HB1325-2R5156-R
HB1325-2R5156-R
    EATON(伊顿)
    插件,P=5mm
    超级电容器 DIP 15F -10~+30% 2.5V
HB1325-2R5156-R 数据手册
Supercapacitors HALOGEN HF Pb FREE HB Series Description Cooper Bussmann PowerStor supercapacitors are unique, ultra-high capacitance devices utilizing electrochemical double layer capacitor (EDLC) construction combined with new, high performance materials. This combination of advanced technologies allows Cooper Bussmann to offer a wide variety of capacitor solutions tailored to specific applications that range from a few micro-amps for several days to several amps for milliseconds. Features & Benefits • Ultra low ESR for high power density • Large capacitance for high energy density Cylindrical Device • UL Recognized Specifications Working Voltage Surge Voltage Capacitance Capacitance Tolerance Operating Temperature Range Extended Operating Temperature Range 2.5V 3.0V 3.0F to 110F -10% to +30% (20°C) -25°C to 70°C -25°C to 85°C (with linear voltage derating to 2.1V @ 85°C) Standard Product Capacitance (F) 3 5 6 10 15 25 35 60 110 Part Number HB0820-2R5305-R HB1020-2R5505-R HB0830-2R5605-R HB1030-2R5106-R HB1325-2R5156-R HB1625-2R5256-R HB1635-2R5356-R HB1840-2R5606-R HB1860-2R5117-R Maximum ESR (Ω) (Equivalent Series Resistance) Measured @ 1kHz 100Hz 0.155 0.160 0.095 0.100 0.095 0.100 0.060 0.060 0.045 0.050 0.036 0.040 0.028 0.030 0.023 0.025 0.018 0.020 Nominal Leakage Current (μA) After 72 Hrs. @ 20°C 7 11 11 20 22 28 32 47 180 Nominal Dimensions (mm) Diameter Length 8 20 10 20.5 8 30 10 30 13 26 16 25 16 35 18 40 18 60 Typical Mass (grams/piece) 1.5 2.4 2.4 3.5 4.8 8.2 9.8 13.8 22 Performance Parameter Life (1000 hrs @ 70°C @ 2.5Vdc) Storage - Low and High Temperature (1000 hrs @ -25°C and 85°C) 1211 BU-SB111359 Capacitance Change (% of initial Specified value) < 30 % ESR (% of initial specified value) < 200 % < 30 % < 200 % Page 1 of 2 Data Sheet: 4375 Dimensions (mm) Part Number HB0820-2R5305-R HB1020-2R5505-R HB0830-2R5605-R HB1030-2R5106-R HB1325-2R5156-R HB1625-2R5256-R HB1635-2R5356-R HB1840-2R5606-R HB1860-2R5117-R D D’ L L’ F d’ C C’ 8.0 10.0 8.0 10.0 13.0 16.0 16.0 18.0 18.0 8.5 10.5 8.5 10.5 13.5 16.5 16.5 18.5 18.5 20.5 21.8 30.5 31.0 27.9 27.9 37.5 41.5 59.5 21.0 22.3 31.0 31.5 28.4 28.4 38.0 42.0 60.5 3.5 5.0 3.5 5.0 5.0 7.5 7.5 7.5 7.5 0.50 0.60 0.60 0.60 0.60 0.80 0.80 0.80 0.80 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 ± 0.5 ± 0.02 Tolerances Maximum Minimum Note: Longer lead is positive. Part Numbering System − HB Series Code HB Series Dimensions (mm) Diameter Length R Voltage (V) R is Decimal 2R5 = 2.5V Capacitance (μF) Value Multiplier Example: 106 = 10 x 106µF or 10F Packaging Information Part Marking Packaging: • Standard packaging: Bulk, 100 units per bag. • Larger bulk packages available on request. North America Cooper Bussmann 1225 Broken Sound Parkway NW Suite F Boca Raton, FL 33487-3533 Tel: 1-561-998-4100 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Cooper Bussmann P.O. Box 14460 St. Louis, MO 63178-4460 Tel: 1-636-394-2877 Fax: 1-636-527-1607 Manufacturer Capacitance (F) Nominal Working Voltage (V) Series Code (or part number) Polarity Europe Cooper Bussmann Cooper (UK) Limited Burton-on-the-Wolds Leicestershire • LE12 5TH UK Tel: +44 (0) 1509 882 737 Fax: +44 (0) 1509 882 786 Cooper Bussmann Avda. Santa Eulalia, 290 08223 Terrassa, (Barcelona), Spain Tel: +34 937 362 812 +34 937 362 813 Fax: +34 937 362 719 Asia Pacific Cooper Bussmann 1 Jalan Kilang Timor #06-01 Pacific Tech Centre Singapore 159303 Tel: +65 278 6151 Fax: +65 270 4160 The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. ©.2011 Cooper Bussmann www.cooperbussmann.com 1211 BU-SB111359 Page 2 of 2 Data Sheet: 4375
HB1325-2R5156-R 价格&库存
很抱歉,暂时无法提供与“HB1325-2R5156-R”相匹配的价格&库存,您可以联系我们找货
HB1325-2R5156-R
