FH34SRJ-50S-0.5SH(99) 数据手册
0.5 mm Pitch, 1.0 mm above the board Top and Top/Bottom Contact, Back-Flip
actuator Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors
FH34(S)Series
Increased FPC/FFC holding force
Space saving (30 pos. shown)
Actuator
Metal fittings
1.0mm
17m
m
3.2mm
Easy FPC/FFC insertion
Back opening rotating
17
mm
All four
sides are
chamfered.
Top contacts
FP
C
/F
FC
Ready to insert FPC/FFC
■Features
Delivered with
the actuator open
1. Low-profile
With the 1.0 mm above the board and width of 3.8 mm the
connectors are used in space saving applications.
2. Increased FPC/FFC retention
As compared with existing similar construction connectors:
* In horizontal direction: Approximately 2.6 times
* In vertical direction: Approximately 2 times
3. Unique Back-Flip rotating actuator
The rotating actuator opens from the back of the connector,
assuring reliable electrical and mechanical connection.
4. Easy FPC insertion and reliable electrical
connection
FPC
FPC/FFC inserted and retained.
Completed electrical and mechanical connection.
Proven Flip Lock actuator allows easy insertion of FPC and
provides a tactile sensation when fully closed, confirming
complete electrical and mechanical connection.
5. Delivered with the actuator open
FPC/FPC can be immediately inserted without the need
for the opening of the actuator.
6. Accepts standard FPC thickness
0.3mm thick standard Flexible Printed Circuit (FPC) can
be used. This is the only ultra-low profile ZIF connector
using standard FPC.
7. Compatible with existing connectors.
FPC/FFC and PCB mounting patterns are the same as for
the FH19SC Series (bottom contact), allowing the use of
both connectors for interconnections between two boards or
replacement of the connectors.
Compatible with existing connectors.(FH19SC SERIES)
8. Conductive traces on the PCB can run
under the connector
No exposed contacts on the bottom of the connector.
9. Board placement with automatic equipment
Flat upper surface and tape and reel packaging facilitate
vacuum pick-up and placement.
Standard reel packaging contains 5000 connectors.
10.Halogen-free*
*As defined by IEC61249-2-21
Br-900ppm maximum, Cl-900ppm maximum, Cl + Br combined-1,500ppm
maximum
2013.11w
1
FH34(S)Series●0.5 mm Pitch, 1.0 mm above the board Top and Top Bottom Contact, Back-Flip actuator Flexible Printed Circuit & Flexible Flat Cable ZIF Connectors
■Specifications
Current rating 0.5 A (Note 1)
Ratings
Voltage rating 50 Vrms AC
Recommended FPC/FFC
Operating temperature range:
-55 to +85°C (Note 1)
Operating humidity range:
Relative humidity 90% max. (No condensation)
Storage temperature range:
-10 to +50°C (Note 2)
Storage humidity range:
Thickness: 0.3 ± 0.03 mm, Gold plated contact pads
Item
Specification
1. Insulation resistance 500 Mø min.
2. Withstanding voltage No flashover or insulation breakdown
100 mø max.
3. Contact resistance
* Including FPC and FFC conductor resistance
Contact resistance: 100 mø max.
4. Durability
No damage, cracks, or parts dislocation
No electrical discontinuity of 1μs or longer
5. Vibration
6. Shock
7. Humidity (Steady state) Insulation resistance: 50 Mø min.
8. Temperature cycle Insulation resistance: 50 Mø min.
Conditions
100 V DC
250 Vrms AC / one minute
1 mA, AC / DC 20mV max (AC: 1kHz)
20 cycles
Frequency: 10 to 55 Hz, single amplitude of 0.75
mm, 10 cycles in each of the 3 axis
Acceleration of 981m/s2, 6 ms duration, sine halfwave, 3 cycles in each of the 3 axis
96 hours at 40°C and humidity of 90 to 95%
Temperature : -55°C / +15°C to +35°C/+85°C / +15°C to +35°C
Time:
30 /
2 to 3
/ 30 / 2 to 3 minutes
5 cycles
Reflow: At the recommended temperature profile
9. Resistance to soldering heat No deformation of components affecting performance
Manual soldering: 350°C ±5°C for 5 seconds (Note 3)
Note1: When passing the current through all of the contacts, use 70% of the rated current.
Note2: Includes temperature rise caused by current flow.
Note3: The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage,
shipment or during transportation after board mounting.
■Materials
Part
Material
Finish
FH34S series
Color:Beige
FH34SRJ series
Color:Gray
FH34S series
Color:Black
FH34SRJ series
FH34SRJ series
Color:Black
Gold plating with nickel barrier
Pure tin reflow plating
LCP
Insulator
Contacts
Metalfittings
PA
LCP(8pos.)
