DZN
ELECTRIC DOUBLE LAYER CAPACITORS “DYNACAP”
GREEN
CAP
High power type Capacitors
70˚C
Low ESR
• Low internal resistance allows boosting charge and heavy-current discharge.
(ampere level)
• Pollution-Free ; with no pollutants such as Cd or Pb.
High power
• Unlimited number of charges
and discharges.
DZN
DZ
Marking color : White print on a blue sleeve
Specifications
Item
Performance
Category temperature range (˚C)
−25 to +70
Tolerance at rated capacitance (%)
−20 to +80
Internal resistance
Rated Capacitance (F)
0.7
1.0
3.3
4.7
10
100
at 1 kHz
Internal resistance (Ω)
0.4
0.3
0.2
0.10
0.10
0.10
0.03
0.03
Characteristics at high
Percentage of capacitance change
and low temperature
Internal resistance
Endurance (70˚C)
Within ±30% of value at 20˚C
Less than five times of the value at 20˚C
Test time
1000 hours
Within ±30% of the initial measured value
Within four times of the initial specified value
Internal resistance
Test time :1000 hours ; Same as endurance.
Shelf life (70˚C)
Outline Drawing
Unit: mm
d±0.05
copper clad steel wire(tinned)
Sleeve
Vent
25, 35
2– 2
Sleeve
10
2.6
F±0.5
D+1max.
.1
D+0.5max.
±0
10
L+α max.
1.5±0.1
Markings
5
min.
15min.
L+2max.
øD
F
ød
α
8
3.5
12.5
5.0
0.6
6.3±1
Vent
18
7.5
0.8
Lug terminal details
0.9±0.1 Thickness:0.8t
6.8
18
(–)Negative terminal
indicated by cross notching
Position of printed
circuit board holes
7.5
8 to
2.1
2.0
Standard Ratings
Max. Leakage Current(mA) after 24h
ELNA Parts No.
ø DxL(mm)
Internal resistance(mΩ)
at 1kHz (measurement value)
2.5
0.7
0.1
DZN-2R5D704G4T
8.0x15.0
200
2.5
1.0
0.1
DZN-2R5D105T
8.0x22.0
100
2.5
3.3
0.2
DZN-2R5D335T
12.5x23.0
40
2.5
4.7
0.3
DZN-2R5D475T
12.5x31.5
30
Max. operating voltage(V)
Rated capacitance(F)
2.5
10
0.5
DZN-2R5D106T
18.0x35.0
DZN-2R5D206T
18.0x40.0
50
1.0
DZN-2R5D506T
25.0x40.0
15
2.5
100
1.0
DZN-2R5D107T
35.0x50.0
8
∗ Internal resistance are not guaranteed values, but measurement value.
∗ We tailor packaged product in series and parallel arrangements according to voltage and capacitance as required.
Part numbering system (example: 2.5V10F)
DZN
Series code
2R5
Rated voltage
symbol
CAT.No.2005/2006E(2005.10.1)
D
106
T
Rated capacitance
symbol
152
NOTE
Design, Specifications are subject to change without notice.
Ask factory for technical specifications before purchase and/or use.
很抱歉,暂时无法提供与“DZN-2R5D206T”相匹配的价格&库存,您可以联系我们找货
