DX
DX
ELECTRIC
DOUBLE
LAYER
CAPACITORS“DYNACAP”
“DYNACAP”
ELECTRIC
DOUBLE
LAYER
CAPACITORS
GREEN
CAP
5.5V Miniaturized Standard Capacitors
Smaller and lighter than Series DB.
5mm tall. Max. thin profile (H-shaped).
Miniaturized but can encase up to 0.47F in 11.5×5mm case,
and 1.5F in φ19.0×20.5Lmm case.
70˚C
Miniaturized
DX
DB
Marking color : White print on an indigo sleeve
Specifications
Item
Performance
Category temperature range (℃)
ー25 to +70
Tolerance at rated capacitance (%)
ー20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (70℃)
Internal resistance (Ω Max.)
0.047
0.1
0.22
0.33
120
75
75
75
0.47
0.47
75(φ11.5)30(φ19.0)
1
1.5
30
30
Within ±30% of the value at 20℃
Internal resistance
Less than five times of the value at 20℃
Test time
1000 hours
Within ±30% of the initial measured value
Internal resistance
Less than four times of the initial specified value
Shelf life (70℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Unit : mm
φD±0.3
Terminal shaped : H
(4.5)
Sn plated
(0.15)
(0.15)
5.0±0.3
4.0±0.3
Sleeve
Sleeve
Sn plated
10.0±0.5
Note
Part numbering system (example : 5.5V0.1F)
5R5
Max.operating voltage
symbol
Series code
U
104
Terminal
code
(0.8)
5.0±0.5
(φ11.5 : 0.8, φ19 : 1.0)
DX
φD±0.3
5±0.3 L±0.5
L±0.5
12.4±0.5
(4.5)
Terminal shaped : V
Reted capacitance
symbol
Additional
symbol
Part number is refer to following table.
Do not apply external force to products or terminals as stress such as twisting,
bending, pushing, or falling of such products or terminals may remove the terminals,
resulting in an open/short circuit or liquid leakage.
Avoid applying excessive heat to capacitors during heating of an adhesive curing oven.
For details, refer to the precautions in use of DYNACAP.
Standard Ratings
Max. operating voltage (V)
0.047
5.5
0.1
5.5
0.22
5.5
0.33
5.5
0.47
φD×L (mm)
DX-5R5V473U
11.5×13.0
DX-5R5H473U
11.5× 5.0
DX-5R5V104U
11.5×13.0
DX-5R5H104U
11.5× 5.0
DX-5R5V224U
11.5×13.0
DX-5R5H224U
11.5× 5.0
DX-5R5V334U
11.5×13.0
DX-5R5H334U
11.5× 5.0
DX-5R5V474SU
DX-5R5H474SU
DX-5R5V474U
11.5×13.0
11.5× 5.0
19.0×20.5
5.5
1
DX-5R5V105U
19.0×20.5
5.5
1.5
DX-5R5V155U
19.0×20.5
NOTE : Design,
Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
201
CAT.No.2015/2016E
EDLC
5.5
ELNA Parts No.
很抱歉,暂时无法提供与“DX-5R5L224T”相匹配的价格&库存,您可以联系我们找货
