1000 Eaton Boulevard
Cleveland, OH 44122
United States
Mini DisplayPort to DisplayPort All-in-One
Keystone/Panel Mount Angled Adapter (F/F),
Black
Highlights
Angled female connector for
easy installation in tight spaces
Molded connectors with goldplated contacts for optimal
signal transfer
Panel mount adapter for
securing to podium or kiosk
Keystone design for use with
standard data wallplate
Compatible with all MDP and
DisplayPort cables
Supports video resolutions up to
3840 x 2160 @ 60Hz
DisplayPort 1.2 Compatible
MODEL NUMBER: P169-000-KPA-BK
Package Includes
Adds a Mini DisplayPort (MDP) female connector to a fixed location, such as a universal keystone
wallplate, panel, podium or kiosk. Gives your conference room, classroom, home theater room or retail
establishment a professional, clutter-free look.
Description
The P169-000-KPA-BK Mini DisplayPort to DisplayPort All-in-One Keystone/Panel Mount Angled Adapter
allows you to terminate a Mini DisplayPort connection in a keystone wallplate or panel. Or you can use the
included panel mount adapter to install the female MDP keystone jack port in a podium or kiosk. The
angled connector makes the adapter easy to install in tight spaces.
Ideal for giving your conference room, classroom, home theater room or retail establishment a
professional, tidy look, this adapter can complete an in-wall run and keep components out of sight in a
closet or another room to eliminate cable clutter. Compatible with all MDP and DisplayPort cables, the
P169-000-KPA-BK features molded connectors with gold-plated contacts for optimal signal transfer.
Features
Mounts a Mini DisplayPort Connector in a Fixed Location
● Keystone design for easy snap-in installation in wallplate or panel
Includes panel mount adapter for installation in podium or kiosk
Angled female connector for easy installation in tight spaces
Molded connectors with gold-plated contacts for optimum signal transfer
Hides components out of sight to eliminate cable clutter
Supports video resolutions up to 3840 x 2160 @ 60Hz
Specifications
OVERVIEW
1/2
DisplayPort to DisplayPort All-inOne Keystone/Panel Mount
Angled Adapter (F/F), Black
Cleveland, OH 44122
United States
UPC Code
037332195494
Technology
DisplayPort
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
9.00 x 0.50 x 7.00
Shipping Dimensions (hwd / cm)
22.86 x 1.27 x 17.78
Shipping Weight (lbs.)
0.04
Shipping Weight (kg)
0.02
CONNECTIONS
Side A - Connector 1
DISPLAYPORT (FEMALE)
Side B - Connector 1
MINI DISPLAYPORT (FEMALE)
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P169-000-KPA-BK”相匹配的价格&库存,您可以联系我们找货
