High Voltage Tolerance Capacitors
DK
DK
ELECTRIC
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS“DYNACAP”
“DYNACAP”
ELECTRIC
DOUBLE
GREEN
CAP
70˚C
High voltage tolerant (6.3V guaranteed) and highly reliable.
Ideal for backing up of Li-battery-backed equipment such
as cameras, video and telephone sets.
Miniaturized
DX
DB
DK
Marking color : White print on an indigo sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー25 to +70
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (70℃)
Internal resistance (Ω Max.)
0.047
0.1
0.47
0.68
1
300
200
50
50
30
Within ±30% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃
Test time
1000 hours
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Test time : 1000 hours ; Same as endurance.
Shelf life (70℃)
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Applicable standards
Outline Drawing
Unit : mm
Part numbering system (example : 6.3V0.1F)
Sleeve
0.5±0.1
6R3
Max.operating voltage
symbol
D
104
T
Rated capacitance
symbol
φD Max
6.0±1
Part number is refer to following table.
(4.0±0.5)
(3.0±0.5)
6.0±1
Series code
0.8±0.1
5.0±0.3
L Max
DK
1.2±0.1
Sn plated teminal
Standard Ratings
Max. operating voltage (V)
ELNA Parts No.
φD×L (mm)
6.3
0.047
DK-6R3D473T
13.5×9.5
6.3
0.1
DK-6R3D104T
13.5×9.5
6.3
0.47
DK-6R3D474T
21.5×9.5
6.3
0.68
DK-6R3D684T
21.5×9.5
6.3
1
DK-6R3D105T
21.5×9.5
EDLC
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
205
CAT.No.2015/2016E
很抱歉,暂时无法提供与“DK-6R3D105T”相匹配的价格&库存,您可以联系我们找货
