DZ-2R5D106T
DZ-2R5D106T
    ELNAAMERICA
    DIP
    超级电容器 DIP 10F -20~+80% 2.5V
DZ-2R5D106T 数据手册
UPGRADE DZ,DZH DZ,DZH ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” Standard, Large Capacitance Type Capacitors ● ● Pollution-Free ; with no pollutants such as Cd or Pb. Unlike batteries ; excellent charge and discharge characteristics with no chemical reactions 60˚C GREEN CAP ® ® 2.5V 70˚C 2.7V Large capacitance DZH Specifications DZ Marking color : White print on a black sleeve Item Performance Series name Series DZ Series DZH Category temperature range (℃) ー25 to +70 ー25 to +60 Tolerance at rated capacitance (%) ー20 to +80 ー20 to +80 Internal resistance at 1kHz Refer to the following page Characteristics at high and low temperature Endurance Percentage of capacitance change Within ±30% of the value at 20℃ Percentage of capacitance change Internal resistance Less than five times of the value at 20℃ Internal resistance Test temperature 70℃ Test temperature 60℃ Test time 1000 hours Test time 2000 hours Percentage of capacitance change Within ±30% of the initial measured value Percentage of capacitance change Within ±30% of the initial measured value Internal resistance Less than four times of the initial specified value Internal resistance Less than four times of the initial specified value Shelf life Same as endurance Within ±30% of the value at 20℃ Less than eight times of the value at 20℃ Same as endurance Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Unit : mm 2‒φ2 Sleeve φD+1max. F±0.5 φD+0.5max. 16 7.5 0.8 1 α 8 10 12.5 3.5 5.0 0.6 2.0 0. 6.3 2.5 1.5±0.1 Markings L+2max. 6.3±1 Vent 18 ± φD F φd 5 min. 15min. 10 10 L+α max. Lug terminal details 0.9±0.1 Thickness : 0.8t 2.6 φd±0.05 copper clad steel wire (tinned) Sleeve Vent φ25, 35 6.8 7.5 φ6.3 to φ18 (‒) Negative terminal indicated by cross notching Position of printed circuit board holes 2.1 Part numbering system (example : 2.5V10F) DZ Series code ̶ 2R5 D 106 (Z6)(S) Max. operating voltage symbol Terminal code Rated capacitance symbol Casing symbol T ̶ Taping (Forming) symbol Part number is refer to the following page. EDLC CAT.No.2015/2016E 212 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. Standard Ratings (Series DZ 2.5V) Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h ELNA Parts No. φD×L (mm) DZ,DZH Internal resistance (Ω max.) at 1kHz UPGRADE ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP” ® Internal resistance (mΩ) at 1kHz (measurement value) 2.5 1 0.1 DZ-2R5D105F4T 6.3×14 1.0 400 2.5 1 0.1 DZ-2R5D105G3T 8×12 1.0 200 2.5 2.7 0.2 DZ-2R5D275G5ST 8×20 0.5 150 2.5 3.3 0.2 DZ-2R5D335H5T 10×20 0.3 70 2.5 4.7 0.3 DZ-2R5D475H5T 10×20 0.2 80 2.5 5.6 0.3 DZ-2R5D565H5T 10×20 0.2 70 2.5 6.8 0.4 DZ-2R5D685H6T 10×25 0.2 60 40 2.5 10 0.5 DZ-2R5D106H8T 10×35 0.2 2.5 10 0.5 DZ-2R5D106Z6ST 12.5×25 0.2 40 2.5 15 0.7 DZ-2R5D156Z8ST 12.5×35 0.2 35 2.5 15 0.7 DZ-2R5D156J5T 16×20 0.2 35 2.5 22 0.8 DZ-2R5D226J6T 16×25 0.2 30 2.5 33 0.8 DZ-2R5D336J8T 16×35.5 0.2 30 2.5 40 0.8 DZ-2R5D406K9T 18×40 0.2 30 2.5 50 1.0 DZ-2R5D506T 25×40 0.08 20 2.5 100 1.0 DZ-2R5D107S37T 25×50 0.08 15 2.5 200 2.0 DZ-2R5D207S57T 35×50 0.08 15 We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required. Standard Ratings (Series DZ 2.7V) Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h ELNA Parts No. φD×L (mm) Internal resistance (Ω max.) at 1kHz Internal resistance (mΩ) at 1kHz (measurement value) 2.7 1 0.2 DZ-2R7D105F4T 6.3×14 1.0 400 2.7 1 0.2 DZ-2R7D105G3T 8×12 1.0 200 2.7 2.7 0.3 DZ-2R7D275G5ST 8×20 0.5 150 2.7 3.3 0.3 DZ-2R7D335H5T 10×20 0.3 70 2.7 4.7 0.4 DZ-2R7D475H5T 10×20 0.2 80 2.7 5.6 0.4 DZ-2R7D565H5T 10×20 0.2 70 2.7 6.8 0.5 DZ-2R7D685H6T 10×25 0.2 60 40 2.7 10 0.6 DZ-2R7D106H8T 10×35 0.2 2.7 10 0.6 DZ-2R7D106Z6ST 12.5×25 0.2 40 2.7 15 0.8 DZ-2R7D156Z8ST 12.5×35 0.2 35 2.7 15 0.8 DZ-2R7D156J6T 16×25 0.2 35 2.7 22 1.0 DZ-2R7D226J7T 16×31.5 0.2 30 2.7 33 1.0 DZ-2R7D336J9T 16×40 0.2 30 We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required. Standard Ratings (Series DZH 2.5V) Max. operating voltage (V) Rated capacitance (F) Max. Leakage Current (mA) after 24h ELNA Parts No. 2.5 22 0.8 DZH-2R5D226Z8ST 2.5 50 1.0 DZH-2R5D506K9T φD×L (mm) 12.5×35 Internal resistance (Ω max.) at 1kHz Internal resistance (mΩ) at 1kHz (measurement value) 0.2 55 18×40 0.08 30 2.5 100 2.0 DZH-2R5D107S35T 25×40 0.08 20 2.5 300 5.0 DZH-2R5D307S57T 35×50 0.08 15 We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required. EDLC NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 213 CAT.No.2015/2016E
DZ-2R5D106T 价格&库存
很抱歉,暂时无法提供与“DZ-2R5D106T”相匹配的价格&库存,您可以联系我们找货