Phosphor bronze
Phosphor bronze
■Ordering information
FH 34S RJ - 30S - 0.5 SH (50)
1
2
3
1 Series name : FH
2 Series No.
: 34S
3 Blank : Top contact
RJ
: Top and Bottom contact, halogen-free
(Flame retardance UL94V-0).
4 Number of positions : 4 to 40
5 Contact pitch : 0.5mm
2
4
5
6
6 Termination type
7
SH : SMT horizontal mounting type
7 Specifications
(50)…Standard product 5,000 pieces/reel
(99)…500 pieces/reel
Remarks
UL94V-0
UL94V-0
■Connector Dimensions
A±0.15
B
H
(1.95)
0.5
(3.2)
∞Number of contacts
(0.15)
0.15 H
Number of contacts indicator
(3.8)
HRS mark
Cav No.
1±0.1
A * *
0.5
(0.15)
(1.75)
2.9
0.3
2.9
(C)
0.1
1
D±0.1
Note
Note
Note
Note
1
2
3
4
: The coplanarity of each terminal lead within specified dimension is 0.1 mm Max.
: Packaged on tape and reel only. Check packaging specification.
: Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
: After reflow, the terminal plating may change color, however this does not represent a quality issue.
All dimensions: mm
Part Number
FH34S-7S-0.5SH(50)
FH34S-23S-0.5SH(50)
FH34S-32S-0.5SH(50)
FH34SRJ-4S-0.5SH(50)
FH34SRJ-6S-0.5SH(50)
FH34SRJ-8S-0.5SH(50)
FH34SRJ-10S-0.5SH(50)
FH34SRJ-11S-0.5SH(50)
FH34SRJ-12S-0.5SH(50)
FH34SRJ-14S-0.5SH(50)
FH34SRJ-16S-0.5SH(50)
FH34SRJ-18S-0.5SH(50)
FH34SRJ-20S-0.5SH(50)
FH34SRJ-22S-0.5SH(50)
FH34SRJ-24S-0.5SH(50)
FH34SRJ-26S-0.5SH(50)
FH34SRJ-30S-0.5SH(50)
FH34SRJ-34S-0.5SH(50)
FH34SRJ-40S-0.5SH(50)
CL No.
CL580-1224-2-50
CL580-1228-3-50
CL580-1208-6-50
CL580-1238-7-50
CL580-1236-1-50
CL580-1231-8-50
CL580-1251-5-50
CL580-1258-4-50
CL580-1253-0-50
CL580-1252-8-50
CL580-1259-7-50
CL580-1248-0-50
CL580-1256-9-50
CL580-1254-3-50
CL580-1255-6-50
CL580-1247-8-50
CL580-1232-0-50
CL580-1261-9-50
CL580-1260-9-50
Number of Contacts
7
23
32
4
6
8
10
11
12
14
16
18
24
26
30
34
40
A
5.5
13.5
18
4
5
6
7
7.5
8
9
10
11
12
13
14
15
17
19
22
B
3
11
15.5
1.5
2.5
3.5
4.5
5
5.5
6.5
7.5
8.5
9.5
10.5
11.5
12.5
14.5
16.5
19.5
C
4.03
12.07
16.53
2.53
3.53
4.53
5.53
6.03
6.53
7.53
8.57
9.57
10.57
11.57
12.57
13.57
15.57
17.53
20.53
D
4.88
12.88
17.38
3.38
4.38
5.38
6.38
6.88
7.38
8.38
9.38
10.38
11.38
12.38
13.38
14.38
16.38
18.38
21.38
Tape and reel packaging (5,000 pieces/reel, 500 pieces/reel).
Order by number of reels.
3
■Recommended PCB mounting pattern and metal mask dimensions
(0.185)
(0.25)
(2.9)
(0.15)
0.8±0.05
(0.065)
(0.15)
∞Number of contacts
0.3±0.05
0.1 J
0.25±0.03
(Metal mask)
(0.25)
0.65±0.03
(Metal mask)
J
0.5
3.3±0.05
0.8±0.05
Recommended metal mask thickness: t=0.1
B
E±0.1
F±0.1
(A)
■Recommended FPC/FFC Dimensions
G±0.05
0.
R
H
2-
0.3±0.03
(Uncover area)
1.5±0.3
2
B±0.03
0.5±0.03
0.3±0.03
2.5MIN(Stiffener)
0.5±0.07
Note 1 : Stiffener dimension should be 2.5mm min., and H dimension should be 0.5mm for improved flexibility of FPC.
Note 2 : When using the FPC/FFC in FH34S or FH19SC connectors, the exposed area inserted in either connector is 2.5mm ±
0.3mm and the stiffener is 3.5mm min.
