ENGINEERING BULLETIN
Sprague-Goodman
SG-207F
Supercedes SG-207E
MICROWAVE SAPPHIRE
PISTONCAP
TRIMMER CAPACITORS
FEATURES
Sapphire dielectric
Very high Q at UHF and microwave frequencies
Subminiature – smallest PISTONCAP® types
Choice of 2 configurations and 6 mounting styles
to suit all RF structures
• Designed to meet MIL-C-14409D
• Precision high resolution adjustment:
127 threads per inch for GU series, GW series
and GN_1R2_ _
169 threads per inch for GN_2R5_ _ to GN_8R0_ _
• Extremely stable over temperature, frequency,
voltage, etc.
APPLICATIONS
Stable oscillators, frequency multipliers, filters, tuning
cavities, coupling, etc.
SPECIFICATIONS
Operating temperature: -55°C to +125°C
Rated voltage: 500 VDC
Dielectric withstanding voltage: 1000 VDC
Contact resistance: 0.01 Ohms
Insulation resistance: 106 Megohms min at 500 VDC
Torque: 0.1 to 1.0 oz-in (7.2 to 72 g-cm) for GU series
and GN_1R2_ _
0.2 to 2.0 oz-in (14.4 to 144 g-cm) for GW
and GN_2R5_ _ to GN_8R0_ _
PART NUMBERING SYSTEM
C
GU
Sapphire
Dielectric
GN
GU
GW
C=
F =
L =
N
R
V
Y
Mount Type
PC Mount
Flange Mount
Horizontal Surface
Mount
Leadless
Reverse Lead Mount
Vertical Surface Mount
Vertical Surface Mount,
Wide Lead
Capacitance Code
Industry Standard, i.e.
1R2 = 1.2 pF
100 = 10 pF
00
00 =
01 =
50 =
51 =
Modification Suffix
+350 ±100 ppm/°C (no marking)
as above, with PTFE protective
cap
NPO ± 50 ppm/°C (± 75 for 8 pF
models) (dimple or red ID mark
on adjustment screw)
cap
Sprague-Goodman Electronics, Inc.
1700 SHAMES DRIVE, WESTBURY, NY 11590
TEL: 516-334-8700 • FAX: 516-334-8771
E-MAIL: info@spraguegoodman.com
SG-207F
MICROWAVE SAPPHIRE PISTONCAP® TRIMMER CAPACITORS
K DIA
K DIA
Fig. 1
Fig. 2
SLOT
0.015
0.38
X
Type F –
Flange Mount
0.012
DP
0.30
SLOT
0.015
0.38
0.012
DP
0.30
0.010
0.25
0.010
0.25
A1
A2
B1
D
D
C
DIA
Capacitance
( pF )
X
C
DIA
A1
B1
C
0.005
0.1
D
K
0.005
0.1
A2
Model No.
Fig. 1
Model No.
Fig.2
min
max
Q min
(250 MHz)
0.3
1.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.09
2.3
0.145
3.68
0.23
5.8
GUF1R200
GUF1R250
GNF1R200
GNF1R250
0.4
2.5
3000
0.20
5.2
0.17
4.4
0.118
3.00
0.09
2.3
0.185
4.70
0.23
5.8
GWF2R500
GWF2R550
GNF2R500
GNF2R550
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.118
3.00
0.15
3.8
0.185
4.70
0.31
7.9
GWF4R500
GWF4R550
GNF4R500
GNF4R550
0.8
8.0
1000
0.57
14
0.41
11
0.118
3.00
0.25
6.4
0.185
4.70
0.47
12
GWF8R000
GWF8R050
GNF8R000
GNF8R050
Fig. 1
SLOT
0.015
0.38
X
Fig. 2
0.012
DP
0.30
SLOT
K DIA
K DIA
0.015
0.38
X
G
0.23
5.8
Type R –
Reverse Lead Mount
0.012
DP
0.30
G
0.23
5.8
0.23
5.8
0.23
5.8
0.06
1.4
A1
0.06
1.4
B1
H1
Capacitance
(pF )
C DIA
A2
0.010
TYP
0.25
0.010
TYP
0.25
H2
C DIA
A1
B1
C
0.005
0.1
G
H1
K
0.005
0.1
A2
H2
Model No.
