ENGINEERING BULLETIN
Sprague-Goodman
SG-660B
Supercedes SG-660A
AIRTRIM® AIR DIELECTRIC
MULTITURN
TRIMMER CAPACITORS
APPLICATIONS
Designed for VHF, UHF and microwave applications:
amplifiers, oscillators, filters, radar, cable TV, mobile
radios and RF appliances. Suitable for military and
aerospace environments.
FEATURES
• High Q
• Fourteen standard mounting styles, including
surface mount
• Excellent stability
• Designed to meet MIL-C-14409D
• Multiturn resolution
SPECIFICATIONS
Operating Temperature Range: – 65° to +125°C
Working Voltage: 250 VDC
Test Voltage: 500 VDC
Insulation Resistance: >106 Megohms
Contact Resistance: < 0.01 Ohms
Q vs. Frequency
5000
Self-Resonant Freq. vs.
Capacitance
Capacitance vs. Rotation
GAA14
GAA10
10
GAA6R
4000
GAA3R5
Q
3000
2000
Q: > 5000 at 100 MHz
Vibration: 60 g, 10 to 2000 Hz
Shock: 1500 g, 0.5 ms
Constructed with 300°C solder
GAA14
1000
10
8
8
C(pF)
GAA10
GHz
6
6
4
4
2
2
GAA10
GAA3R5
GAA6R
50
100
150
MHz
200
250
1
2
3
4
5
2
4
Turns
Sprague-Goodman Electronics, Inc.
1700 SHAMES DRIVE, WESTBURY, NY 11590
TEL: 516-334-8700 • FAX: 516-334-8771
E-MAIL: info@spraguegoodman.com
6
C(pF)
8
10
AIRTRIM® AIR DIELECTRIC MULTITURN TRIMMER CAPACITORS
SG-660B
PART NUMBERING SYSTEM
GA
A
01
6R0
Air
Dielectric
Multiturn
Maximum Rated Capacitance —
expressed in pF by three digits. The
first two are significant figures; the
last specifies the number of zeros
that follow. The letter R indicates a
decimal point.
Mounting Modifications
01 — Panel mount, turret
02 — Panel mount, lug
03 — Panel mount, threaded stud
04 — PC mount, 3 lugs (1 stator,
2 rotor)
05 — Horizontal surface mount
06 — Vertical mount, turret and
lug (wide single)
07 — Vertical mount, stud and
lug (wide single)
08 — Vertical mount, through
board
09 — Vertical surface mount
(wide lead)
10 — Vertical turret and lugs
(wide double)
11 — Vertical turret and lugs
(narrow double)
12 — Vertical turret and lug
(narrow single)
13 — PC mount, 2 lugs
14 — Vertical surface mount
(narrow lead)
0.35–3.5 pF CAPACITANCE RANGE
• Torque: 0.3 to 3.0 oz-in (22 to 216 g-cm)
• Temperature Coefficient: ±30 ppm/ °C
• Self-Resonant Frequency: > 6 GHz at min capacitance
0.120-80
UNS-2A
0.22
5.6
0.10
2.5
0.120-80
UNS-2A
0.22
5.6
Round Nut
0.26
6.6
0.13
3.3
Dimensions are in/mm
Adjust screw slot: 0.060/1.5 x 0.016/0.41
Round Nut
0.16
DIA
4.1
0.13
TYP
3.3
0.073-80
UNS-2A
0.16
DIA
4.1
0.16
DIA
4.1
GAA3R501
GAA3R501
0.15
3.8
0.01
TYP
0.3
GAA3R503
GAA3R503
0.10
TYP
2.5
GAA3R505
GAA3R505
0.21
5.3
0.120-80
UNS-2A
0.120 - 80
UNS -2A
0.16
DIA
4.1
0.28
7.1
0.21
5.3
0.28
7.1
0.40
10
0.22
5.6
0.11
2.8 0.12
3.0
0.120-80
UNS-2A
0.24
6.1
Bottom view shown
without nut for clarity
0.21
5.3
0.28
7.1
0.21
5.3
0.26
6.6
Hex Nut
0.05
DIA
1
0.28
7.1
0.01
0.3
0.02
0.5
0.03
TYP
0.8
0.01
0.3
0.120-80
UNS-2A
0.25
6.4
0.12
3.0
0.01
TYP
0.3
0.10
2.5
0.02
0.5
0.16
DIA
4.1
0.16
DIA
4.1
0.03
DIA
0.8
GAA3R512
2
GAA3R513
GAA3R513
GAA3R514
GAA3R514
SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@spraguegoodman.com
SG-660B
Not to scale.
