DVL-5R5D224T-R5
DVL-5R5D224T-R5
    ELNAAMERICA
    DIP
    超级电容器 DIP 220mF -20~+80% 5.5V
DVL-5R5D224T-R5 数据手册
DVL DVL ELECTRIC ELECTRICDOUBLE DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” ® ® 5.5V SMD, Wide Temperature range Capacitors ● ● ● ● ● GREEN CAP 85°C Size : φ12.5×10.5mm, compatible with surface mounting. Wide temperature range (−40 to 85℃), Low ESR. Unlike batteries, safe and high reliability without containing active and hazardous substance. Unlike batteries, excellent charge and discharge characteristics with no chemical reactions. Responds to temperature 260℃ during the reflow peek. Convert to chip DHL DVL Specifications Item Performance Category temperature range (℃) ー 40 to +85 Tolerance at rated capacitance (%) ー 20 to +80 Internal resistance at 1 kHz Marking color : White print on an brown sleeve Rated capacitance (F) 0.047 0.1 0.22 Internal resistance (Ω Max.) 45 45 45 Characteristics at high and low temperature Percentage of capacitance change Endurance (85℃) Percentage of capacitance change Within ±30% of the value at 20℃ −40℃ : Less than seven times of the value at 20℃  85℃ : Less than five times of the value at 20℃ Internal resistance 1000 hours Test time Within ±30% of the initial measured value Less than four times of the initial specified value Internal resistance Test time : 1000 hours ; Same as endurance. Shelf life (85℃) Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Applicable standards Outline Drawing Unit : mm 6.0 6.0 4.0 (5.0) (5.0) (5.0) φD±0.5 Unit : mm 3.2 0.7±0.3 13±0.2 13±0.2 0.3 Max Recommended land pattern size L Max (1.2) Part numbering system (example : 5.5V0.1F) DVL ̶ Series code 5R5 D 104 Max. operating voltage symbol Terminal code Rated capacitance symbol T ̶ R5 Taping symbol Part number is refer to following table. Standard Ratings Rated capacitance (F) ELNA Parts No. φD×L (mm) 5.5 0.047 DVL-5R5D473T-R5 12.5×10.5 5.5 0.1 DVL-5R5D104T-R5 12.5×10.5 5.5 0.22 DVL-5R5D224T-R5 12.5×10.5 *soldering conditions are described on page 191. NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 197 CAT.No.2015/2016E EDLC Max. operating voltage (V)
DVL-5R5D224T-R5 价格&库存
很抱歉,暂时无法提供与“DVL-5R5D224T-R5”相匹配的价格&库存,您可以联系我们找货
