PM-5R0V104-R
PM-5R0V104-R
    EATON(伊顿)
    插件,P=7.3mm
    超级电容器 DIP 100mF -20~+80% 5V
PM-5R0V104-R 数据手册
PowerStor  Provisional Aerogel Capacitors PM Series Description Cooper Bussmann PowerStor supercapacitors are unique, ultra-high capacitance devices utilizing electrochemical double layer capacitor (EDLC) construction combined with new, high performance materials. This combination of advanced technologies allows Cooper Bussmann to offer a wide variety of capacitor solutions tailored to specific applications that range from a few microamps for several days to several amps for a few milliseconds. LEADED DEVICE SERIES FEATURES AND BENEFITS Generic PM APPLICATIONS Specific 5.0 volts, Low ESR, High capacitance Long cycle life Low leakage currents RoHS compliant Low ESR with high energy density Pulse Power Bridge or Hold Up Power SPECIFICATIONS Working Voltage (maximum) Surge Voltage Nominal Capacitance Range Capacitance Tolerance Operating Temperature Range Extended Operating Temperature Range 5.0 volts 5.5 volts 0.1F to 3F -20% to +80% (20°C) -40°C to 60°C -40°C to 85°C (Max. working voltage: 3.9V) STANDARD PRODUCTS HIGH ENERGY DENSITY & ULTRA LOW ESR (PM SERIES) Nominal Capacitance (F) 0.1 0.47 1.0 1.5 3.0 Part Number PM-5R0V104-R PM-5R0H104-R PM-5R0V474-R PM-5R0H474-R PM-5R0V105-R PM-5R0H105-R PM-5R0V155-R PM-5R0H155-R PM-5R0V305-R PM-5R0H305-R Nominal ESR (Ω) (Equivalent Series Resistance) Nominal Leakage Current (µA) @ 20°C after 100 Hours Nominal Dimensions Typical Mass (grams/piece) TBD 5.5 x 10.8 x 12.5 mm 1.1 Measured @ 1kHz 1.25 Measured @ DC 1.5 0.30 0.40 TBD 8.5 x 16.8 x 14.0 mm 2.4 0.15 0.20 TBD 8.5 x 16.8 x 21.5 mm 3.5 0.07 0.10 15 10.5 x 20.8 x 22.5 mm 5.4 0.05 0.07 20 10.5 x 20.8 x 32 mm 7.8 PERFORMANCE Parameter Life (1000 hrs @ 60°C @ 5 volts DC) Storage- Low and High Temperature (1000 hrs @ -40°C and 85°C) Capacitance Change (% of initial specified value) ≤ 30 % ESR (% of initial specified value) ≤ 200 % ≤ 30 % ≤ 200 % Visit us on the Web at www.cooperet.com 1225 Broken Sound Parkway, NW, Suite F, Boca Raton, Florida 33487-3533 Tel: +1-561-998-4100 Toll Free: +1-888-414-2645 Fax: +1-561-241-6640 PowerStor  Aerogel Capacitors PM Series DIMENSIONS (mm) Part Number PM-5R0V104-R PM-5R0H104-R PM-5R0V474-R PM-5R0H474-R PM-5R0V105-R PM-5R0H105-R PM-5R0V155-R PM-5R0H155-R PM-5R0V305-R PM-5R0H305-R A B C d’ D D’ E E’ F P 6.0 11.3 13.0 0.5 20 15 25 20 2.0 7.3 9.0 17.3 14.5 0.5 20 15 25 20 2.0 11.8 9.0 17.3 22.0 0.5 20 15 25 20 2.0 11.8 11.0 21.3 23.0 0.6 20 15 25 20 2.0 5.3 21.3 32.5 0.6 20 15 25 20 2.0 11.0 Tolerances Maximum ± 0.02 Minimum 5.3 ± 0.5 Note (1): Longer lead is positive. B C B F C A A d' d' C C A A D D' F E E' P P P VERTICAL HORIZONTAL PART NUMBERING SYSTEM P Series Code M Version P = Pack - 5 R 0 Voltage (V) R is decimal 5R0 = 5.0V - Configuration V = Vertical - or H = Horizontal R Capacitance (µ F) Value Multiplier RoHS Complaint 4 Example: 474 = 47 x 10 µ F or 0.47 F PACKAGING INFORMATION Standard packaging: Bulk, 100 units per package. Larger bulk packages available upon request. PART MARKING Manufacturer Capacitance (F) Max. Operating Voltage (V) Series Code (or part number) Polarity Rev X7 07/08 Visit us on the Web at www.cooperet.com  Cooper Electronic 1225 Broken Sound Parkway, NW, Suite F, Boca Raton, Florida 33487-3533 Tel: +1-561-998-4100 Toll Free: +1-888-414-2645 Fax: +1-561-241-6640 Technologies 2008 This bulletin is intended to present product design solutions and technical information that will help the user with design applications. Cooper Electronic Technologies reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Electronic Technologies also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
PM-5R0V104-R 价格&库存
很抱歉,暂时无法提供与“PM-5R0V104-R”相匹配的价格&库存,您可以联系我们找货
PM-5R0V104-R
  • 1+50.867621+6.58051
  • 10+37.0253110+4.78979
  • 50+31.5152950+4.07699
  • 100+29.81020100+3.85641
  • 500+26.92356500+3.48298
  • 1000+26.029401000+3.36730
  • 2500+25.084592500+3.24508
PM-5R0V104-R
