Effective October 2017
Supersedes March 2015
Technical Data 4393
PB Supercapacitors
Cylindrical pack
HALOGEN
Pb HF
FREE
Features
5.0 Volts
Low Equivalent Series Resistance (ESR)
High capacitance
Long cycle life
Low leakage currents
UL recognized
Applications
Description
Eaton PowerStor supercapacitors are unique, ultrahigh capacitance devices utilizing electrochemical
double layer capacitor (EDLC) construction
combined with new, high performance materials.
This combination of advanced technologies allows
Eaton to offer a wide variety of capacitor solutions
tailored to specific applications that range from a
few micro-amps for several days to several amps
for milliseconds.
Bridge or hold-up power
Memory backup
Battery swap out
PB Supercapacitors
Cylindrical pack
Technical Data 4393
Ratings
Capacitance
0.1 F to 1.0 F
Maximum working voltage
5.0 V
Surge voltage
6.0 V
Capacitance tolerance
-20% to +80% (+20 °C)
Operating temperature range
- 25 °C to +70 °C
extended to +85 °C
Specifications
Nominal
Capacitance (F)
Vertical
Part Number
Horizontal
Part Number
Maximum Initial ESR
(Ω) (Equivalent Series
Resistance) Measured
@ 100 Hz
Nominal leakage
current (μA) after
72 hours @ +20 °C
Nominal
dimensions (mm)
Typical mass
(grams/piece)
0.1
PB-5R0V104-R
PB-5R0H104-R
4.0
3
5.5 x 10.8 x 12.5
1.1
0.47
PB-5R0V474-R
PB-5R0H474-R
1.0
7
8.5 x 16.8 x 14.0
2.4
1.0
PB-5R0V105-R
PB-5R0H105-R
0.5
12
8.5 x 16.8 x 21.5
3.5
Performance
Parameter
Capacitance change
(% of initial value)
ESR
(% of max. initial value)
Life (1000 hours @ +70 °C, 5.0 Vdc or +85 °C, 4.2 Vdc)
≤ 30%
≤ 300%
Storage - Low and High Temperature (1000 hours @ -25 °C to +70 °C)
≤ 30%
≤ 300%
Dimensions (mm)
Vertical Part Number
Horizontal Part Number
A
B
C
d’
D
D’
E
E’
F
P
PB-5R0V104-R
PB-5R0H104-R
6.0
11.3
13.0
0.5
25
7.3
PB-5R0V474-R
PB-5R0H474-R
9.0
17.3
14.5
0.5
25
11.8
PB-5R0V105-R
PB-5R0H105-R
9.0
17.3
22.0
0.5
25
11.8
Tolerances
Maximum
B
Minimum
± 0.02
B
C
F
± 0.5
C
A
A
d'
d'
C
C
A
A
D
E
D'
F
P
E'
P
Positive lead
Positive lead
P
Vertical
Horizontal
Part numbering system
P
B
5
R
V
47
4
-R
Multiplier
Standard
product
Capacitance (μF)
Family Code
Version
Voltage (V) R = Decimal
Configuration
P Family
B-High capacitance
5R0 = 5.0 V
V = Vertical
H = Horizontal
Packaging information
Standard packaging: Bulk, 100 units per bag
Larger bulk packages available on request
www.eaton.com/electronics
Example: 474 = 47 x 474 or 0.47 F
Part marking
2
Value
Manufacturer
Capacitance (F)
Max Operating Voltage (V)
Family Code (or part number)
Polarity
PB Supercapacitors
Cylindrical pack
Technical Data 4393
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Profile Feature
Standard SnPb Solder
Lead (Pb) Free Solder
• Temperature max. (Tsmax)
100 °C
100 °C
• Time max.
60 seconds
60 seconds
D preheat to max Temperature
160 °C max.
160 °C max.
Peak temperature (TP)*
220 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Preheat and soak
Manual solder
+350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
Reflow soldering
Do not use reflow soldering using infrared or convection oven heating methods.
Cleaning/Washing
Avoid cleaning of circuit boards, however if the circuit board must be cleaned use static or ultrasonic immersion in a standard circuit board
cleaning fluid for no more than 5 minutes and a maximum temperature of +60 °C. Afterwards thoroughly rinse and dry the circuit boards. In
general, treat supercapacitors in the same manner you would an aluminum electrolytic capacitor.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4393
October 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“PB-5R0H474-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.163791+5.03980
- 5+36.353835+4.67820
- 10+34.3341810+4.41830
- 30+30.9973530+3.98890
- 40+30.3826740+3.90980
- 50+29.9436250+3.85330
- 60+29.5045660+3.79680
- 100+28.71426100+3.69510
- 500+27.13366500+3.49170
