1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6/Cat5e 110 Style Punch Down Keystone Jack
- White, TAA
MODEL NUMBER: N238-001-WH
Highlights
Use in Cat6 or Cat5e
installations
Compliant with EIA/TIA CAT6
connecting hardware
specifications.
Dual-color coded labeling made
for both 568A & 568B (258A)
wiring schemes.
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
Package Includes
Description
Tripp Lite's Cat6/Cat5e 110 Punch Down Keystone Jacks provide maximum flexibility for any UTP
Ethernet environment. Ideal for Cat5e cabling environments, the jack also meets UL-certified
ANSI/TIA/EIA-568-B.2-1 Permanent Link/Channel Identification Test for Category 6 cabling installations.
The uniquely patterned printed circuit board construction is designed to meet Cat6 250Mhz performance,
and is fully compliant with EIA/TIA Cat6 connecting hardware specifications. With its compact casing, it fits
into any conventional face plate, outlet box, or panel. It also features dual-color coded labeling made for
both 568A & 568B (258A) wiring schemes.
UTP Cat6 22-24 AWG solid cable
Features
Use in Cat6 or Cat5e installations
Compliant with EIA/TIA CAT6 connecting hardware specifications
Dual-color coded labeling made for both 568A & 568B (258A) wiring schemes
Compact casing fits into any conventional face plate, outlet box, or panel
UL-certified ANSI/TIA/EIA-568-B.2-1 Permanent Link/Channel Identification Test
Uniquely patterned, printed circuit board designed to meet Cat6 performances
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332143662
Technology
Cat5/5e; Cat6
PHYSICAL
Color
White
1/2
White Cat6/Cat5e 110 Punch
Down Keystone Jack
Termination caps (2)
Cleveland, OH 44122
United States
Housing Color
White
Shipping Dimensions (hwd / in.)
5.00 x 4.00 x 0.50
Shipping Dimensions (hwd / cm)
12.70 x 10.16 x 1.27
Shipping Weight (lbs.)
0.02
Shipping Weight (kg)
0.01
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
110 IDC
STANDARDS & COMPLIANCE
Product Compliance
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N238-001-WH”相匹配的价格&库存,您可以联系我们找货
