SGNMNC3706HTT
SGNMNC3706HTT
    SPRAGUE-GOODMAN
    可调电容 2pF~70pF 6KV Ф18.03mm
SGNMNC3706HTT 数据手册
SGNM – SERIES 1 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and NMR Machines Pressure of Up to 40 PSI • • Residual Magnetic Value Less Than 20 nT Model Number Capacitance Range (pF) Cryogenic Projects Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) Min Max SGNMNC1054 0.50 5.00 2,000 4,000 8,000 SGNMNC1056 0.50 5.00 2,000 6,000 12,000 SGNMNC1059 0.50 5.00 2,000 8,750 17,500 SGNMNC1103 1.00 10.00 1,700 3,000 6,000 SGNMNC1106 1.00 10.00 1,700 6,000 12,000 SGNMNC1108 1.00 10.00 1,700 7,500 15,000 SGNMNC1152 1.00 15.00 1,500 2,000 4,000 SGNMNC1156 1.50 15.00 1,500 6,000 12,000 SGNMNC1206 2.00 20.00 1,500 6,000 12,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700 SGNM – SERIES 2 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and Pressure of Up to 40 PSI • NMR Machines • Residual Magnetic Value Less Than 20 nT Cryogenic Projects Model Number Capacitance Range (pF) Min Max Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) SGNMNC2106 1.00 10.00 3,000 6,000 12,000 SGNMNC2156 1.50 15.00 2,000 6,000 12,000 SGNMNC2206 2.00 20.00 1,500 6,000 12,000 SGNMNC2236 2.00 23.00 1,200 6,000 12,000 SGNMNC2256 3.00 25.00 1,200 6,000 12,000 SGNMNC2306 3.00 30.00 600 6,000 12,000 SGNMNC2356 3.50 35.00 600 6,000 12,000 SGNMNC2406 4.00 40.00 500 6,000 12,000 SGNMNC2502 5.00 50.00 500 2,500 5,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700 SGNM – SERIES 3 CERAMIC HIGH VOLTAGE NON-MAGNETIC TRIMMER CAPACITOR Product Highlights Applications • High Voltage Ceramic Dielectric • MRI and NMR Coils • Internally Sealed to Withstand External • Transmitting and Receiving Sections of MRI and Pressure of Up to 40 PSI • Residual Magnetic Value Less Than 20 nT Model Number SGNMNC3101 SGNMNC3103 SGNMNC3106 SGNMNC3153 SGNMNC3205 SGNMNC3253 SGNMNC3256 SGNMNC3306 SGNMNC3505 SGNMNC3706 SGNMNC3708 SGNMNC3806 SGNMNC31006 Capacitance Range (pF) Min Max 1.00 10.00 1.50 10.00 2.00 10.00 1.50 15.00 3.00 20.00 5.00 25.00 7.00 25.00 4.00 30.00 5.00 50.00 2.00 70.00 6.50 70.00 5.00 85.00 10.00 100.00 NMR Machines • Cryogenic Projects Q Min Rated DC Working Dielectric Withstanding Voltage (V) Voltage (V) (at 25 MHz C Max) 2,000 1,500 3,000 2,000 3,000 6,000 1,800 6,000 12,000 2,000 3,000 6,000 600 4,500 9,000 1,200 3,000 6,000 1,200 6,000 12,000 1,000 6,000 12,000 700 4,500 9,000 600 6,000 12,000 600 7,500 15,000 500 6,000 12,000 500 6,000 12,000 Options: 1. Extended Shaft - Add suffix “E” to model number 2. Cryogenic Version – Add suffix “K” for model that operates and may be tuned at temperatures as low as 4K. This model is not sealed 3. No Lead Option – Add suffix “NL” for a model that does not include a wire lead attached to stator terminal 4. Please contact us directly for additional customization options SPRAGUE GOODMAN ELECTRONICS, INC. ▪ 1700 SHAMES DRIVE ▪ WESTBURY, NEW YORK 11590 ▪ (516) 334 - 8700
SGNMNC3706HTT
物料型号: - SGNM系列1:SGNMNC1054, SGNMNC1056, SGNMNC1059, SGNMNC1103, SGNMNC1106, SGNMNC1108, SGNMNC1152, SGNMNC1156, SGNMNC1206 - SGNM系列2:SGNMNC2106, SGNMNC2156, SGNMNC2206, SGNMNC2236, SGNMNC2256, SGNMNC2306, SGNMNC2356, SGNMNC2406, SGNMNC2502 - SGNM系列3:SGNMNC3101, SGNMNC3103, SGNMNC3106, SGNMNC3153, SGNMNC3205, SGNMNC3253, SGNMNC3256, SGNMNC3306, SGNMNC3505, SGNMNC3706, SGNMNC3708, SGNMNC3806, SGNMNC31006
器件简介: 这些电容器具有高压陶瓷介质,内部密封以承受高达40 PSI的外部压力,残余磁值小于20 nT。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 电容范围:0.50 pF 至 100.00 pF - 最小品质因数(Q):500 至 2,000(在25 MHz时) - 额定直流工作电压:600 V 至 8,750 V - 介质耐压电压:2,000 V 至 17,500 V
功能详解:文档中未提供详细的功能解释,但提到这些电容器适用于MRI和NMR机器的发射和接收部分,以及低温项目。
应用信息: 适用于MRI和NMR线圈,以及低温项目。
封装信息: 文档中未提供封装信息,但提供了定制选项,如加长轴、低温版本、无引线选项等。
制造商信息:Sprague Goodman Electronics, Inc.,位于纽约州Westbury。
SGNMNC3706HTT 价格&库存
很抱歉,暂时无法提供与“SGNMNC3706HTT”相匹配的价格&库存,您可以联系我们找货
