1
2
3
4
5
6
ໆౢკ
A
A
19.3
16.2
16.1
19.8 REF.
SUGGESTED MOUNTING CUTOUT
14.7
8.1
1.6
B
B
14.6
16.8
8.15
9.8
30
ACCORDING TO ANSI/TIA-568-C.2
REQUIREMENTS
C6 CHANNEL COMPLIANT
MATERIAL
C
SHIELDED CASE : COPPER C2680, T=0.25MM, 30U" NICKEL PLATED.
BRACKET : SUS304.
COUPLER HOUSING : ABS HIGH-IMPACT UL94V-0 THERMOPLASTIC.
CONTACT HOLDER : ABS HIGH-IMPACT UL94V-0 THERMOPLASTIC.
SPRING WIRE : PHOSPHOR BRONZE 5100W TEMPER WIRE, Φ=0.45MM, 3U" AU / 30U" PDNI OVER 60U" NICKEL UNDERCOAT.
PHYSICAL CHARACTERISTICS
Cat 6
COMMUNICATION
CIRCUIT ACCESSORIES
INSERTION LIFE : 750 MATING CYCLES WITH FCC COMPLIANT 8P PLUG.
CONTACT FORCE : 100 GRAMS WITH FCC COMPLIANT 8P PLUG.
PLUG RETENTION FORCE : 11 LBF MIN.
OPERATING TEMPERATURE RANGE : -10 C TO 60 C.
STORAGE TEMPERATURE RANGE : -40 C TO 68 C.
HUMIDITY : 10%~90%RH.
01/06/12
ELECTRICAL
INSULATION RESISTANCE : 500 MΩ.
DIELECTRIC WITHSTANDING VOLTAGE : 1000 V AC.
DC CURRENT RATING : 1.5 Amps.
DC RESISTANCE : 0.1Ω.
CONTACT RESISTANCE : 20mΩ.
D
NOTE
A : WILL NOT SUPPORT CHANNEL SHORTER THAN 15M.
B : DO NOT INSERT RJ-11 6P PLUG.
1
2
56Y4
E334154
01/06/12
3
N235-001-SH
C
很抱歉,暂时无法提供与“N235-001-SH”相匹配的价格&库存,您可以联系我们找货
