sleeve
Sn plated
10.0±0.5
Part numbering system (example : 5.5V0.1F)
5R5
Max.operating voltage
symbol
Series code
Note
104
Terminal
code
(0.8)
5.0±0.5
(φ11.5 : 0.8, φ19:1.0)
DXJ
5±0.3 L±0.5
L±0.5
12.4±0.5
(4.5)
Terminal shaped : V
Rated Capacitance
symbol
U
Additional
symbol
Part number is refer to following table.
Do not apply external force to products or terminals as stress such as twisting,
bending, pushing, or falling of such products or terminals may remove the terminals,
resulting in an open/short circuit or liquid leakage.
Avoid applying excessive heat to capacitors during heating of an adhesive curing oven.
For details, refer to the precautions in use of DYNACAP.
Standard Ratings
Max. operating voltage (V)
ELNA Parts No.
5.5
0.047
5.5
0.1
0.22
5.5
0.33
5.5
1
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
203
11.5×13.0
DXJ-5R5H473U
11.5× 5.0
DXJ-5R5V104U
11.5×13.0
DXJ-5R5H104U
11.5× 5.0
DXJ-5R5V224U
11.5×13.0
DXJ-5R5H224U
11.5× 5.0
DXJ-5R5V334U
11.5×13.0
DXJ-5R5H334U
11.5× 5.0
DXJ-5R5V105U
19.0×20.5
CAT.No.2015/2016E
EDLC
5.5
φD×L (mm)
DXJ-5R5V473U
很抱歉,暂时无法提供与“DXJ-5R5H334U”相匹配的价格&库存,您可以联系我们找货
