GUF1R200
GUF1R200
    SPRAGUE-GOODMAN
    插件
    可调电容 0.3pF~1.2pF 500V Ф1.90 x 5.80mm
GUF1R200 数据手册
ENGINEERING BULLETIN Sprague-Goodman SG-207F Supercedes SG-207E MICROWAVE SAPPHIRE ® PISTONCAP TRIMMER CAPACITORS FEATURES • • • • Sapphire dielectric Very high Q at UHF and microwave frequencies Subminiature – smallest PISTONCAP® types Choice of 2 configurations and 6 mounting styles to suit all RF structures • Designed to meet MIL-C-14409D • Precision high resolution adjustment: 127 threads per inch for GU series, GW series and GN_1R2_ _ 169 threads per inch for GN_2R5_ _ to GN_8R0_ _ • Extremely stable over temperature, frequency, voltage, etc. APPLICATIONS Stable oscillators, frequency multipliers, filters, tuning cavities, coupling, etc. SPECIFICATIONS Operating temperature: -55°C to +125°C Rated voltage: 500 VDC Dielectric withstanding voltage: 1000 VDC Contact resistance: 0.01 Ohms Insulation resistance: 106 Megohms min at 500 VDC Torque: 0.1 to 1.0 oz-in (7.2 to 72 g-cm) for GU series and GN_1R2_ _ 0.2 to 2.0 oz-in (14.4 to 144 g-cm) for GW and GN_2R5_ _ to GN_8R0_ _ PART NUMBERING SYSTEM C GU Sapphire Dielectric GN GU GW C= F = L = N R V Y = = = = Mount Type PC Mount Flange Mount Horizontal Surface Mount Leadless Reverse Lead Mount Vertical Surface Mount Vertical Surface Mount, Wide Lead Capacitance Code Industry Standard, i.e. 1R2 = 1.2 pF 100 = 10 pF 00 00 = 01 = 50 = 51 = Modification Suffix +350 ±100 ppm/°C (no marking) as above, with PTFE protective cap NPO ± 50 ppm/°C (± 75 for 8 pF models) (dimple or red ID mark on adjustment screw) as above, with PTFE protective cap Sprague-Goodman Electronics, Inc. 1700 SHAMES DRIVE, WESTBURY, NY 11590 TEL: 516-334-8700 • FAX: 516-334-8771 E-MAIL: info@spraguegoodman.com SG-207F MICROWAVE SAPPHIRE PISTONCAP® TRIMMER CAPACITORS K DIA K DIA Fig. 1 Fig. 2 SLOT 0.015 0.38 X Type F – Flange Mount 0.012 DP 0.30 SLOT 0.015 0.38 0.012 DP 0.30 0.010 0.25 0.010 0.25 A1 A2 B1 D D C DIA Capacitance ( pF ) X C DIA A1 B1 C 0.005 ± ----—----– 0.1 D K 0.005 ± ----—----– 0.1 A2 Model No. Fig. 1 Model No. Fig.2 min max Q min (250 MHz) 0.3 1.2 4000 0.20 –--–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.09 –--–— 2.3 0.145 –--–— 3.68 0.23 –--–— 5.8 GUF1R200 GUF1R250 GNF1R200 GNF1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.17 –--–— 4.4 0.118 –--–— 3.00 0.09 –--–— 2.3 0.185 –--–— 4.70 0.23 --–— 5.8 GWF2R500 –--–— GWF2R550 GNF2R500 GNF2R550 0.6 4.5 2000 0.33 –--–— 8.4 0.25 –--–— 6.5 0.118 –--–— 3.00 0.15 –--— 3.8 0.185 –--–— 4.70 0.31 –-— 7.9 GWF4R500 GWF4R550 GNF4R500 GNF4R550 0.8 8.0 1000 0.57 –--–— 14 0.41 –--–— 11 0.118 –--–— 3.00 0.25 –-–— 6.4 0.185 –--–— 4.70 0.47 --–— 12 GWF8R000 GWF8R050 GNF8R000 GNF8R050 Fig. 1 SLOT 0.015 0.38 X Fig. 2 0.012 DP 0.30 SLOT K DIA K DIA 0.015 0.38 X G 0.23 5.8 Type R – Reverse Lead Mount 0.012 DP 0.30 G 0.23 5.8 0.23 5.8 0.23 5.8 0.06 1.4 A1 0.06 1.4 B1 H1 Capacitance (pF ) C DIA A2 0.010 TYP 0.25 0.010 TYP 0.25 H2 C DIA A1 B1 C 0.005 ± ----—----– 0.1 G H1 K 0.005 ± ----—----– 0.1 A2 H2 Model No. Fig. 1 Model No. Fig.2 min max Q min (250 MHz) 0.3 1.2 4000 0.20 –--–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.04 –--–— 1.0 – 0.114 –--–— 2.90 0.23 –--–— 5.8 0.015 –--–— 0.38 GUR1R200 GUR1R250 GNR1R200 GNR1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.17 –--–— 4.4 0.118 –--–— 3.00 0.09 –--— 2.4 – 0.16 –--–— 4.0 0.23 --–— 5.8 0.015 –--–— 0.38 GWR2R500 – GWR2R550 GNR2R500 GNR2R550 0.6 4.5 2000 0.33 –--–— 8.4 0.25 –--–— 6.5 0.118 –--–— 3.00 0.09 –-–— 2.4 – 0.16 –--–— 4.0 0.31 --–— 7.9 0.050 –-–--–— 1.3 GWR4R500 GWR4R550 GNR4R500 GNR4R550 0.8 8.0 1000 0.57 –--–— 14 0.41 –--–— 11 0.118 –--–— 3.00 0.09 –--— 2.4 0.14 –--–— 3.5 0.16 –--–— 4.0 0.47 --–— 12 0.14 –--–— 3.5 GWR8R000 GWR8R050 GNR8R000 GNR8R050 Dimensions are in/mm. Unless otherwise specified, tolerance is ±0.01/0.3, except slot tolerance is +0.001/0.03, -0.002/0.05 and lead thickness tolerance is ±0.002/0.05. 2 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com MICROWAVE SAPPHIRE PISTONCAP® TRIMMER CAPACITORS Fig. 1 SG-207F Fig. 2 A1 Type L – Horizontal Surface Mount A2 B1 K DIA K DIA C DIA C DIA L L E TYP D Capacitance ( pF ) 0.040 1.0 0.010 0.25 SLOT 0.015 0.38 X 0.040 1.0 E TYP D 0.012 DP 0.30 0.010 0.25 SLOT 0.015 0.38 X 0.012 DP 0.30 A1 B1 C 0.005 ±—------– 0.1 D E K 0.005 ±—------– 0.1 L A2 Model No. Fig. 1 Model No. Fig.2 min max Q min (250 MHz) 0.3 1.2 4000 0.20 –--–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.08 –--–— 2.1 0.171 –--–— 4.34 0.114 –--–— 2.90 0.07 –--–— 1.8 0.23 –--–— 5.8 GUL1R200 GUL1R250 GNL1R200 GNL1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.17 –--–— 4.4 0.118 –--–— 3.00 0.08 –--–— 2.1 0.147 –--–— 3.73 0.158 –--–— 4.01 0.09 –--–— 2.4 0.23 –--— 5.8 GWL2R500 GWL2R550 GNL2R500 GNL2R550 0.6 4.5 2000 0.33 –--–— 8.4 0.25 –--–— 6.5 0.118 –--–— 3.00 0.13 –--–— 3.3 0.147 –--–— 3.73 0.158 –--–— 4.01 0.09 –--–— 2.4 0.31 –--— 7.9 GWL4R500 GWL4R550 GNL4R500 GNL4R550 0.8 8.0 1000 0.57 –--–— 14 0.41 –--–— 11 0.118 –--–— 3.00 0.25 –--–— 6.4 0.147 –--–— 3.73 0.158 –--–— 4.01 0.09 –--–— 2.4 0.47 –--— 12 GWL8R000 GWL8R050 GNL8R000 GNL8R050 Fig. 1 Fig. 2 K DIA SLOT 0.015 0.38 X Type V – Vertical Surface Mount K DIA 0.050 1.3 * 0.012 DP 0.30 SLOT A1 0.015 0.38 X SEE BELOW 0.012 DP 0.30 A2 B1 D 0.010 0.25 D C DIA C DIA F Capacitance ( pF ) min 0.3 max 1.2 0.010 0.25 0.03 0.8 0.03 0.8 F A1 B1 C 0.005 ±—------– 0.1 D F K 0.005 ±—------– 0.1 A2 Model No. Fig. 1 Model No. Fig.2 4000 0.20 –--–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.09 –--–— 2.3 0.08 –--–— 1.9 0.114 –--–— 2.90 0.23 --–— 5.8 GUV1R200 GUV1R250 GNV1R200 0.17 –--–— 4.4 0.118 –--–— 3.00 0.09 –--–— 2.3 0.11 –--–— 2.8 0.158 –--–— 4.01 0.23 --–— 5.8 GWV2R500 GWV2R550 GN _ 2R500 GN _ 2R550 Q min (250 MHz) * GNV1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.6 4.5 2000 0.33 –--–— 8.4 0.25 –--–— 6.5 0.118 –--–— 3.00 0.15 –--–— 3.8 0.11 –--–— 2.8 0.158 –--–— 4.01 0.31 –-— 7.9 GWV4R500 GWV4R550 GN _ 4R500 GN _ 4R550 0.8 8.0 1000 0.57 –--–— 