PHV-5R4V255-R
PHV-5R4V255-R
    EATON(伊顿)
    插件,P=5.3mm
    超级电容器 DIP 2.5F -10~+30% 5.4V
PHV-5R4V255-R 数据手册
Effective June 2017 Supersedes August 2013 Technical Data 4403 PHV Supercapacitors Cylindrical pack HALOGEN HF Pb FREE Features • • Large capacitance for high energy density Ultra-low ESR for high power density Applications • • Description Eaton supercapacitors are unique, ultra-high capacitance devices utilizing electrochemical double layer capacitor (EDLC) construction combined with new, high performance materials. This combination of advanced technologies allows Eaton to offer a wide variety of capacitor solutions tailored to specific applications that range from a few micro-amps for several days to several amps for milliseconds. Pulse Power Bridging or hold-up power PHV Supercapacitors   Technical Data 4403 Effective June 2017 Ratings Capacitance 0.5 F to 5.0 F Maximum working voltage 5.4 V Surge voltage 6.0 V Capacitance tolerance -10% to +30% (+20 °C) Operating temperature range -40 °C to +65 °C Extended operating temperature range -40 °C to +85 °C (with linear derating to 4.0 V @ +85 °C) Specifications Nominal Capacitance (F) Vertical Part Number Horizontal Part Number Maximum ESR (Ω) (Equivalent Series Resistance) Measured @ 1 kHz 100Hz Nominal leakage current (µA) after 100 hours @ 5 V, +20°C Nominal dimensions (mm) Typical mass (grams/piece) 0.5 PHV-5R4V474-R PHV-5R4H474-R 0.300 0.40 13 8.5 x 16.8 x 14.0 2.6 1.5 PHV-5R4V155-R PHV-5R4H155-R 0.120 0.16 18 8.5 x 16.8 x 21.5 3.0 2.5 PHV-5R4V255-R PHV-5R4H255-R 0.075 0.08 24 10.5 x 20.8 x 22.5 4.5 3.0 PHV-5R4V305-R PHV-5R4H305-R 0.075 0.08 25 8.5 x 16.8 x 31.5 4.8 5.0 PHV-5R4V505-R PHV-5R4H505-R 0.065 0.07 28 10.5 x 20.8 x 32 6.8 Performance Parameter Capacitance change (% of initial value) ESR (% of max. initial value) Life (1000 hours @ +65 °C @ 5.4 Vdc) ≤ 30% ≤ 200% Storage - Low and High Temperature (1000 hours @ -40 °C and +85 °C) ≤ 30% ≤ 200% Dimensions (mm) Vertical Part Number Horizontal Part Number A B C d’ D D’ E E’ F P PHV-5R4V474-R PHV-5R4H474-R 9.0 17.3 14.5 0.5 20 15 25 20 2.0 11.8 PHV-5R4V155-R PHV-5R4H155-R 9.0 17.3 22.0 0.5 20 15 25 20 2.0 11.8 PHV-5R4V255-R PHV-5R4H255-R PHV-5R4V305-R PHV-5R4H305-R PHV-5R4H505-R 11.0 21.3 9.0 17.3 11.0 21.3 Maximum 23.0 32.5 32.5 0.6 0.5 0.6 ± 0.02 20 20 20 15 15 15 25 25 25 20 20 20 2.0 2.0 2.0 ± 0.5 5.3 11.8 5.3 PHV-5R4V505-R Tolerances Minimum Note: Longer lead is positive. B Vertical C B Horizontal F C A A d' d' C C A A D F P E D' E' P Positive lead Positive lead P Part numbering system P HV Family Code Version — 5R4 V Voltage (V) R = Decimal Configuration 5R4 = 5.4 V V = Vertical H = Horizontal 15 5 -R Multiplier Standard product Capacitance (µF) P= Pack Packaging information • • 2 Standard packaging: Bulk, 100 units per bag Larger bulk packages available on request www.eaton.com/electronics Value Example: 155 = 15 x 105 or 1.5 F Part marking • • • Manufacturer Capacitance (F) Maximum operating voltage (V) • • Family code (or part number) Polarity marking PHV Supercapacitors Cylindrical pack Technical Data 4403 Effective June 2017 Wave solder profile tp Temperature Tp First Wave Second Wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Profile Feature Standard SnPb Solder Lead (Pb) Free Solder • Temperature max. (Tsmax) 100 °C 100 °C • Time max. 60 seconds 60 seconds D preheat to max Temperature 160 °C max. 160 °C max. Peak temperature (TP)* 220 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Preheat and soak Manual solder +350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended. Reflow soldering Do not use reflow soldering using infrared or convection oven heating methods. Cleaning/Washing Avoid cleaning of circuit boards, however if the circuit board must be cleaned use static or ultrasonic immersion in a standard circuit board cleaning fluid for no more than 5 minutes and a maximum temperature of +60 °C. Afterwards thoroughly rinse and dry the circuit boards. In general, treat supercapacitors in the same manner you would an aluminum electrolytic capacitor. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronoics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4403 BU-SB13841 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
PHV-5R4V255-R 价格&库存
很抱歉,暂时无法提供与“PHV-5R4V255-R”相匹配的价格&库存,您可以联系我们找货
PHV-5R4V255-R
  • 1+63.01626
  • 5+58.36879
  • 10+55.12276
  • 25+50.66694
  • 35+49.27749
  • 50+47.88804
  • 65+47.04958
  • 100+45.83981
  • 500+43.24058
PHV-5R4V255-R
  • 100+68.54700
  • 200+67.17550
  • 400+65.16042
库存:100
PHV-5R4V255-R
  • 1+87.515391+11.31812
  • 10+66.2227910+8.56441
  • 50+57.7226050+7.46511
  • 100+55.09170100+7.12486
  • 500+50.63688500+6.54873
  • 1000+49.256581000+6.37022
库存:2175
