DC,DCK-614,621
DC,DCK-614,621
ELECTRIC
DOUBLE
LAYERCAPACITORS
ELECTRIC
DOUBLE
LAYER
CAPACITORS
“DYNACAP”
CAPACITORS “DYNACAP”
GREEN 60℃
CAP
70℃
Coin Cell Capacitors
Unlike batteries, the number of charging /
discharging cycles unlimited and rapid
charging / discharging is possible.
High reliability, Safe and unlike secondary
batteries, this is pollution free devices.
1.8mm height 614type made lineup in the DC,
DCK Series.
Low profile
DC
DC
(614)
(621)
For higher
voltage
tolerant
Low profile
DCK
DCK
(614)
(621)
Specifications
Item
Performance
Series Name
Series DC
Max. operating voltage (V)
2.5
3.3
Category temperature range (℃)
ー25 to +70
ー10 to +60
Tolerance at rated capacitance (%)
ー20 to +80
ー20 to +80
Internal resistance (Ω)
at 1 kHz
Series DCK
Size code
614
621
Size code
614
Rated capacitance (F)
0.2
0.4
0.2
0.4
Internal resistance (ΩMax.)
100
100
200
200
Size code
614
621
Size code
614
621
621
Characteristics at high
and low temperature
Percentage of capacitance change Within ±30% of the value at 20℃ Within ±30% of the value at 20℃
Endurance
614
621
Size code
Test time and temp
70℃ 1000 hours
70℃ 500 hours
Percentage of capacitance change Within ±30% of the initial measured value Within ±40% of the initial measured value
Internal resistance
400Ω Max.
1kΩ Max.
Size code
614
621
Test time and temp
60℃ 1000 hours
60℃ 500 hours
Internal resistance
800Ω Max.
2kΩ Max.
Shelf life
Same as endurance.
Same as endurance.
Internal resistance
Percentage of capacitance change Within ±50% of the value at 20℃ Within ±50% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃ Less than five times of the value at 20℃
Applicable standards
Less than five times the initial specified value Less than five times of the value at 20℃
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
Terminal shaped : E
1.8MAX(614)
2.6MAX(621)
L+0.1
ー0.2 (614)
φD±0.2
L±0.2(621)
Sn plated
1.7±0.3
2.5±0.3
0.5
0.15±0.05
0.5±0.1
2.0±0.3
Part numbering system (example : 614,2.5V0.2F, terminal shaped : E)
DC
Series code
2R5
symbol
E
T 614 ̶ E
204
Rated capacitance
symbol
Part numbering system (example : 621, 3.3V0.4F, terminal shaped : E)
DCK
Additional
symbol
Series code
Part number is refer to following table.
3R3
symbol
E
404
T
̶ E
Rated capacitance Additional
symbol
symbol
ELNA Parts No.
φD×L (mm)
2.5
0.2
DC-2R5E204T614-E
6.8×1.4
3.3
0.2
DCK-3R3E204T614-E
6.8×1.4
2.5
0.4
DC-2R5E404T-E
6.8×2.1
3.3
0.4
DCK-3R3E404T-E
6.8×2.1
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
209
CAT.No.2015/2016E
EDLC
Standard Ratings
很抱歉,暂时无法提供与“DCK-3R3D204T614”相匹配的价格&库存,您可以联系我们找货
