935142624522
935142624522
    IPDIA
    硅电容器 0504 22nF ±15% 1.37 x 1.00mm 100mΩ
935142624522 数据手册
Wire Bonding Silicon Vertical Capacitor WBSC142.xxx Rev 3.2 Key features Key applications  Full compatible to monolithic ceramic capacitors   Ultra high stability of capacitance value: Any demanding applications, such as medical, aerospace, automotive industrial…  Applicable for standard wire bonding  Temperature ± 1 % (-55 °C to +150 °C) approach (Top & Bottom Gold metalizations)  Voltage < 0.1 % / Volts  Negligible capacitance loss through ageing  Custom sizes, values, shapes, tolerances and higher voltage  Low leakage current down to 100 pA  Decoupling / Filtering / Charge pump (i.e: Pacemakers / defibrillators)  High reliability applications  Downsizing  Low profile Thanks to the unique IPDiA Silicon capacitor The IPDiA technology is the most appropriate technology, most of the problems encountered in solution for Chip On Board, Chip On Foil, Chip On demanding applications can be solved. Glass, Chip On Ceramic, flip chip and embedded The capacitor ² 250nF/mm ) integration allows capability smaller (up footprint to than applications, when designers are looking at utmost decoupling behaviours. ceramic alternative to answer strong volumes This Silicon based technology is ROHS compliant constraints. and compatible with lead free reflow soldering This technology provides industry leading performances relative to the capacitor stability over the full operating voltage & temperature range. This technology also offers high reliability, up to 10 times better than ceramic capacitors and eliminates cracks phenomenon. process. WBSC142.xxx Electrical specification (*) Other values on request Parameters Capacitance range Capacitance tolerances Operating temperature range Storage temperatures Temperature coefficient Breakdown Voltage (BV) Capacitance variation versus RVDC Equivalent Serial Inductor (ESL) Equivalent Serial Resistor (ESR) Insulation resistance Aging Capacitance value 10 1pF 15 10pF: 15pF: 935.142.522.210 935.142.528.210 935.142.528.215 100pF: 150pF: 22 33 47 68 22pF: 33pF: 47pF: 68pF: 935.142.528.222 935.142.528.233 935.142.528.247 935.142.528.268 220pF: 330pF: 680pF: Contact 935.142.528.322 935.142.528.333 IPDIA Sales 935.142.521.368 10pF 935.142.522.310 935.142.522.315 935.142.521.310 935.142.528.315 1nF: Contact IPDIA Sales Contact IPDIA Sales Contact IPDIA Sales Contact IPDIA Sales Contact IPDIA Sales 1nF 10nF: 935.142.620.510 Contact IPDIA Sales 22nF: 935.142.827.522 935.142.624.522 Contact IPDIA Sales Contact IPDIA Sales Contact IPDIA Sales 10nF Contact IPDIA Sales Contact IPDIA Sales Contact Contact Temperature coefficient IPDIA Sales IPDIA Sales PICS vs. MLCC capacitors Contact IPDIA Sales: Contact IPDIA Sales ±1%, from -55 to +150°C 150, 50, 30(*) 0.1 % /V (from 0 V to RVDC) Max 100 pH Max 100 m 100G @ 16V, from -55 to 150°C Negligible, < 0.001% / 1000h FIT
935142624522 价格&库存
很抱歉,暂时无法提供与“935142624522”相匹配的价格&库存,您可以联系我们找货