Fig. 1
Model No.
Fig.2
min
max
Q min
(250 MHz)
0.3
1.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.04
1.0
0.114
2.90
0.23
5.8
0.015
0.38
GUR1R200
GUR1R250
GNR1R200
GNR1R250
0.4
2.5
3000
0.20
5.2
0.17
4.4
0.118
3.00
0.09
2.4
0.16
4.0
0.23
5.8
0.015
0.38
GWR2R500
GWR2R550
GNR2R500
GNR2R550
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.118
3.00
0.09
2.4
0.16
4.0
0.31
7.9
0.050
1.3
GWR4R500
GWR4R550
GNR4R500
GNR4R550
0.8
8.0
1000
0.57
14
0.41
11
0.118
3.00
0.09
2.4
0.14
3.5
0.16
4.0
0.47
12
0.14
3.5
GWR8R000
GWR8R050
GNR8R000
GNR8R050
Dimensions are in/mm. Unless otherwise specified, tolerance is ±0.01/0.3, except slot tolerance is +0.001/0.03, -0.002/0.05
and lead thickness tolerance is ±0.002/0.05.
2
SPRAGUE-GOODMAN ELECTRONICS, INC., 1700 SHAMES DRIVE, WESTBURY, NY 11590 • TEL: 516-334-8700 • FAX: 516-334-8771 • E-MAIL: info@ spraguegoodman.com
Fig. 1
SG-207F
Fig. 2
A1
Type L –
Horizontal Surface Mount
A2
B1
K DIA
K DIA
C
DIA
C DIA
L
L
E
TYP
D
Capacitance
( pF )
0.040
1.0
0.010
0.25
SLOT
0.015
0.38
X
0.040
1.0
E
TYP
D
0.012
DP
0.30
0.010
0.25
SLOT
0.015
0.38
X
0.012
DP
0.30
A1
B1
C
0.005
0.1
D
E
K
0.005
0.1
L
A2
Model No.
Fig. 1
Model No.
Fig.2
min
max
Q min
(250 MHz)
0.3
1.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.08
2.1
0.171
4.34
0.114
2.90
0.07
1.8
0.23
5.8
GUL1R200
GUL1R250
GNL1R200
GNL1R250
0.4
2.5
3000
0.20
5.2
0.17
4.4
0.118
3.00
0.08
2.1
0.147
3.73
0.158
4.01
0.09
2.4
0.23
5.8
GWL2R500
GWL2R550
GNL2R500
GNL2R550
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.118
3.00
0.13
3.3
0.147
3.73
0.158
4.01
0.09
2.4
0.31
7.9
GWL4R500
GWL4R550
GNL4R500
GNL4R550
0.8
8.0
1000
0.57
14
0.41
11
0.118
3.00
0.25
6.4
0.147
3.73
0.158
4.01
0.09
2.4
0.47
12
GWL8R000
GWL8R050
GNL8R000
GNL8R050
Fig. 1
Fig. 2
K DIA
SLOT
0.015
0.38
X
Type V –
K DIA
0.050
1.3
0.012
DP
0.30
SLOT
A1
0.015
0.38
X
SEE BELOW
0.012
DP
0.30
A2
B1
D
0.010
0.25
D
C DIA
C DIA
F
Capacitance
( pF )
min
0.3
max
1.2
0.010
0.25
0.03
0.8
0.03
0.8
F
A1
B1
C
0.005
0.1
D
F
K
0.005
0.1
A2
Model No.
Fig. 1
Model No.
