N235-001-WH
N235-001-WH
    TRIPPLITE
    N235-001-WH
N235-001-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Straight-Through Modular In-Line Snap-In Coupler (RJ45 F/F), White, TAA MODEL NUMBER: N235-001-WH Highlights ● 50-µinch gold-plated contacts on RJ45 jacks ● Heavy-duty polycarbonate housing ● Keystone design for use with standard data wallplate ● Compatible with all Cat6 cables ● Backward compatible with Cat5e and Cat5 LANs Package Includes ● Connects two Cat6 cables to create one longer cable. Provides feed-through patching with standard data wallplates. Ideal for premise wiring, telecommunications, data networking and Ethernet connections. Description Strengthen your high-speed network with Tripp Lite’s N235-001-WH Cat6 Straight-Through Modular InLine Snap-In Coupler. It connects two Cat6 patch cords to create one longer cable, and its keystone design is perfect for convenient feed-through patching when used with a standard data wallplate (such as Tripp Lite’s N042-001-WH). Built for ultra-fast performance, this is an ideal coupler when setting up premise wiring, voice/data networking, telecommunications and Ethernet connections. Compatible with all Cat6 cables, the N235-001-WH features straight-through wiring and 50-µinch goldplated contacts designed to resist corrosion. The durable, high-impact polycarbonate housing resists scratching and is colored white to blend in with any color scheme. This coupler is UL-listed and meets all requirements for EIA/TIA Cat6 compliance. It’s also backward compatible with Cat5e and Cat5 LANs. Features Strengthens Your High-Speed Network ● Ideal for premise wiring, voice/data networking, telecommunications and Ethernet connections ● Connects 2 Cat6 patch cables for a longer cable run ● Keystone design for easy snap-in installation in standard data wallplates (such as Tripp Lite’s N042001-WH) ● Rated to 250 MHz ● Compatible with all Cat6 cables ● Backward compatible with Cat5e and Cat5 LANs Superior Construction for Superior Performance ● Features straight-through wiring ● 50-µinch gold-plated contacts resist corrosion and improve conduction ● Durable, scratch-resistant polycarbonate housing ● White coloring blends into any color scheme ● UL-listed ● Meets all EIA/TIA Cat6 requirements 1/3 N235-001-WH Cat6 StraightThrough Modular In-Line SnapIn Coupler (RJ45 F/F), White 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332192714 Technology Cat5/5e; Cat6 PHYSICAL Color White Cable Length (ft.) 0 Cable Length (m) 0.00 Shipping Dimensions (hwd / in.) 4.00 x 5.00 x 0.50 Shipping Dimensions (hwd / cm) 10.16 x 12.70 x 1.27 Shipping Weight (lbs.) 0.01 Shipping Weight (kg) 0.01 ENVIRONMENTAL Operating Temperature Range 14 TO 140 F (-10 TO 60 C) Storage Temperature Range -40 TO 154.4 F (-40 TO 68 C) Relative Humidity 10 TO 90% RH, NON-CONDENSING CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) PoE Type Type 3 PoE++/UPoE (60W, IEEE 802.3bt) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N235-001-WH 价格&库存
很抱歉,暂时无法提供与“N235-001-WH”相匹配的价格&库存,您可以联系我们找货