Part Number
FH34S-7S-0.5SH(50)
FH34S-23S-0.5SH(50)
FH34S-32S-0.5SH(50)
4
CL No.
CL580-1224-2-50
CL580-1228-3-50
CL580-1208-6-50
CL580-1238-7-50
CL580-1236-1-50
CL580-1231-8-50
CL580-1251-5-50
CL580-1258-4-50
CL580-1253-0-50
CL580-1252-8-50
CL580-1259-7-50
CL580-1248-0-50
CL580-1256-9-50
CL580-1254-3-50
CL580-1255-6-50
CL580-1247-8-50
CL580-1232-0-50
CL580-1261-9-50
CL580-1260-9-50
Number of Contacts
7
23
32
4
6
8
10
11
12
14
16
18
24
26
30
34
40
A
5.5
13.5
18
4
5
6
7
7.5
8
9
10
11
12
13
14
15
17
19
22
B
3
11
15.5
1.5
2.5
3.5
4.5
5
5.5
6.5
7.5
8.5
9.5
10.5
11.5
12.5
14.5
16.5
19.5
E
4.6
12.6
17.1
3.1
4.1
5.1
6.1
6.6
7.1
8.1
9.1
10.1
11.1
12.1
13.1
14.1
16.1
18.1
21.1
All dimensions: mm
F
G
4
5.4
12
13.4
16.5
17.9
2.5
3.9
3.5
4.9
4.5
5.9
5.5
6.9
6
7.4
6.5
7.9
7.5
8.9
8.5
9.9
9.5
10.9
10.5
11.9
11.5
12.9
12.5
13.9
13.5
14.9
15.5
16.9
17.5
18.9
20.5
21.9
■Recommended FPC construction
● Contact FPC manufacturer for specific details.
1. Using Single-sided FPC
FPC : Flexible Printed Circuit
Material Name
Covering film layer
Material
Polyimide
Material Thickness
(μm)
1 mil thick
(25)
Cover adhesive
(25)
Surface treatment
0.2μm thick gold plated over 1
to 5μm thick nickel underplating
Copper foil
Cu
Base adhesive
Thermosetting adhesive
25
Base film
Polyimide
25
3
35
1oz
1 mil thick
35
Reinforcement material adhesive Thermosetting adhesive
Stiffener
Polyimide
175
7 mil thick
Total
2. Using Double-sided FPC
298
Material
Material Name
Covering layer film
Polyimide
Material Thickness
(μm)
(25)
1 mil thick
Cover adhesive
(25)
Surface treatment
Through-hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polyimide
1 mil thick
25
Copper foil
Cu
1/2oz
Cover adhesive
25
Covering film layer
Polyimide
25
3
15
1/2oz
18
Base adhesive
18
(18)
1 mil thick
50
Stiffener
Polyimide
100
4 mil thick
Total
297
* To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back
side is not recommended.
3. Using FFC
FFC : Flexible Flat Cable
Material Name
Material
Material Thickness
(μm)
Polyester film
Adhesive
(12)
Thermoplastic polyester
Gold plated annealed copper foil
Adhesive
(30)
35
Polyester
Polyester
30
12
Adhesive
Polyester
30
Stiffener
Polyester
188
Total
295
4. Precautions
1. This specification is a recommendation for the construction of the FH34S Series FPC and FFC (t=0.3 ± 0.03).
2. For details about the construction, please contact the FPC/FFC manufacturers.
5
■Packaging Specification
M±0.1
N±0.1
L±0.3
1.5
+0.1
(1.95)
Unreeling direction
Unreeling direction
1.7 +0.15
L±0.3
Flat surface,
for placement with
automatic equipment
(3.2)
(4)
1.75±0.1
(0.3)
M±0.1
(0.3)
(2.25)
Ø1
.5
(2.25)
8±0.1
● Embossed Carrier Tape Dimensions
(Tape width of 32mm min.)
1.75±0.1
4±0.1 2±0.15
Ø1
.5
(Tape width 24mm max.)
Flat surface, for placement
3±
0.5
● Reel Dimensions
(Ø80)
(Ø380)
Ø1
(Q: INSIDE)
(R: OUTSIDE)
End section
Mounting section
Lead section (400mm min.)
Embossed carrier tape
No connector inserted
(10 pockets min.)
Top cover tape
(10 pockets min.)
All dimensions: mm
Part Number
FH34S-7S-0.5SH(50)
FH34S-23S-0.5SH(50)
FH34S-32S-0.5SH(50)
6
CL No.