01
03
02
06
10
11
12
04
13
07
05
09
14
08
0.6 –6.0 pF CAPACITANCE RANGE
• Torque: 0.4 to 4.0 oz-in (29 to 288 g-cm)
• Temperature Coefficient: ±15 ppm/ °C
0.190 - 64
UNS-2A
0.21
5.3
0.08
2
Adjust screw slot: 0.13/3.3 x 0.020/0.51
Round Nut
0.24
DIA
6.1
0.29
7.4
0.24
DIA
6.1
0.19
4.8
0.29
7.4
0.19
4.8
0.27
6.9
0.20
5.1
0.25
6.4
0.190-64
UNS-2A
0.03
TYP
0.8
0.06 DIA
2
0.16
4.0
0.24 DIA
6.1
GAA6R001
GAA6R001
0.26
6.6
0.20
TYP
5.1
0.015
TYP
0.38
0.015
TYP
0.38
GAA6R004
GAA6R004
0.190-64
UNS-2A
0.25
6.2
0.15
3.8
TYP
GAA6R005
GAA6R005
0.19
4.8
0.19
4.8
0.190-64
UNS-2A
0.190-64
UNS-2A
0.29
7.4
0.29
7.4
0.015
0.38
0.20
5.1
0.10
2.5
0.11
2.8
0.030
0.76
0.24
DIA
6.1
0.40
10
0.16
4.1
0.015
0.38
0.03
0.76
0.24
DIA
6.1
0.04
DIA
1
GAA6R014
GAA6R012
SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com
3
SG-660B
1.0 – 10.0 pF, 1.0 – 14.0 pF and 2.0 – 16.0 pF
CAPACITANCE RANGES
• Torque: 0.5 to 5.0 oz-in (36 to 360 g-cm)
• Self-Resonant Frequency: > 5 GHz at min capacitance
0.234- 64
UNS-2A
0.234- 64
UNS-2A
Hex Nut
0.28
0.045
AF x
THK
7.1
1.1
0.20
5.1
Adjust screw slot: 0.16/4.0 x 0.020/0.51
0.20
5.1
0.30
7.6
0.30
7.6
0.234-64
UNS-2A
Hex Nut
0.28
0.045
AF x
THK
7.1
1.1
Hex Nut
0.28
0.045
AF x
THK
7.1
1.1
0.20
5.1
0.30
7.6
4-40 UNC-2A
0.06
2
0.11
2.8
0.30
DIA
7.6
0.047
Dia Hole
1.2
0.20
5.1
0.30
DIA
7.6
0.30 DIA
7.6
0.095
2.4
0.095
DIA
2.4
GAA10001, GAA14001 & GAA16001
0.30
DIA
7.6
0.31
7.9
GAA10002, GAA14002 & GAA16002
0.30
DIA
7.6
0.19
4.8
0.31
7.9
0.234-64
UNS-2A
0.03
TYP
0.8
0.22
5.6
0.30
7.6
0.015
TYP
0.38
0.31
7.9
0.15
TYP
3.8
0.29
7.2
0.11
2.8
0.015
TYP
0.38
0.06
DIA
2
0.28
7.1
0.03
0.8
0.015
0.38
0.25
6.4
GAA10006, GAA14006 & GAA16006
GAA10005, GAA14005 & GAA16005
0.19
4.8
0.234-64
UNS-2A
0.31
7.9
0.234-64
UNS-2A
0.30
7.6
0.44
11
0.44
11
4-40
UNC-2A
0.015
0.38
0.31
7.9
Hex Nut
0.20
5.1
0.03
0.8
0.28
7.1
0.30
DIA
7.6
0.44
11
0.30
DIA
7.6
0.19
4.8
0.20
5.1
0.234-64
UNS-2A
0.234-64
UNS-2A
0.25
6.4
TYP
GAA10004, GAA14004 & GAA16004
0.19
4.8
0.19
4.8
0.20
5.1
0.31
7.9
GAA10003, GAA14003 & GAA16003
0.30 DIA
7.6
0.25
6.4
0.28
7.1
0.015
0.38
0.234-64
UNS-2A
0.03
0.8
0.015
0.38
0.20
5.1
0.10
2.5
0.30
DIA
7.6
0.25
6.4
0.25
6.4
Bottom view shown
GAA10007, GAA14007 & GAA16007
GAA10008, GAA14008 & GAA16008
GAA10009, GAA14009 & GAA16009
RECOMMENDED HANDLING PROCEDURE
Tuning
The rotor should not be torqued
once maximum capacitance is
reached.
Soldering
Maximum recommended solder
temperature: 275°C.
Washing
Sealing Caps should be secured
when washing board assemblies to
prevent infusion of cleaning solvents
E-MAIL: info@spraguegoodman.com • WEBSITE: http://www.spraguegoodman.com
4
© 2000 SPRAGUE- GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED
PRINTED IN THE U.S.A.
50004
很抱歉,暂时无法提供与“GAA3R512”相匹配的价格&库存,您可以联系我们找货