14 0.41 –--–— 11 0.118 –--–— 3.00 0.25 –--–— 6.4 0.11 –--–— 2.8 0.158 –--–— 4.01 0.47 --–— 12 GWV8R000 GWV8R050 GN _ 8R000 GN _ 8R050 Insert letter “V” or “Y” to select lead width. * GNV series has a lead width of 0.050 / 1.3 GNY series has a lead width of 0.093 / 2.4 Dimensions are in/mm. Unless otherwise specified, tolerance is ±0.01/0.3, except slot tolerance is +0.001/0.03, -0.002/0.05 and lead thickness tolerance is ±0.002/0.05. SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com 3 SG-207F MICROWAVE SAPPHIRE PISTONCAP® TRIMMER CAPACITORS Fig. 1 Fig. 2 A1 SLOT 0.015 0.38 Type C – PC Mount 0.012 DP 0.30 X B1 SLOT A2 0.015 0.38 X 0.012 DP 0.30 K DIA K DIA C DIA C DIA 0.230 5.84 0.230 5.84 0.040 1.0 D Capacitance (pF) X 0.010 TH 0.25 0.040 1.0 D X 0.010 TH 0.25 A1 B1 C 0.005 ±—------– 0.1 D K 0.005 ±—------– 0.1 A2 Model No. Fig. 1 Model No. Fig.2 min max Q min (250 MHz) 0.3 1.2 4000 0.20 –--–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.08 –--–— 2.1 0.114 –--–— 2.90 0.23 --–— 5.8 GUC1R200 GUC1R250 GNC1R200 GNC1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.17 –--–— 4.4 0.12 –--–— 3.0 0.08 –--–— 2.1 0.158 –--–— 4.01 0.23 --–— 5.8 GWC2R500 GWC2R550 GNC2R500 GNC2R550 0.6 4.5 2000 0.33 –--–— 8.4 0.25 –--–— 6.5 0.12 –--–— 3.0 0.13 –--–— 3.3 0.158 –--–— 4.01 0.31 --–— 7.9 GWC4R500 GWC4R550 GNC4R500 GNC4R550 0.8 8.0 1000 0.57 –--–— 14 0.41 –--–— 11 0.12 –--–— 3.0 0.25 –--–— 6.4 0.158 –--–— 4.01 0.47 --–— 12 GWC8R000 GWC8R050 GNC8R000 GNC8R050 Fig. 1 Fig. 2 SLOT 0.015 0.38 X Type N – Leadless 0.012 DP 0.30 SLOT A1 X 0.012 DP 0.30 A2 B1 C DIA Capacitance (pF) 0.015 0.38 C DIA A1 B1 C 0.005 ±—------– 0.1 A2 Model No. Fig. 1 Model No. Fig.2 min max Q min (250 MHz) 0.3 1.2 4000 0.20 –---–— 5.2 0.17 —–— 4.4 0.075 –--–— 1.9 0.23 ––— 5.8 GUN1R200 GUN1R250 GNN1R200 GNN1R250 0.4 2.5 3000 0.20 –--–— 5.2 0.17 —–— 4.4 0.12 –--–— 3.0 0.23 ––— 5.8 GWN2R500 GWN2R550 GNN2R500 GNN2R550 0.6 4.5 2000 0.33 –--–— 8.4 0.25 —–— 6.5 0.12 –--–— 3.0 0.31 ––— 7.9 GWN4R500 GWN4R550 GNN4R500 GNN4R550 0.8 8.0 1000 0.57 —-–— 14 0.41 —–— 11 0.12 –--–— 3.0 0.47 ––— 12 GWN8R000 GWN8R050 GNN8R000 GNN8R050 Dimensions are in/mm. Unless otherwise specified, tolerance is ±0.01/0.3, except slot tolerance is +0.001/0.03, -0.002/0.05 and lead thickness tolerance is ±0.002/0.05. 4 SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com ©1998 SPRAGUE-GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED. PRINTED IN THE U.S.A. 50205
GUF1R200
物料型号:Sprague-Goodman MICROWAVE SAPPHIRE PISTONCAP® TRIMMER CAPACITORS,型号SG-207F。
器件简介:这是一种微型的蓝宝石介质可变电容器,具有非常高的品质因数(Q值),适用于超高频和微波频率。它设计用于满足MIL-C-14409D标准,具有高精度的高分辨率调整。
引脚分配:文档中没有提供具体的引脚分配图,但提供了多种安装方式,包括PC安装、法兰安装、水平表面安装、无引线安装、反向引线安装和垂直表面安装。
参数特性: - 工作温度:-55°C至+125°C - 额定电压:500 VDC - 介质耐压:1000 VDC - 接触电阻:0.01欧姆 - 绝缘电阻:最小10^6兆欧姆(在500 VDC下)
功能详解:这些可变电容器适用于稳定的振荡器、频率倍增器、滤波器、调谐腔、耦合等应用。
应用信息:适用于需要高稳定性的射频结构,如稳定振荡器、频率倍增器、滤波器、调谐腔、耦合等。
封装信息:提供了多种封装类型,包括GU系列、GW系列、GN系列等,每种系列都有不同的安装方式和调整精度。
GUF1R200 价格&库存
很抱歉,暂时无法提供与“GUF1R200”相匹配的价格&库存,您可以联系我们找货
