DBJ
DBJ
ELECTRIC
ELECTRICDOUBLE
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS“DYNACAP”
“DYNACAP”
5.5V Low Profile and High Temperature Capacitors
High temperature type of series DB.
Small-sized, large capacity, excellent voltage holding.
For all ratings, uniform 5mm pitch of terminal spacing.
φ13.5×7.5L size can encase up to 0.33F.
Ideal for backing up of CMOS’
s, IC’
s,
microcomputers, RAM’
s, RTC’
s and the like
used in Video’
s, tuners, TV sets,
telephone sets and others.
GREEN
CAP
85˚C
DH
Low profile
High temperature
DBJ
Marking color : White print on a black sleeve
DB
Specifications
Item
Performance
Category temperature range (℃)
ー10 to +85
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
0.047
0.1
0.22
0.33
0.47
1
Internal resistance (Ω Max.)
200
150
150
150
100
75
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (85℃)
Within ±30% of the value at 20℃
Internal resistance
Less than four times of the initial specified value.
Test time
1000 hours
Within ±30% of the initial measured value
Internal resistance
Test time : 1000 hours ; Same as endurance.
Shelf life (85℃)
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
Part numbering system (example : 5.5V0.1F)
Sleeve
0.5±0.1
5R5
Max.operating voltage
symbol
D
104
T
Rated capacitance
symbol
φD Max
6.0±1
Part number is refer to following table.
(4.0±0.5)
(3.0±0.5)
6.0±1
Series code
0.8±0.1
5.0±0.3
L Max
DBJ
1.2±0.1
Sn plated teminal
Standard Ratings
Max. operating voltage (V)
ELNA Parts No.
5.5
0.047
DBJ-5R5D473T
13.5×7.5
5.5
0.1
DBJ-5R5D104T
13.5×7.5
5.5
0.22
DBJ-5R5D224T
13.5×7.5
5.5
0.33
DBJ-5R5D334T
13.5×7.5
5.5
0.47
DBJ-5R5D474T
21.5×8.0
5.5
1
DBJ-5R5D105T
21.5×8.0
φD×L (mm)
EDLC
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
199
CAT.No.2015/2016E
很抱歉,暂时无法提供与“DBJ-5R5D104T”相匹配的价格&库存,您可以联系我们找货