Fig.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.09
2.3
0.08
1.9
0.114
2.90
0.23
5.8
GUV1R200
GUV1R250
GNV1R200
0.17
4.4
0.118
3.00
0.09
2.3
0.11
2.8
0.158
4.01
0.23
5.8
GWV2R500
GWV2R550
GN _ 2R500
GN _ 2R550
Q min
(250 MHz)
GNV1R250
0.4
2.5
3000
0.20
5.2
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.118
3.00
0.15
3.8
0.11
2.8
0.158
4.01
0.31
7.9
GWV4R500
GWV4R550
GN _ 4R500
GN _ 4R550
0.8
8.0
1000
0.57
14
0.41
11
0.118
3.00
0.25
6.4
0.11
2.8
0.158
4.01
0.47
12
GWV8R000
GWV8R050
GN _ 8R000
GN _ 8R050
Insert letter “V” or “Y” to select lead width.
* GNV
series has a lead width of 0.050 / 1.3
GNY series has a lead width of 0.093 / 2.4
3
SG-207F
Fig. 1
Fig. 2
A1
SLOT
0.015
0.38
Type C –
PC Mount
0.012
DP
0.30
X
B1
SLOT
A2
0.015
0.38
X
0.012
DP
0.30
K DIA
K DIA
C
DIA
C
DIA
0.230
5.84
0.230
5.84
0.040
1.0
D
Capacitance
(pF)
X
0.010
TH
0.25
0.040
1.0
D
X
0.010
TH
0.25
A1
B1
C
0.005
0.1
D
K
0.005
0.1
A2
Model No.
Fig. 1
Model No.
Fig.2
min
max
Q min
(250 MHz)
0.3
1.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.08
2.1
0.114
2.90
0.23
5.8
GUC1R200
GUC1R250
GNC1R200
GNC1R250
0.4
2.5
3000
0.20
5.2
0.17
4.4
0.12
3.0
0.08
2.1
0.158
4.01
0.23
5.8
GWC2R500
GWC2R550
GNC2R500
GNC2R550
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.12
3.0
0.13
3.3
0.158
4.01
0.31
7.9
GWC4R500
GWC4R550
GNC4R500
GNC4R550
0.8
8.0
1000
0.57
14
0.41
11
0.12
3.0
0.25
6.4
0.158
4.01
0.47
12
GWC8R000
GWC8R050
GNC8R000
GNC8R050
Fig. 1
Fig. 2
SLOT
0.015
0.38
X
Type N –
Leadless
0.012
DP
0.30
SLOT
A1
X
0.012
DP
0.30
A2
B1
C
DIA
Capacitance
(pF)
0.015
0.38
C
DIA
A1
B1
C
0.005
0.1
A2
Model No.
Fig. 1
Model No.
Fig.2
min
max
Q min
(250 MHz)
0.3
1.2
4000
0.20
5.2
0.17
4.4
0.075
1.9
0.23
5.8
GUN1R200
GUN1R250
GNN1R200
GNN1R250
0.4
2.5
3000
0.20
5.2
0.17
4.4
0.12
3.0
0.23
5.8
GWN2R500
GWN2R550
GNN2R500
GNN2R550
0.6
4.5
2000
0.33
8.4
0.25
6.5
0.12
3.0
0.31
7.9
GWN4R500
GWN4R550
GNN4R500
GNN4R550
0.8
8.0
1000
0.57
14
0.41
11
0.12
3.0
0.47
12
GWN8R000
GWN8R050
GNN8R000
GNN8R050
+0.001/0.03, -0.002/0.05 and lead thickness tolerance is ±0.002/0.05.
4
©1998 SPRAGUE-GOODMAN ELECTRONICS, INC., ALL RIGHTS RESERVED.
PRINTED IN THE U.S.A.
50205
很抱歉,暂时无法提供与“GUL1R250”相匹配的价格&库存,您可以联系我们找货
