Effective October 2016
Supersedes December 2011
Technical Data 4080
M Supercapacitors
Cylindrical cells
HALOGEN
Pb HF
FREE
Features
2.5 Volts
Low ESR
High capacitance long cycle life
Low ESR with high energy density
Low leakage current
UL recognized
Applications
Description
Eaton supercapacitors are unique, ultra-high
capacitance devices utilizing electrochemical
double layer capacitor (EDLC) construction
combined with new, high performance materials.
This combination of advanced technologies
allows Eaton to offer a wide variety of capacitor
solutions tailored to specific applications that
range from a few micro-amps for several days to
several amps for milliseconds.
Pulse Power
Bridge or hold-up power
M Supercapacitors
Cylindrical cells
Technical Data 4080
Ratings
Capacitance
1.0 F to 9.0 F
Maximum working voltage
2.5 V
Surge voltage
3.0 V
Capacitance tolerance
-20% to +80% (+20 °C)
Operating temperature range
-40 °C to +60 °C
Extended temperature range
-40 °C to +85 °C (Maximum working voltage 2.0 V)
Specifications
Capacitance (F)
Part Number
Nominal ESR (Ω)
(Equivalent Series Resistance)
Measured @
1 kHz
100 Hz
1
M0810-2R5105-R
0.210
0.250
8
13
1.2
2
M0820-2R5205-R
0.075
0.100
8
3
M1020-2R5305-R
0.035
0.050
10
20.5
2.8
6
M1030-2R5605-R
0.025
0.035
10
30
3.9
9
M1325-2R5905-R
0.020
0.030
13
26
5.6
Nominal dimensions (mm)
(diameter x length)
Typical Mass
(grams/piece)
Performance
Parameter
Capacitance change
(% of initial value)
ESR
(% of max. initial value)
Life (1000 hours @ +60 °C @ 2.5 Vdc)
≤ 30%
≤ 200%
Storage - Low and High Temperature (1000 hours @ -40 °C and +60 °C)
≤ 30%
≤ 200%
Dimensions (mm)
Part Number
D
D’
L
L’
F
d’
C
C’
M0810-2R5105-R
8.0
8.5
13.0
13.5
3.5
0.50
20.0
5.0
M0820-2R5205-R
8.0
8.5
20.5
21.0
3.5
0.50
20.0
5.0
M1020-2R5305-R
10.0
10.5
21.8
22.3
5.0
0.60
20.0
5.0
M1030-2R5605-R
10.0
10.5
31.0
31.5
5.0
0.60
20.0
5.0
M1325-2R5905-R
13.0
13.5
27.9
28.4
5.0
0.60
20.0
5.0
Tolerances
Maximum
±0.5
±0.02
Minimum
Part marking
Manufacturer
Capacitance (F)
Nominal working voltage (V)
Family code (or part number)
Polarity
Part numbering system
M
1325
Family Code
Size reference
(mm)
M Family
Diameter = 13
2
90
5
-R
Capacitance (μF)
Voltage (V) R = Decimal
Length = 25
Packaging information
2R5
Standard packaging: Bulk, 100 units per bag
Larger bulk packages available on request
www.eaton.com/electronics
2R5 = 2.5 V
Value
Example: 905 = 9 x 105 μF or 9.0 F
Multiplier
Standard product
M Supercapacitors
Cylindrical cells
Technical Data 4080
Wave solder profile
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Profile Feature
Standard SnPb Solder
Lead (Pb) Free Solder
• Temperature max. (Tsmax)
100 °C
100 °C
• Time max.
60 seconds
60 seconds
D preheat to max Temperature
160 °C max.
160 °C max.
Peak temperature (TP)*
220 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Preheat and soak
Manual solder
+350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
Reflow soldering
Do not use reflow soldering using infrared or convection oven heating methods.
Cleaning/Washing
Avoid cleaning of circuit boards, however if the circuit board must be cleaned use static or ultrasonic immersion in a standard circuit board
cleaning fluid for no more than 5 minutes and a maximum temperature of +60 °C. Afterwards thoroughly rinse and dry the circuit boards. In
general, treat supercapacitors in the same manner you would an aluminum electrolytic capacitor.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronoics
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 4080
October 2016
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“M1030-2R5605-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+136.479891+17.74195
- 10+106.3988110+13.83150
- 50+94.3948750+12.27103
- 100+90.67682100+11.78770
- 500+84.37956500+10.96907
- 1000+82.427561000+10.71532
