DK-6R3D684T
DK-6R3D684T
    ELNAAMERICA
    DIP
    超级电容器 DIP 680mF -20~+80% 6.3V
DK-6R3D684T 数据手册
High Voltage Tolerance Capacitors ● ● DK DK ELECTRIC DOUBLELAYER LAYERCAPACITORS CAPACITORS“DYNACAP” “DYNACAP” ELECTRIC DOUBLE ® GREEN CAP 70˚C High voltage tolerant (6.3V guaranteed) and highly reliable. Ideal for backing up of Li-battery-backed equipment such as cameras, video and telephone sets. Miniaturized DX High voltage tolerant DB DK Marking color : White print on an indigo sleeve Specifications Item Performance Category temperature range (℃) ー25 to +70 Tolerance at rated capacitance (%) ー20 to +80 Internal resistance at 1 kHz Rated capacitance (F) Characteristics at high and low temperature Percentage of capacitance change Endurance (70℃) Percentage of capacitance change Internal resistance (Ω Max.) 0.047 0.1 0.47 0.68 1 300 200 50 50 30 Within ±30% of the value at 20℃ Internal resistance Less than five times of the value at 20℃ Test time 1000 hours Within ±30% of the initial measured value Internal resistance Less than four times of the initial specified value Test time : 1000 hours ; Same as endurance. Shelf life (70℃) Conforms to JIS C5160-1 2009 (IEC 62391-1 2006) Applicable standards Outline Drawing Unit : mm Part numbering system (example : 6.3V0.1F) Sleeve 0.5±0.1 ̶ 6R3 Max.operating voltage symbol D 104 T Rated capacitance symbol φD Max 6.0±1 Part number is refer to following table. (4.0±0.5) (3.0±0.5) 6.0±1 Series code 0.8±0.1 5.0±0.3 L Max DK 1.2±0.1 Sn plated teminal Standard Ratings Max. operating voltage (V) Rated capacitance (F) ELNA Parts No. φD×L (mm) 6.3 0.047 DK-6R3D473T 13.5×9.5 6.3 0.1 DK-6R3D104T 13.5×9.5 6.3 0.47 DK-6R3D474T 21.5×9.5 6.3 0.68 DK-6R3D684T 21.5×9.5 6.3 1 DK-6R3D105T 21.5×9.5 EDLC NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 205 CAT.No.2015/2016E
DK-6R3D684T 价格&库存
很抱歉,暂时无法提供与“DK-6R3D684T”相匹配的价格&库存,您可以联系我们找货
