DH-5R5D224T
DH-5R5D224T
    ELNAAMERICA
    DIP
    超级电容器 DIP 220mF -20~+80% 5.5V
DH-5R5D224T 数据手册
DH ELECTRIC ELECTRICDOUBLE DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” High Temperature Capacitors ● ● GREEN CAP ® ® 85˚C High temperature tolerant (−25 to +85℃) and highly reliable. Ideal for backing up of controls, electronic rice cooking jars, home bakeries and the like. DH High temperature Miniaturized DB DX Marking color : White print on an indigo sleeve Specifications Item Performance Category temperature range (℃) ー25 to +85 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance at 1 kHz Rated capacitance (F) Characteristics at high and low temperature Percentage of capacitance change Endurance (85℃) Percentage of capacitance change 0.047 0.1 0.22 0.47 0.68 1 300 200 120 50 50 30 Internal resistance (Ω Max.) Within ±30% of the value at 20℃ Internal resistance Less than five times of the value at 20℃ Test time 1000 hours Within ±30% of the initial measured value Internal resistance Less than four times of the initial specified value Shelf life (85℃) Test time : 1000 hours ; Same as endurance. Applicable standards Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Outline Drawing Unit : mm Part numbering system (example : 5.5V0.1F) Sleeve 0.5±0.1 ̶ 5R5 Max.operating voltage symbol D 104 T Rated capacitance symbol φD Max 6.0±1 Part number is refer to following table. (4.0±0.5) (3.0±0.5) 6.0±1 Series code 0.8±0.1 5.0±0.3 L Max DH 1.2±0.1 Sn plated teminal Standard Ratings Max. operating voltage (V) Rated capacitance (F) ELNA Parts No. φD×L (mm) 5.5 0.047 DH-5R5D473T 13.5×9.5 5.5 0.1 DH-5R5D104T 13.5×9.5 5.5 0.22 DH-5R5D224T 13.5×9.5 5.5 0.47 DH-5R5D474T 21.5×9.5 5.5 0.68 DH-5R5D684T 21.5×9.5 5.5 1 DH-5R5D105T 21.5×9.5 EDLC CAT.No.2015/2016E 206 NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use.
DH-5R5D224T 价格&库存
很抱歉,暂时无法提供与“DH-5R5D224T”相匹配的价格&库存,您可以联系我们找货
