DB-5R5D224T
DB-5R5D224T
    ELNAAMERICA
    DIP
    超级电容器 DIP 220mF -20~+80% 5.5V
DB-5R5D224T 数据手册
DB, DBN DB, DBN ELECTRICDOUBLE DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” ELECTRIC 5.5V Standard Capacitors Series DB ● ● ● ● ● GREEN CAP Small-sized, large capacity, excellent voltage holding. For all ratings, uniform 5mm pitch of terminal spacing. Wider temperature range(−25 to +70° C)than battery. φ21.5×7.5L size can encase up to 1.5F. Ideal for backing up of CMOS’ s, IC’ s, microcomputers, RAM’ s, RTC’ s and the like used in Video’ s, tuners, TV sets, telephone sets and others. ® ® 70°C Low resistance Marking color : White print on an indigo sleeve DB DBN Specifications Item Performance Category temperature range (℃) ー25 to +70 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance Rated capacitance (F) 0.047 0.1 0.22 0.33 at 1 kHz Internal resistance (Ω Max.) 120 75 75 75 Characteristics at high Percentage of capacitance change and low temperature Internal resistance Endurance (70℃) Percentage of capacitance change 0.47 0.47 75(φ13.5)30(φ21.5) 1000 hours Within ±30% of the initial measured value Within four times of the initial specified value Shelf life (70℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Standard Ratings Unit : mm ELNA Parts No. DB-5R5D473T DB-5R5D104T DB-5R5D224T DB-5R5D334T DB-5R5D474ST DB-5R5D474T DB-5R5D105T DB-5R5D155T Max. operating voltage (V) Rated capacitance (F) Sleeve 0.5±0.1 6.0±1 (4.0±0.5) (3.0±0.5) 0.8±0.1 5.0±0.3 0.047 0.1 0.22 0.33 0.47 0.47 1 1.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 1.2±0.1 φD Max 30 Within ±30% of the value at 20℃ Internal resistance 6.0±1 1.5 Less than five times of the value at 20℃ Test time L Max 1 30 φD×L (mm) 13.5×7.5 13.5×7.5 13.5×7.5 13.5×7.5 13.5×7.5 21.5×8.0 21.5×8.0 21.5×8.0 Part numbering system (example : 5.5V0.1F) Sn plated teminal DB ̶ Series code 5R5 D 104 Max. operating voltage symbol Terminal code Reted capacitance symbol T Additional symbol Part number is refer to above table. 5.5V Low Resistance Series DBN GREEN CAP ● Low ESR 70°C ● Specifications Internal resistance was reduced to 85% to DB series. It excels in rapid charge.(It can charge and discharge with 1.5 times as much current (mA) as rated capacitance.) Item Performance Category temperature range (℃) ー25 to +70 Tolerance at rated capacitance (%) ー20 to +80 Rated capacitance (F) 0.047 0.1 0.22 0.33 at 1 kHz Internal resistance (Ω) 25 25 25 25 Characteristics at high Percentage of capacitance change and low temperature Internal resistance Endurance (70℃) Percentage of capacitance change EDLC Internal resistance 0.47 0.47 25(φ13.5)20(φ21.5) 1 1.5 20 20 Within ±30% of the value at 20℃ Less than five times of the value at 20℃ Test time 1000 hours Within ±30% of the initial measured value Internal resistance Within four times of the initial specified value Shelf life (70℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Standard Ratings Max. operating voltage (V) Rated capacitance (F) 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 CAT.No.2015/2016E 0.047 0.1 0.22 0.33 0.47 0.47 1 1.5 ELNA Parts No. DBN-5R5D473T DBN-5R5D104T DBN-5R5D224T DBN-5R5D334T DBN-5R5D474ST DBN-5R5D474T DBN-5R5D105T DBN-5R5D155T φD×L (mm) 13.5×7.5 13.5×7.5 13.5×7.5 13.5×7.5 13.5×7.5 21.5×8.0 21.5×8.0 21.5×8.0 Part numbering system (example : 5.5V0.047F) DBN Series code ̶ 5R5 D 473 Max. operating voltage symbol Terminal code Reted capacitance symbol T Additional symbol Part number is refer to left table. 198 NOTE : ‌Design, Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use.
DB-5R5D224T 价格&库存
很抱歉,暂时无法提供与“DB-5R5D224T”相匹配的价格&库存,您可以联系我们找货