CL580-1224-2-50
CL580-1228-3-50
CL580-1208-6-50
CL580-1238-7-50
CL580-1236-1-50
CL580-1231-8-50
CL580-1251-5-50
CL580-1258-4-50
CL580-1253-0-50
CL580-1252-8-50
CL580-1259-7-50
CL580-1248-0-50
CL580-1256-9-50
CL580-1254-3-50
CL580-1255-6-50
CL580-1247-8-50
CL580-1232-0-50
CL580-1261-9-50
CL580-1260-9-50
Number of Contacts
7
23
32
4
6
8
10
11
12
14
16
18
24
26
30
34
40
L
16
24
32
16
16
16
16
16
24
24
24
24
24
24
24
24
32
32
44
M
7.5
11.5
14.2
7.5
7.5
7.5
7.5
7.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
11.5
14.2
14.2
20.2
N
28.4
28.4
28.4
40.4
Q
17.4
25.4
33.4
17.4
17.4
17.4
17.4
17.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
25.4
33.4
33.4
45.4
R
21.4
29.4
37.4
21.4
21.4
21.4
21.4
21.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
29.4
37.4
37.4
49.4
■Operation and Precautions
Exercise care when handling connectors. Follow recommendations given below.
Operation
Precautions
1. As delivered
Delivered
with
the
actuator open. There is
no need to operate the
actuator prior to inserting
the FPC/FFC.
• Do not close the actuator without the FPC/FPC
inserted.
2. FPC/FFC insertion (The top contact specification)
Insert the FPC/FFC with
the conductive surfaces
facing up.
Align the FPC/FFC
straight
with
the
connector and insert it
firmly all the way.
FPC/FFC contact
surfaces face up.
• The contacts are making connection with the
FPC/FFC pads from the top.
Do not insert the FPC/FFC with the pads facing
down.
When inserting the FPC/FFC do not twist it. Insert
straight. Improper insertion may cause deformation
of the contacts and connection failures.
• Be sure to insert the FPC/FFC when the actuator is
fully open.
3. Locking
After FPC/FFC insertion, rotate the actuator down
to a full stop, pushing it at the center.
Rotate
• Do not operate the actuator by only one end. Open
or close by pushing at the center.
• Do not try to rotate the actuator past the fully open
90° position. This will damage the connector,
preventing it from use.
• Do not apply excessive force to the connector when
the actuator is closed.
Push at the center of the actuator.
4. FPC/FFC removal (Lock release)
Carefully rotate the actuator up to 90°, lifting it at
the center.
• Do not operate the actuator from one end only.
• The actuator opens only 90°. Do not attempt to
open it past this angle or grasp it.
• During the opening of the actuator do not press it
toward the connector body. Rotate up at the center.
Raise
Lift at the center
7
■Precautions at the Design Stage
(1) Route the FPC/FFC so that a direct pull force
(2) Make sure that there is enough space to insert/remove the FPC/FFC straight.
(3) Follow the recommendations given in this catalog in regard to mounting pattern, metal mask dimensions and
FPC/FFC mating dimensions.
(4) Consult the manufacturer of the FPC/FFC for the details on the flexibility of the specific FPC/FFC.
(5) When designing the board lay-out and spaces in the device assure that there is enough clearances for the actuator to
fully open/close.
■Precautions when mounting connectors on the PCB
◆Handling before mounting on PCB
Insertion of the FPC/FFC or operation of the actuator prior to mounting on the PCB is not recommended.
◆PC board warpage
Minimize the warpage as much as possible. The connector are straight within 0.1 mm max. Make sure that the
mounting area flatness can accept the connector terminals without causing any failure of the solder joints.
◆Forces on the board
◆When braking the large PC board into individual boards exercise care not to damage the installed connectors.
◆When attaching the boards or other components with the screws
make sure that any stresses will not cause board deflections
affecting the mounting areas of the connector.
Connectors
PCB
◆When hand soldering:
· Do not perform hand soldering with the FPC inserted in the connector.
* Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads.
* Do not use excessive amount of solder or flux compounds.
Operation of the actuator or contacts may be affected by excessive amounts of solder or flux compounds.
■Temperature Profile
MAX 250ç
250
Temperature(ç)
230ç
200
Solder method
: Reflow, IR/hot air
Environment
: Room air
Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry, Co., Ltd.'s Part
200ç
Number:
M705-221CM5-42-10.5)
150
150ç
Test board
: Glass epoxy
Land dimensions
: 0.3mm∞0.8mm
Metal mask
: 0.25∞0.65∞0.1mm thick
25mm∞40mm∞0.8mm thick
100
The temperature profiles shown are based on the above
50
25ç (60 sec.)
conditions.
90 to 120 sec.
Preheating
Start
(60 sec.)
Soldering
In individual applications the actual temperature may
vary, depending on solder paste type, volume / thickness
and board size / thickness. Consult your solder paste and
Time (Seconds)
8
HRS test condition
equipment manufacturer for specific recommendations.
