GXE27000NM
GXE27000NM
    SPRAGUE-GOODMAN
    可调电容 3.5pF~27pF 200V 8.50 x 7.50mm
GXE27000NM 数据手册
0.33 REV DESCRIPTION 00 NEW APP DATE 09/01/09 DRAWING S.G. 8.5 SPECIFICATIONS: 1. Capacitance range: 3.5 to 27.0 pF 2. Q min: 1500 at 1 MHz 3. TCC: 0± 250 ppm/C 4. Operating temperature range: -40C to + 125C +0.008 0.30 -0.000 7.7 +0.200 -0.000 5. Construction: non magnetic DIA 6. Working voltage: 200 VDC 7. Dielectric withstanding voltage: 300 VDC 8. Insulation resistance: 10^4 megohms min 9. Torque: 0.21 to 3.5 oz-in (15 to 250 g-cm ) 10. Linear capacitance change vs.rotation 0.098 2.5 11. Color 12. Dielectric: code: Red PTFE DIA 0.02 0.03 0.6 0.7 +0.004 0.148 -0.000 3.75 +0.10 -0.00 0.402 +0.004 0.051-0.000 10.2 +0.1 -0.0 1.3 DIA (3 HOLES) 0.30 7.5 0.17 4.3 STATOR TERMINAL 2 ROTOR TERMINALS +0.0 0.0413 -0.004 1.05 +0.0 -0.1 0.12 +0.00 -0.02 3.0 +0.0 -0.5 SUGGESTED TOLERANCES: (EXCEPT AS NOTED) DECIMAL: 0.002 in 0.051 mm FRACTIONAL: MOUNTING 1 HOLES LAYOUT SPRAGUE GOODMAN ELECTRONICS INC. 1700 SHAMES DRIVE MATERIAL: WESTBURY, NY SCALE: 4:1 TITLE: GXE27000NM 1/64 ANGULAR: DIA DATE: 09/01/2009 DRAVING DRAWN BY: APPROVED: 11590 R. LEVIN S. GRINBERG USED NUMBER: GXE27000NM FOR: REV: 00
GXE27000NM 价格&库存
很抱歉,暂时无法提供与“GXE27000NM”相匹配的价格&库存,您可以联系我们找货
