Effective July 2020
Supersedes September 2016
Technical Data 4422
KW Supercapacitors
Coin cells
HALOGEN
Pb HF
FREE
Features and benefits
High specific capacitance
Low leakage current
Long cycle life
Eco-friendly
Broad operating range,
full specification -40 °C to +85 °C
Applications
Description
Eaton supercapacitors are unique, ultrahigh
capacitance devices utilizing electric double layer
capacitor (EDLC) construction combined with
new, high performance materials. This
combination of advanced technologies allows
Eaton to offer a wide variety of capacitor solutions
tailored to specific applications that range from
a few microamps for several days to several
milliamps formilliseconds.
All products feature low ESR for high power
density with environmentally friendly materials for
a green power solution. Eaton supercapacitors are
maintenance-free with design lifetimes up to
20 years* and operating temperatures down to
-40 °C and up to +85 °C.
Electric utilitymeters
Motor control units
Solar inverters
Real-Time Clock (RTC) backup
Programmable Logic Controllers (PLCs)
Irrigation and water control systems
*Supercapacitor lifetimes vary based on
charge voltage and temperature. See
Eaton’s application guidelines or contact
your local Eaton sales representative for
more information on lifetime estimates
KW Supercapacitors
Coin cells
Technical Data 4422
Effective July 2020
Specifications1
Capacitance
0.1 F to 1.0 F
Working voltage
5.5 V
Surge voltage
6.3 V
Capacitance tolerance
-20% to +80% (+20 °C)
Operating temperature range2
-40 °C to +85 °C
Standard Product
Capacitance (F)
Part number
Lead length
Maximum initial ESR (Ω) (Equivalent series
resistance) measured @ 1 kHz
Typical mass (g)
0.1
KW-5R5C104-R
Standard
50
3.7
0.1
KW-5R5C104H-R
Short
50
3.7
0.22
KW-5R5C224-R
Standard
50
3.7
0.22
KW-5R5C224H-R
Short
50
3.7
0.33
KW-5R5C334-R
Standard
50
3.7
0.33
KW-5R5C334H-R
Short
50
3.7
0.68
KW-5R5C684-R
Standard
30
10.2
0.68
KW-5R5C684H-R
Short
30
10.2
1.0
KW-5R5C105-R
Standard
30
10.4
1.0
KW-5R5C105H-R
Short
30
10.4
Performance
Parameter
Capacitance change
(% of initial value)
ESR
(% of maximum initial value)
Life — +85 °C @ 5.5 Vdc, 2000 hours
≤ 30%
≤ 200%
Storage Life — -40 °C to +85 °C, 2000 hours
≤ 30%
≤ 200%
1. Testing and verification of product under end application conditions is recommended
2. Not recommended for +85 °C/85% RH applications
2
www.eaton.com/electronics
KW Supercapacitors
Coin cells
Technical Data 4422
Effective July 2020
Dimensions (mm)
KW-5R5C684/105-R
KW-5R5C104/224/334-R
Polarity marking
location
D
Polarity marking
location
Sleeve
D
Sleeve
H Max
L(-)
H Max
L1 L2
L(+)
P
T
5.00
Recommended PCB layout
Part number
H
Max
L(-)
±0.2
L(+)
±0.2
P
±0.3
T
±0.1
1.60 ±0.05
L1
±0.1
L2
±0.1
KW-5R5C104-R
6.1
5.7
3.0
4.0
3.3
3.3
0.9
1.9
KW-5R5C224-R
6.1
5.7
3.0
4.0
3.3
3.3
0.9
1.9
KW-5R5C334-R
6.1
5.7
3.0
4.0
KW-5R5C334H-R
3.3
3.3
0.9
1.9
KW-5R5C684-R
6.5
5.8
3.0
4.0
13.5
KW-5R5C684H-R
8.30
21.5
KW-5R5C105-R
W
W1
P
KW-5R5C104H-R
KW-5R5C224H-R
L2
5.00
1.60 ±0.05
ØD
Max
L1
L(+)
L(-)
W
W1
T
8.85
KW-5R5C105H-R
5.0
0.4
3.3
3.3
0.8
1.8
6.5
5.8
3.0
4.0
3.3
3.3
0.8
1.8
W
±0.06
W1
±0.06
0.8
1.3
Part numbering system
KW
5
R
5
C
o
Voltage (V)
R = Decimal
Configuration
5R5 = 5.5 V
V = Vertical
H = Horizontal
C=Cylindrical
Family Code
o
o
o
H*
-R
Short lead length
Standard product
Capacitance (μF)
Value
Multiplier
Example: 474 = 47 x 104 μF or 0.47 F
* If ordering standard lead length, omit “H” from part number.
Packaging information
Standard bulk packaging:
• KW-5R5C104/224/334-R—400 parts
• KW-5R5C684/105-R—500 parts
Part marking
Manufacturer
Capacitance (F)
Maximum operating voltage (V)
Polarity
3
KW Supercapacitors
Coin cells
Technical Data 4422
Effective July 2020
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Preheat area
Cool down area
Time
Profile feature
Standard SnPb solder
Lead (Pb) Free solder
• Temperature max. (Tsmax)
100 °C
100 °C
• Time max.
60 seconds
60 seconds
D preheat to max temperature
160 °C max.
160 °C max.
Peak temperature (TP)*
235 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Preheat and soak
Manual solder
Do not touch the supercapacitor’s external sleeve with the soldering rod or the sleeve will melt or crack. The recommended temperature
of the soldering rod tip is less than +260 °C (maximum: +350 °C) and the soldering duration should be less than 5 seconds. Minimize the
time that the soldering iron is in direct contact with the terminals of the supercapacitor as excessive heating of the leads may lead to
higher equivalent series resistance (ESR).
Reflow soldering
Do not use reflow soldering using infrared or convection oven heating methods.
Cleaning/Washing
Avoid cleaning of circuit boards, however if the circuit board must be cleaned use static or ultrasonic immersion in a standard circuit board
cleaning fluid for no more than 5 minutes and a maximum temperature of +60 °C. Afterwards thoroughly rinse and dry the circuit boards.
In general, treat supercapacitors in the same manner you would an aluminum electrolytic capacitor.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2020 Eaton
All Rights Reserved
Printed in USA
Publication No. 4422
July 2020
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“KW-5R5C224-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+41.36400
- 10+40.47840
- 30+39.88440
- 国内价格
- 1+42.65508
- 100+41.70742
- 200+40.82225
